Canon EOS R6 Sensor Measurements at PhotonsToPhotos
bclaff Forum Pro • Posts: 10,577
Like the R5 there is some sort of Noise Reduction (NR) at low ISO settings (down triangle symbol). Here's the Photographic Dynamic Range (PDR) :
Because of the NR it's a little hard to judge if there is dual conversion gain at ISO 400 or not; that is still under investigation but I suspect not.
Unlike the R5 I did not detect NR using electronic shutter on the R6.
Here are some of the 2D Fourier Transforms (pushed to enhance visibility):
Mechanical shutter all whole ISO settings
Electronic shutter first four whole ISO settings
Remember, "random" pattern means no processing.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Canon EOS R6
Abu Faisal New Member • Posts: 19
Re: Canon EOS R6 Sensor Measurements at PhotonsToPhotos
Thanks Bill ... Extremely helpful as always
I could see that R6 curve is similar to 1dx mark iii. However, 1dx mark iii curve doesn't show noise reduction in the curve (no triangle) while DPReview shadow improvement shows what seems to be noise reduction in the 1dx mark iii when compared with other brands as shown below:
https://www.dpreview.com/reviews/image-comparison/fullscreen?attr144_0=canon_eos1dxiii&attr144_1=sony_a9ii&attr144_2=sony_a7iii&attr144_3=nikon_d850&attr146_0=100_6&attr146_1=100_6&attr146_2=100_6&attr146_3=100_6&attr177_3=efc&normalization=compare&widget=747&x=0.13130655709667333&y=0.49820192759806886
Any thoughts dear Bill
Thanks and Best Regards,
 Abu Faisal's gear list:Abu Faisal's gear list
Sony RX100 V Canon EOS 5DS R Canon EOS R Canon EOS M6 II Canon EF 70-200mm F2.8L IS II USM +18 more
OP bclaff Forum Pro • Posts: 10,577
Yes, there is NR there too which I missed. I'll have to update the symbols on the 1dx mark iii chart.
Accidentally posted in wrong forum now here .
