How To Take Panorama Shots?
Started 4 months ago | Questions
jimlau Regular Member • Posts: 226
If I want a 3 photo panorama ,the center shot being at a 45 degree angle up from the horizon, how do I adjust the left and right shots in order to maintain as much of each shot as possible? Do I rotate or tilt the 2 side photos?
Thanks.
 jimlau's gear list:jimlau's gear list
Nikon D5500 Panasonic Lumix DMC-GX85 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic 100-300mm F4-5.6 II
In2Lapland
In2Lapland Regular Member • Posts: 138
Re: How To Take Panorama Shots-Geometry?
A pano starts on the left or right, not somewhere in the middle.
First determine how you want to display it, so that the exposure is proportional for each image.
Almost all cameras have some kind of spirit level, which you keep an eye on when you are busy determining the composition. After all, you want the images on an imaginary horizon to be the same only.
If you want a "just aligned" pano, use a tripod and pano head. And then you have to figure out how many degrees you have to turn to maintain a correct overlap in order to be able to stitch the images, which differs per focal length.
Handheld is also possible, but then it will be reasonable to hold onto the imaginary horizon in advance.
 In2Lapland's gear list:In2Lapland's gear list
Sigma SD14 Sigma SD1 Merrill Sigma sd Quattro Sigma sd Quattro H Canon EOS 5D Mark IV +18 more
OP jimlau Regular Member • Posts: 226
I know all that. Photoshop did a bad job on its own, but just now under alignment it did better. still some top and bottom were a bit off. but that could have been a slight slip of the tilt.
So maybe that's all that was off.
PJPfeiffer Senior Member • Posts: 1,095
Re: How To Take Panorama Shots?
Try Microsoft ICE for combining your 3 images
 PJPfeiffer's gear list:PJPfeiffer's gear list
Panasonic Lumix DMC-FZ300 Snapseed +3 more
petrochemist Senior Member • Posts: 2,791
Beat me to it. ICE corrects for most distortions when stitching images so normally manages a trouble free merge. Photo's should ideally overlap by about 30% & should be shot in manual to ensure the same aperture/shutter speed/exposure/focus is used on all the initial photos.
ICE can manage shots taken from the sample location with the FOV rotated, as well as images taken from a series of spots. I've had it work nicely with shots from a moving ship.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-G5 +15 more
In2Lapland
Oops, the question is about post-processing?
But if PS does not want to cooperate, you will have to open the box of tricks.
dsjtecserv Veteran Member • Posts: 3,900
Thanks.
is your question about how to take the shots for best results, or how to process shot you have already taken? If you have already taken the shots (and don't have the opportunity to reshoot) then I'd suggest posting the output that you are currently getting from Photoshop, with details on what PS tools and settings you are using. And as other have suggested, using a program specifically designed for panoramas is likely to get you better results.
Obviously it is best to shoot the images in a way most likely lead to accurate stitching and the overall desired results. If you are seeking advice on how to best shoot, can you provide more information on what you are trying to do?
Dave
 dsjtecserv's gear list:dsjtecserv's gear list
Canon EOS 5DS R Canon EF 17-40mm f/4.0L USM Canon EF 100mm F2.8L Macro IS USM Canon TS-E 24mm f/3.5L II Canon EF 24-105mm f/4L IS USM +4 more
dsjtecserv wrote:
Thanks.
Dave
Both. I have 3 shots of the night sky. PS was not stitching them well. I had it set on auto and assumed it knew best. So i then started to question the shooting technique.
But then I went back and chose to just align, and 95% of all 3 images were included
So all is fine now. PS was throwing me off on how to shoot. I had locked the tilt, then just panned across the sky with sufficient overlaps. That type of shooting with alignment stitching should do the trick I assume?
jimlau wrote:
dsjtecserv wrote:
Thanks.
Dave
First, shooting only the night sky, with no other reference points such as ground objects, trees etc., is challenging for any panorama software. It is more difficult for it to detect overlapping patterns in stars etc. only. It can be done, but an accurate depiction often needs additional, manual specification of control points that should be treated as overlapping. Photoshop doesn't have a mechanism for this. But if you merely want a "starry sky" with no guarantee that the same stars are aligned from shot to shot to produce and accurate depiction of the sky, then just alignment, without warping, may accommodate that.
If you are using a pan-tilt head that allows you to adjust the pitch of the camera while still panning on a level axis, then that is fine. But if you are using a ball head and tilting the the camera up, then the rotation will be along an arc, with the high point in the middle and the frames to the left and right shooting lower in the sky.  Aligning that to make a rectangular pano will be problematic, because you don't have the higher part of the sky to the left and tight recorded.
Don't use automatic anything. Determine an exposure that is best for the whole scene, and use that on manual for all of the shots. Same thing with focus: find the best focus for the important part of the scene, adjust aperture for the desired depth of field, and then lock focus. The amount of overlap between frame varies depending on the scene, but generally about 1/3 is plenty.
Dave
dsjtecserv wrote:
jimlau wrote:
dsjtecserv wrote:
Thanks.
Dave
Dave
This is what I got from locked tripod and only panning, locked focus, using PS:
jimlau wrote:
dsjtecserv wrote:
jimlau wrote:
dsjtecserv wrote:
Thanks.
Dave
Dave
Looks nice; glad you got it worked out!
Dave
