Fujifilm X-T4 great price with caveats
sebek911 Regular Member • Posts: 184
Hi there, I got a crazy deal on an X-T4 for 800 but... the play and delete buttons to view photos are not working. If I assign the function button to play, it does let me review photos but even then I can't use the delete button.
Would you keep it and just deal with this? will it get worse?
I can also purchase a 2 year New Leaf extended warranty.
SpeedyNeo
SpeedyNeo Contributing Member • Posts: 809
Re: Fujifilm X-T4 great price with caveats
Yes, you can assign Play to another button, and for deleting just press menu and choose Erase. That's how I delete photos anyway 😃
That's a crazy cheap deal if you ask me, assuming there's nothing else wrong with the camera.
Fujifilm X-T3 | XF16mmF1.4 | XF35mmF1.4 | XF90mmF2 | Fujifilm X100V | Fujifilm FinePix XP140
 SpeedyNeo's gear list:SpeedyNeo's gear list
Fujifilm XP130 Fujifilm X100V Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +1 more
Morris0
Morris0 Forum Pro • Posts: 16,736
If you purchase the warrantee at a reasonable price you can have the camera serviced and have all functions as they should be.
Great deal!
Morris
Fujifilm X-T3 Samyang 12mm F2.0 NCS CS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Sigma 150-600mm F5-6.3 | C XF 90mm +11 more
OP sebek911 Regular Member • Posts: 184
So the menu underneath the ISO dial - when I change any of these, should I see anything on the screen change?
So many things to check that I have no clue if there is anything else wrong.
How do I test the menu under the ISO dial to make sure it's working?
MrSee
MrSee Senior Member • Posts: 1,204
Sounds like a great idea!
Jim from Ontario Canada
Fuji X-H1
Fuji 18-55 2.8-4
 MrSee's gear list:MrSee's gear list
Fujifilm X-H1
Foxjet Contributing Member • Posts: 855
$800 USD? If so I too would check the camera very carefully.
Are you aware that Fuji has a PDF manual online? Do us a favor and read it.
 Foxjet's gear list:Foxjet's gear list
Fujifilm X100T Fujifilm X-E1 Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-T3 +1 more
KennyXYZ
KennyXYZ Regular Member • Posts: 445
My guess is that it will get worse over time. At least that was my experience with my X-e2. I kept on finding work arounds for dying buttons, dead AF and blurry LCD until one day I was left with manual focus only. My keeper rate was getting worse and worse. In the end I got my money's worth and became a better picture taker because of it.
 KennyXYZ's gear list:KennyXYZ's gear list
Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR +2 more
Yeah looks like the menu below the ISO dial is not functioning either.
I followed manual for ADV and changed it to different filters and LCD image doesn't change at all.
