Battery Order Question
RoyAmatore
RoyAmatore Senior Member • Posts: 1,420
What are pros and cons of which battery to use first, MD-18 on regular battery?  Do I need both operating to get 9 FPS?  Any thoughts?
 RoyAmatore's gear list:RoyAmatore's gear list
Nikon D750 Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Tamron 15-30mm F2.8 +5 more
BackPacker1532 Regular Member • Posts: 227
Re: Battery Order Question
5
I always use the grip battery first, easier to change!
 BackPacker1532's gear list:BackPacker1532's gear list
Canon PowerShot G10 Canon PowerShot SX50 HS Nikon Coolpix L320 Nikon D3 Nikon D850 +6 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 16,873
The default if grip battery first, which seems logical.   It's an easier battery to get to, so easier to recharge.  And if it is a big battery, you get more performance from the camera (in some cases more frame rate), and you'd want that as much as possible.
So it seems logical to use grip first.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +37 more
curve241 Forum Member • Posts: 69
Likewise.
JohnnyLuddite Senior Member • Posts: 1,309
As well, when you remove the grip, you know the battery is as full as when you put it in, it's likely to be fully charged in the camera itself.
Using the battery in the grip also moves a small amount heat out of the main body, although this is more significant, I understand, for ML bodies.
 JohnnyLuddite's gear list:JohnnyLuddite's gear list
Sony RX100 Fujifilm X-E1 Nikon D750 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 24-120mm F4G ED VR +2 more
