PENTAX K50 focal lenght
Started Sep 30, 2020 | Questions
hermglick New Member • Posts: 14
in menu FOCAL LENGTH INPUT no longer available. occasionally i use a non auto lens, and it use to work fine.
about six months ago my exposure went out the window. sent camera to PENTAX / RICOH for repair. they replaced resistor board. problem fixed.
yesterday was the first time since repair i tried a manual lens and it will not function.
what should happen when i turn power on after mounting lens is you should get a screen INPUT FOCAL LENGTH  that dose not happen and the camera will not function.
further it is not accessible in MENU. it is there but not highlighted and can not be accessed.
my question is HELP WHATS GOING ON...no no no SORRY.   do you think it is a malfunction or is it possible  repair messed up something when they worked on it ?
thank you for any input
glicker
Pentax K-50
rmalbers Contributing Member • Posts: 529
Re: PENTAX K50 focal lenght
Is SR turned on, that's when you get that. If SR is off you won't see it,  (I think)
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
glicker
I think you should contact Ricoh and explain the problem to see what they say.
flektogon
flektogon Veteran Member • Posts: 6,226
It should work regardless of any camera setting. As the first thing, clean the contacts on the camera mount (and on the lens) with an alcohol swab.
Peter
MightyMike Forum Pro • Posts: 41,691
Make sure you've set the "use aperture ring" custom option to something like "permitted" (could be worded slightly differently) and probably "catch-in-focus" to "on" if that is your preference. Also you might want to make sure SR is turned on, note that in certain shooting modes like timer it automatically turns the SR off.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Phil A Martin
If I understand correctly the problem only occurs when he attaches a manual lens to the camera. When you do this, there should be a pop up screen telling you to input the focal length but this is not happening. This pop up is independent of all other camera settings. I'm afraid that what you suggest would have no effect in the fault.
There was a time when the focal length question only popped up when SR was turned on, this changed and I can't remember which cameras have the change and which cameras are on the old system.
Mike from Canada
Phil A Martin
Well if it did, it predates the K20
If i turn SR switch to off on my K10D it doesn't ask for the focal length when I turn the camera on... maybe that was the last generation?
Mike from Canada
OP hermglick New Member • Posts: 14
thank you all for advice.   prior to exposure repair it worked fine.
i would get the pop up screen ENTER FOCAL LENGTH.  now i cant even access it in the menu.  its there but not highlighted. i cant access it in any mode. tried with auto and manual lens. no good.
glicker
Phil A Martin
glicker
You need to go back to ricoh and explain the situation. It sounds like it needs further attention.
thank you..i will try
glick
AlainCo Regular Member • Posts: 382
You did check that the use of aperture rings is allowed, didn't you?
Cheers
AlainCo
Beauty is in the eye of the photographer
 AlainCo's gear list:AlainCo's gear list
Fujifilm X100F Pentax K10D Pentax K-5 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +2 more
Oiche Senior Member • Posts: 2,045
glicker
Try a camera settings reset.
 Oiche's gear list:Oiche's gear list
Pentax K-70 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 40mm F2.8 Limited Samyang 14mm F2.8 ED AS IF UMC HD Pentax DA 15mm F4 ED AL Limited +1 more
