Samsung nx1000 canon mount adapter
Started Sep 25, 2020 | Questions
Monica gellar New Member • Posts: 3
I got EOS to NX, K&F Lens Mount Adapter for Canon EF EF-S Mount Lens to Samsung NX Mount Mirrorless Camera Body for Samsung NX1 1000 to fit the Canon EF 80-200mmm f/4.5-5.6 OK Black Lens when I try to take an photo it blurry is also blurry when recorded an video what should I do.
I using the EOS to NX, K&F Lens Mount Adapter for Canon EF EF-S Mount Lens on my samsung nx1000 mirrorless camera.
Please answer ASAP
Samsung NX1 Samsung NX1000
kypfer Contributing Member • Posts: 985
Re: Samsung nx1000 canon mount adapter
Please answer ASAP
Presumably you do realise that the lens can only be used with a wide-open aperture and that you have to focus the lens manually. Also you won't have any image stabilisation, so you might need to fit it all on a tripod.
It's "little details" like these that are often not emphasised when you buy the adaptor!
Good luck
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
Please answer ASAP
Good luck
Yes, and to be more specific, the adapter is a 'dumb' adapter, meaning zero electrical connections between the NX body and the lens.
One 'might' be able to change the EF lens aperture by:
1. On Canon, mount the EF lens on body, power-up, goto Aperture Priority Mode, set the aperture, power-down, remove the EF lens, note that the lens aperture is not wide-open anymore.
2. On NX, mount EF lens to adapter...
"If you don't read the newspaper, you're uninformed. If you read the newspaper, you're misinformed." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
