24-70mm f4 Sony lens knocking
Started 7 months ago | Discussions
jassyou Junior Member • Posts: 29
I have just bought this lens last week. after a few times using it, I noticed whenever I turned the camera (lens attached to A9), there was a knocking sound which I suspect coming from the lens.
Anybody has experienced like this? What is the probable cause? BTW, the lens is under warranty.
Thank you.
 jassyou's gear list:jassyou's gear list
Canon PowerShot S120 Panasonic Lumix DC-ZS80 Sony RX100 VII Fujifilm FinePix S5 Pro Nikon D60 +33 more
mcslsk Veteran Member • Posts: 6,282
Re: 24-70mm f4 Sony lens knocking
Yes, the lens makes a soft clicking noise when moved. No need to worry.
 mcslsk's gear list:mcslsk's gear list
Fujifilm X100V Sony a6500 Sony a7R III Canon EF 135mm F2L USM Canon EF 70-200mm F4L IS USM +54 more
OP jassyou Junior Member • Posts: 29
thanks
Martin_99 Senior Member • Posts: 1,598
If I would get a dolar whenever I see this question on dpr forum 😁😁
 Martin_99's gear list:Martin_99's gear list
Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Sony E 18-135mm F3.5-5.6 OSS
Photo_Genius New Member • Posts: 21
I had two of them. One had a lose focusing element and made the noise, but worked fine when turned on.
 Photo_Genius's gear list:Photo_Genius's gear list
Sony a7 III Sony FE 35mm F2.8 Sony FE 70-300mm F4.5-5.6 G OSS Sony FE 12-24mm F4 Sony FE 24-105mm F4 +1 more
Thank you
Sir, I understand your feeling, but I am new to Sony..this kind of 'problem' is new to me, that's why I asked. Apologize if it was a silly question.
