DX on FX, a success, with a TC!
Started Sep 23, 2020 | Discussions
Tord S Eriksson
Tord S Eriksson Forum Pro • Posts: 17,289
Over in another discussion forum, Cosmicnode asked if anyone had tried using a Nikon AF-P 70-300 VR DX lens with a Kenko TC on an FX camera, would it work, and if so, how well?!
Well, I was the one who had the combination, so I just had to try it, and it worked really well, although in low contrast/low light the AF was at time hesitant.
I also tried the Sigma 30&1.4 Art, AF-P 18-55 VR, and the 40/2.8 macro, and no issues at all.
No vignetting, focus spot on (if acquired at all).
Tord
Samples:
Surprising results for me, do you have any other examples?!
Interesting group!
Tord
tordseriksson (at) gmail.....
Owner of a handful of Nikon cameras. And a few lenses.
WSSA #456
 Tord S Eriksson's gear list:Tord S Eriksson's gear list
Olympus C-8080 Wide Zoom Ricoh GR Nikon 1 V1 Nikon D600 Nikon D3300 +24 more
petrochemist Veteran Member • Posts: 3,619
Re: DX on FX, a success, with a TC!
I've tried c-mount lenses with poor coverage with a cheap c-mount TC coverage definitely improved as expected. Unfortunately my cheap TC was rubbish so IQ wasn't worth the effort.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
epozar
epozar Senior Member • Posts: 1,966
No wonder here - the TC uses only the central part of an image circle
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
If a 1.5x TC is taking the image from a APSC lens & spreading it to fit a FF sensor it's effectively using all the lenses image circle.
Tord S Eriksson
OP Tord S Eriksson Forum Pro • Posts: 17,289
Never heard of a 1.5x TC, all I've used are 1.4X.
I was surprised it worked so well, considering there is an extra number of glass elements in the light path. Much better than using the same Kenko TC on a DX body, for instance!
I expected some vignetting, but I could not notice any.
WSSA #456
1,5x TCs are indded unusual, but the number just fiited the sensor sizes better.
I think I have seen a 1.5x in the past but 1.4x, 2x & even 3x are more common. I also have a 1.7x for that matter.
It's not unusual for the image circle of a lens to be somewhat bigger than the bare minimum for covering it's chosen sensor so a 1.4x will usually be enough to take a 1.5 crop lens up to a FF. There's likely to be a smaller proportion of Canon APSC lenses that can use this trick as their APSC is smaaler with a 1.6 crop.
In the past I've tried using a 0.7x focal reducer for using APSC lenses on MFT. the crop ratio is close to 0.7 but it didn't work for the fisheye lens I was trying. The different aspect ratio might have played a part. (The focal reducer only claims to work for FF lenses)
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
A few quick notes on APS-C to FF via 1.5X
I've been recommending this for a while. At Electronic Imaging 2016, I published Mixing and matching sensor format with lens coverage , which showed that the APS-C-lens-on-FF -body-via-1.5X-teleconverter trick works very well indeed.
Here is a sample from that paper using a cheap APS-C fisheye -- arguably the type of lens one would least expect to produce good results on a teleconverter:
Opteka 6.5mm APS-C rectangular fisheye with 1.5X teleconverter on FF
Crop from the white rectangle above showing quite good quality
Aside from the fact that a 1.5X teleconverter will reduce the light by about 1 stop (sqrt(2) magnification would be precisely 1 stop), here are a few key issues:
1. The teleconverters are not very accurately labeled. Some 1.4X converters are actually magnifying more than some 1.5X (and even one marked 1.6X). However, lens coverage is usually not too tight on the native format, so there's usually enough extra coverage to be ok. The possible exception would be lenses designed for Canon's 1.6X crop not-really-APS-C cameras... but most of those still have coverage of 1.5X APS-C.
2. Many teleconverters do not properly adjust lens info electronically passed through the teleconverter. Some are simple pass-thrus that don't adjust focal length and aperture to reflect the presence of the teleconverter, which can cause various issues, the worst being incorrect IBIS correction of shake and flash exposure issues. Some teleconverters don't even implement pass thru.
3. Optical quality of teleconverters varies a lot. A lot of teleconverters are optically lousy, but some are quite good. Happily, the good ones aren't necessarily more expensive than the bad ones.
The bad news is that it can be hard to figure-out which are the good ones by #2 and #3 above without actually trying them. I've had teleconverters that were the same brand and apparently very similar model numbers, but completely different in terms of electronics and optical quality.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Tord S Eriksson
Re: A few quick notes on APS-C to FF via 1.5X
Definitely true all of this! My Kenko works better as an FX adapter than as a TC, while the Sigma TC-1401 is impressive, but doesn't fit any of my DX lenses!
WSSA #456
E Dinkla Senior Member • Posts: 2,613
With your advice from older messages in mind and some positive reviews, thread reports and images collected over time I decided to adapt a secondhand Canon EF-S 55-250mm 3.5 IS STM to my A7RII. David Kennard used a Sigma MC-11 for that but in my case that combination did not work. https://www.davidkennardphotography.com/blog/1075-canon-55-250mm-stm-on-a7r-ii.xhtml So I bought a secondhand Metabones IV with some doubt that it would work with my other AF EF and chipped manual lenses. That turned out to be more than alright: https://www.dpreview.com/forums/post/64394061
The EF-S lens I had already shaved at the rear for the MC-11 and given a 3D printed cover there for a neater look. Not needed for the Metabones IV as that one allows EF-S lenses without modifications. However the FF compatible Kenko C-AF 1.4x Teleplus MC4 DGX teleconverter can now be used too and it looks like it does a perfect job, the max focal length is now 350mm and with little tests so far (weather) at least the center is tack sharp on long distances. Vignetting with the teleconverter on is hardly a problem throughout the zoom range. Without teleconverter a square image of approx 20-22mm is usable within the FF sensor. I added a 3D printed hood with a square mask that does not add more vignetting with and without the teleconverter. Lens probably covers more than APS-C or you could be right for the converter factors being more than indicated.
I measured the difference in length between the Sigma MC-11 and Metabones IV for what theoretically should be 26mm, Canon EF register distance minus Sony FE register distance. The Sigma is 0,05/6 mm less than that, the Metabones IV 0,12/13mm less. With zoom lenses, floating element lenses and I think the tele converters/speed boosters one should not underestimate that depth difference (On the Metabones Speedbooster there is a user calibration method integrated). For me there is another reason as I calibrated all my manual lenses to infinity for the MC-11 + A&RII combination. So I tweaked the Metabones IV to the Sigma MC-11 depth. Making them both 26mm might not be a good idea, getting a completely snug fit on one extra mount connection will not happen and a small piece of dirt already throws it over 26mm.
Shaved rear with 3D printed cap reversed to show how it will fit with some glue.
It is a long total with the 3D printed hood + Kenko + Metabones IV adapter. Minolta MD I 200mm 4.0 converted to EF mount next to it. Weight of the Minolta is however more than the 55-250 + hood + Kenko.
Met vriendelijke groet, Ernst
No photographer's gear list is complete without the printer mentioned !
Tested the Canon EF-s 55-250 IS STM + Kenko more
Done some handheld testing with my converted Minolta MD I 200mm 4.0 and the Canon 55-250 with and without the Kenko. On an A7RII camera. with Metabones IV adapter. I do not have more lenses of that length to compare with. I have good images made with the Minolta lens. https://www.dpreview.com/forums/post/59944050
The distance to that wall is a bit more than 80 meters / 27 feet. Handheld, IS either lens (Canon) or camera (Minolta).
Usable square image area 24x24mm of the 55-250 set at 250mm focal length compared with 200mm cropped to the same image content. No Kenko used here.
M 200mm 8.0 M 200mm 4.0 C 250mm 5.6
Near the center. Same view percentage in Capture One
Bottom right corner
Canon is much better in the center and somewhat in the corner. A 5.6 take with the Minolta was lost, but that lens gains little from 4.0 to 8.0 so it does not matter
I did not use the 200mm setting of the Canon as my interest is in getting as much information of a distant subject. Hence the square format too. I have used the Kenko with the Minolta MD I 200mm 4.0 before and it did not deliver. So that combination was skipped here.
Next I compared the Canon with (350mm) and without (250mm) the Kenko at the same wall/distance. The format is what the 350mm captured and a crop for that applied on the 250mm images. In theory the wide open shot with the Kenko should be at 8.0 but it either was 5.6 or 9.0 that I could select and get reported. Maybe the 5.6 shot is wide open or the 9.0 one, little difference between them.
250mm top row , 350mm bottom row,
Near the center, 400 and 300% view in Capture One
Near the right bottom edge , 400 and 300% view in Capture One.
I shot a church tower at 500 meters with the Kenko and that showed a good image but I am not happy with the Kenko results here. The Canon on its own is better than expected so I am not disappointed.
full frame 350mm
Have to test them both on that distance too.
ProfHankD
Re: Tested the Canon EF-s 55-250 IS STM + Kenko more
What this tells me is either that the converter isn't very good or that the lens is nowhere near out-resolving the A7RII sensor... or maybe both. The other possibility is camera shake, which is certainly possible, especially if the teleconverter got the focal length wrong (not adjusted).
Given that it looks better in the center and worse at the edges, the converter seems to be (mostly) at fault. Certainly, I did see a wide range of performance differences between various converters....
My guess as well.  David Kennard used another Kenko for APS lenses that was not better with this lens and an A7RII.
At 500 meter on a tripod, without IS, the TC adds information in the center compared to the 250mm focal length. All samples near the center. Top row 250mm, bottom row 350mm (TC). Bottom right one should be ignored. Default Capture One development.
DJMusic Senior Member • Posts: 1,312
Thanks for the idea.  Makes perfect sense, but I would never have thought about it.  New life for my DX 10-24 on my FX body!
 DJMusic's gear list:DJMusic's gear list
Nikon D7200 Nikon D780 Nikon AF Nikkor 50mm f/1.8D Tamron SP 24-70mm F2.8 Di VC USD Tamron SP 150-600mm F5-6.3 Di VC USD +6 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
The idea of using a tele converter to increase lens coverage is certainly an interesting one, but I was surprised to discover quite how old it was. As far back as the Photokina exhibition of 1970 Sigma was showing a product called the "Imagextender", a 3x converter for fitting 35mm SLR lenses (M42 or Nikon) to Bronica or Rollei 6x6cm medium format SLRs. There's a picture and a little more information here:
https://www.flickr.com/photos/38552878@N02/50542591487/in/photostream/
As far as I can remember, though, neither this or the 36-105mm f/2.8 zoom lens shown attached ever made it to market...
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
ProfHankD
Very cool! Pity it's literally just a paragraph with no other info.
I really doubted that I invented the idea in my 2016 paper , but I wasn't able to find any scholarly (or otherwise) earlier explanations of it. Not surprising that Sigma would be doing this sort of thing in that timeframe. That's back around the peak of their wildly creative collaborations with Fred Spira and Spiratone.
MrSee
MrSee Senior Member • Posts: 2,601
Nice set. The colours really pop.
Jim from Ontario Canada
Fuji X-H1
Fuji 18-55 2.8-4
 MrSee's gear list:MrSee's gear list
Fujifilm X-H1
mek42 Regular Member • Posts: 230
Very interesting.  When I have both a TC (probably old Nikon) and a full frame body (almost certainly a Z6 II) I'll have to try the 18-55mm kit lens / TC / FTZ combo.  (It is my only DX lens.)
Thank you for the idea!
 mek42's gear list:mek42's gear list
Nikon D2Hs
Tord S Eriksson
Works very well! With a Kenko, as the design of Nikon's TCs does not work!
WSSA #456
Heritage Cameras
Apparently another 1.4x teleconverter full frame expander is planned for this year (listed in the image, but not mentioned in the text):
https://leicarumors.com/2021/01/12/coming-soon-laowa-12-24mm-f-5-6-ultra-wide-angle-zoom-lens-for-leica-m-mount.aspx/
Dave, HCL
