E-PL6 cannot adjust shutter in Manual mode?
Started Sep 24, 2020 | Questions
JamiesonS New Member • Posts: 13
I've had my E-PL6 for a number of years now and I don't shoot full Manual that much, but I do have a couple of adapted OM lenses that I like to play with.
Typically when I switch to M mode I can't adjust the shutter speed... it just doesn't respond. Aperture and everything else works fine.  If I then switch the mode dial to something other than M and then back to M I can adjust shutter speed just fine... but usually only one time.  After that it won't change until I switch the modes again.
Since it DOES work after I flip the modes I'm thinking this is not a mechanical issue but possibly a firmware issue? (I have the most recent loaded.)  Or is it possible I have something else set that is causing this behavior?
 JamiesonS's gear list:JamiesonS's gear list
Casio Exilim EX-P505 Olympus PEN E-PL6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +4 more
Olympus PEN E-PL6
AndyH44 Veteran Member • Posts: 3,111
Re: E-PL6 cannot adjust shutter in Manual mode?
Not sure about your E-PL6, but with my E-PL7 there is a "Dial Function" selection in Menu "B" that needs to be set correctly for what you need.
"True craftsmen never blame their tools, but learn to use them properly"
baxters Veteran Member • Posts: 5,319
On the EPL5, switch to M and the wheel only changes aperture. Push the up on thr 4-way button, it changes the screen to where the aperture and shutter can be changed by the 4-way. . Left/right change shutter, Up/Down for aperture.
The up button works the same way in M mode on the EPL9, so bet there's no change on the EPL6. DIfference on the EPL9 is going into M mode only lets the wheel change the shutter. There is probably a setting that prioritizes shutter or aperture as the initial choice in M mode,
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
There is in the E-PL7! Exactly as I described in my response.
BTW - you cannot change the aperture with a camera dial or button on a manual lens.
Helen
Helen Veteran Member • Posts: 7,606
Since the E-PL6 (like the E-PL2 to the current E-PL9 and E-PL10) has only one control dial (the earlier E-PL1 didn’t even have that and relied on buttons only), in M mode you need to tell the camera whether you wish to change shutter speed or aperture - it will default to the one you have set as your preference. To change the other value, simply press the “up” direction of your 4-way controller on the back of the camera, marked with +/- in a diagonally-split square (this function normally controls exposure compensation in the P, S and A modes) and your control dial (the ring around the 4-way controller on the E-PL6) will temporarily switch from the default parameter in M mode (in your case, aperture) to shutter speed. You can tell when it is in this alternative mode by the presence of paired up/down and left/right arrows in front of the shutter speed and aperture. It reverts to the default priority on half pressing the shutter button, pressing OK, changing mode, playback, menu operation or taking a shot. Whilst the arrows show, you can also choose to use the r-way press-button function to change the shutter speed and aperture, holding down for a faster continuous change than spinning the ring would provide, if preferred.
Sometimes the operation of this combined 4-way press button/rear ring array can get twitchy due to oxidisation in the related models which use it (E-PL2, 3, 5, 6 and E-PM1 and 2). In this case, it can become over-sensitive and skippy, or think it is being pressed when only rotated, or vice versa. Accidental presses when rotating by the user simply pressing in a little without realising whilst turning are also a possibility with any brand using this design (they were commonplace a decade ago but many disliked them for this reason).
If it is oxidised contacts, spinning the dial hard, fast and repeatedly may help rectify it for a while.
if you like the design, sensor and operation of the E-PL6, look out for an E-PL7 or E-PL8 (the latter still available new), which have moved the control dial to encircle the shutter button - much more robust as it only rotates (the 4-way push button “ring” remains on the back but with no rotation). They also have much better IBIS and a larger monitor. The newer E-PL9 and 10 also have these improvements but have simplified menus which lose a fair bit of customisation and options, have polycarbonate (but very solid) bodies and are not able to use an optional EVF any more, if you have one. The E-PL9 does have a limited silent shutter facility though (first time in an E-PL model, but a program-only scene mode effectively, with less user control than P-mode). The E-PL10 additionally has the option of fully functional silent shutter use in PASM modes with no user control limits, and can even use it with flash (TTL auto metered flash, too), but only up to 1/20 due to the scan/sweep speed of the 16MP sensor.
Helen
See my lengthy reply which prevented me from seeing your post as I was typing it. The +/- (up arrow) feature on the 4-way rear controller temporarily switches the control dial value to the other one in M-mode on the E-PL9 and 10, as on their predecessors.
Actually, I see you said that, so view this as a “hear hear”. I’ve just double checked my E-PL10 (same applies to E-PL9) and in fact the option to choose whether the control dial defaults to altering the shutter speed or aperture still remains on these models despite their frequent loss of other configuration features in the name of simplifying the menus - it's in the Dial Function segment of gear menu B - Button Functions, which is similar to the earlier models.
OP JamiesonS New Member • Posts: 13
Thank you all for the replies.
Dial and buttons while in M mode:
With Menu B : Button Dial : Dial Function : M = FNo.
Dial will adjust Aperture just fine but the 'Up' and 'Down' buttons fail to adjust the Shutter speed. When I press the 'Up' button, the Shutter speed indicator illuminates but further 'Up' 'Down' button presses do not adjust the Shutter speed, rotating the dial does nothing and 'Left' 'Right' button presses adjust the FNo.
With Menu B : Button Dial : Dial Function : M = Shutter
Dial doesn't adjust Shutter.  A button 'Up' press causes the Shutter speed to illuminate as if it's going to adjust, but further 'Up' 'Down' button presses do not adjust the Shutter speed.  'Left' 'Right' button presses do adjust the Aperture.
Oddly enough the Dial and buttons work as expected while in S mode:
With Menu B : Button Dial : Dial Function : S = Exposure Comp.
Dial adjusts Exposure Compensation and the 'Up' and 'Down' buttons adjust Shutter speed just fine.
The fact that the manual buttons and dial appear to work as expected in S mode but not in M mode makes it seem like it's a software or setting issue.  The mechanical bits work in one mode but not the other.  It's become a major frustration... especially because I have a couple of adapted manual lenses that I like to putter with... and not being able to adjust the shutter reliably in full M mode is ridiculous.
Desperate times...
So I ended up performing a FULL reset and blew away any of my previous settings.  Magically, the Shutter now works as expected in M mode using the buttons and the dial.  I guess I should have "bit the bullet" earlier and just wiped the settings and started over.
Your advice is greatly appreciated.  Stay safe, everyone.
