R5/6 what have you assigned for the 4th dial? A poll
Started Oct 3, 2020 | Polls
R5D4
R5D4 Contributing Member • Posts: 968
So I’m wondering what everyone is assigning for their 4th dial with the R5 and R6.
Let’s assume you have three of the dials assigned to the exposure triangle of Av, Tv and ISO. If that is not true then select “other” and list your settings in the comments below.
I’m also interested in which dials people are setting to what. For me, I am setting
Main dial: Aperture
Quick control dial 1: shutter
Quick control dial 2: ISO
Lens control ring: Select AF method
Please detail your control scheme in the comments.
 R5D4's gear list:R5D4's gear list
Canon EOS R5 Fujifilm X-T3 Canon EOS R6 Canon EF 35mm F1.4L II USM Fujifilm XF 35mm F2 R WR +9 more
POLL
Exposure compensation
41.2% 14  votes
Flash exposure compensation
2.9% 1  vote
Select AF method
29.4% 10  votes
Picture style
5.9% 2  votes
WB
2.9% 1  vote
Kelvin
5.9% 2  votes
Other
11.8% 4  votes
  Show results
Canon EOS R5 Canon EOS R6
Myrgjorf Regular Member • Posts: 464
Re: R5/6 what have you assigned for the 4th dial? A poll
Main dial: Aperture
Shutter (I find shutter speed changes more important for wild life)
Aperture
Exposure compensation (I am using auto ISO)
Select AF method
Oh no! He should know by now that "equivalence" is a forbidden word for APS-C but perfectly allowed for 1” Sonys, compact cameras, smartphones and maybe even for M43s.
 Myrgjorf's gear list:Myrgjorf's gear list
Sony RX100 Olympus TG-5 Canon EOS-1D X Mark II Canon EOS M50 Canon EOS R5 +20 more
sneaky Forum Member • Posts: 53
Myrgjorf wrote:
Main dial: Aperture
Aperture
Select AF method
I have the  EF adapter with the control ring.  I don't use it because, with my longer EF lenses, my left hand is too far forward (to support the weight of the lens) so I can't reach the control ring.
stevvi Contributing Member • Posts: 829
Other. I use Fv mode 99% of the time and don't use the control ring on the lens at all as, when I did, I kept forgetting my EF 100-400 (my last EF lens apart from the 100 macro) doesn't have one. When I get the RF 100-500 I'll probably start using it, and then have to remember about it!
 stevvi's gear list:stevvi's gear list
Canon EOS R Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM +4 more
DutchBoy17 Regular Member • Posts: 139
Main dial: Aperture
Main dial: Aperture
Quick control dial 1: Tv
Quick control dial 2: EC
Lens control ring: Select AF method*
* - I'm thinking about putting ISO on the LCR because I've also set up the AF point selection to let me toggle AF-Mode between tracking and 1-point using M-Fn, and I use touch screen to move the 1-point around. I like being able to switch between Auto-ISO and a specific ISO, but I haven't figured out setting up the R6 for that yet. I currently have C1 and C2 set up to use Auto-ISO with 'day' and 'night' upper limits respectively, coupled with EC on QCD 2 this lets me work the way I used to with Fuji bodies and their dedicated EC dials.
I've been away from Canon since 2009 but from 1995 - 2006 an EOS-5 (Elan IIe) was my primary body and then a Rebel XTi. Anyway, a lot's changed since those days and I've only had the R6 in hand for a day and half, so it's all subject to change
 DutchBoy17's gear list:DutchBoy17's gear list
Panasonic Lumix DMC-GM5 Fujifilm X100V Nikon Z50 Fujifilm X-T5 Panasonic Lumix DC-S5II +21 more
9VIII Senior Member • Posts: 1,331
I don't have an RF mount body but seeing all these options sure does make me want one.
Marmite Gang For Life!!!
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +7 more
nurf Regular Member • Posts: 365
Good old aperture on the lens dial, so I can quickly change it if I need more depth without having to do anything with the right hand.
 nurf's gear list:nurf's gear list
Canon EOS M6 II Canon EOS R5 Canon EF 400mm f/2.8L IS USM Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM +4 more
arbitrage Contributing Member • Posts: 585
I have assigned the Control Ring to EC at times and Direct AF Selection at other times.  But I actually don't use it ever.
1) Main Dial = Shutter Speed....for birds/wildlife I'm always changing this, rarely aperture (I just shoot wide open
2) Quick Control Dial 1 (lower rear wheel): Aperture...more awkward to get to and I rarely change from wide open so leave I leave Aperture there
3) Quick Control Dial 2 (upper rear wheel): ISO....second most common thing I change after SS.
I shoot in M all the time.  Therefore EC is not needed.  I had EC on my Control Ring to play around with Auto ISO.  But I find with WYSIWYG in the EVF that it is just faster for me to move my SS or ISO quickly vs messing around with Auto ISO and EC.
I then had Direct AF Selection on the Control Ring but I find the Control Ring on the 100-500 and the EF adapter to be next to extremely awkward to get to.  The Control Ring needs to be way further out on the lens for larger lenses (like what Canon did for the 600/800 DO lenses).
I currently have SET button to do Direct AF Selection but rarely need that as I have 4 different AF modes already on different Custom Buttons (Auto Face/Tracking on shutter, Zone on AF-ON, Spot on * and Horizontal Zone on the AF Selection button).  But occasionally I want to try one of the other ones or bring one of my back button ones up to the shutter to make it quicker to activate so that is when I use the SET button.
 arbitrage's gear list:arbitrage's gear list
Canon EOS 450D Nikon D500 Nikon Z50 Sony a1 Canon EF 100mm F2.8L Macro IS USM +15 more
Rawpaul
Rawpaul Senior Member • Posts: 2,567
exposure compensation , because it feels natural.
And I use Auto ISO mostly.
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
Frodro100
Frodro100 Regular Member • Posts: 386
Main dial: Aperture
Same as you with the dials on the body. I'm trying out AF area on the control ring, but the more I fiddle with customizing buttons and rings, the less easily I can remember where I put them. Almost to the point of wishing that the Ring Func menu could hold more than just 5 items, so I could throw everything into that menu for now.
rmexpress22 Senior Member • Posts: 2,304
I have the Viltrox EF to RF, which I'm sure doesn't work as well as the original, so I don't use the control dial because of how it feels. I tried setting it to change AF mode but didn't like that either, but I think I left it as that even though I don't actually use it.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
