Flash compatibility
Started 4 months ago | Questions
Harvey
Harvey Regular Member • Posts: 254
Flash compatibility
I have Good flashers for my Fuji XT one camera. i use the GODOX  remote/controller.
I wish to use I wish to use these flashers with my Olympus EM5 camera.
My question is if I bought the Olympus compatible Remote controller for the Olympus camera will it automatically sync and be compatible with these GODOX flashers that I have for my Fuji XT camera.
Thank you in advance.
 Harvey's gear list:Harvey's gear list
Panasonic FZ2500 Sony RX100 V Fujifilm X-T1 Sony a6300 Panasonic G85
dinoSnake Veteran Member • Posts: 3,491
Re: Flash compatibility
They should.  I've just my Olympus Godox flashes with Canon cameras by using a Canon X-Pro on the Canon, and they work great.
kli
kli Veteran Member • Posts: 3,719
Yes, it will.
I have a Godox TT685-C (Canon) that I can use with the XPro-O on my GX-7 and the XPro-F on my X100T, as well as the Xpro-C on my 5DMkII.
Since MFT and Fuji support came out at the same time, any flash that can understand one can understand the other.
Godox released brand support in the following order: Canon, Nikon, Sony, MFT/FUji, and Pentax.   If any of your light versions are older than the support you want (i.e., you have a for-Fuji flash, but need to use it with Pentax), then you may have to firmware update the light.  But if you have a newer one, it should support all the older ones (e.g., the Fuji versions already support Canon, Nikon, Sony, and MFT).
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
