Panasonic Lumix G90
Gadders New Member • Posts: 1
Panasonic Lumix G90
Hi there, I've recently purchased a Lumix G90, intending to use it for videography.
I'm having problems, though, with the audio. I have connected an external lavalier mic (Boya) which works fine. However there is an enormous amount of background hiss coming from the camera. I can reduce the dB level but on playback it's still there. I really need a clean sound.
1. Is there a way of reducing the hiss  or
2. Is there a way of bypassing the built-in mic and just using the external mic?
Sranang Boi Senior Member • Posts: 2,240
Re: Panasonic Lumix G90
Once you plug the Boya mic in the internal mic should automatically get disconnected.
Which Boya mic are you using? If it is the BT-SM80 then you are experiencing the same problem that I have with mine.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
Toshito123 Forum Member • Posts: 57
You posted on the wrong forum.
This forum is for the compact Panasonic cameras without interchangeable lenses.
You might have more replies in the Micro Four Thirds forum.
 Toshito123's gear list:Toshito123's gear list
Panasonic ZS200
