Vignetting with filters on 24-70mm f/2.8 and 14-30mm f/4?
Started 2 months ago | Questions
Tony_J Forum Member • Posts: 74
I am currently in the market for 82mm filters (in particular, from Breakthrough Photography), and part of my decision is how many filters can be stacked before there is vignetting. This will affect whether it's worth it to get a Dark CPL, for example, or if it's sufficient to just stack a regular CPL with an ND filter. And whether it's worth it to get a 10-stop ND filter, or if stacking 3 + 6 is enough.
In terms of the Z system, I plan to hold out for Nikon's next 60 MP release, but I am preemptively accumulating 82mm filters used on eBay for cheap so I don't have to buy them all at once at full price when I upgrade (my current filter set is 77mm). I'm not worried about the sunk cost as I will almost certainly require 82mm filters no matter what I upgrade to.
Can someone with either or both of those two Z lenses report on when filters start to cause vignetting on each? (And since they're zooms, does the focal length matter?)
j_photo Veteran Member • Posts: 4,923
Re: Vignetting with filters on 24-70mm f/2.8 and 14-30mm f/4?
The 24-70mm f/2.8 S has been announced but is not yet available. Meanwhile, there is some interesting info about filter compatibility here:
https://www.youtube.com/watch?v=cvzW84OLCoQ&
 j_photo's gear list:j_photo's gear list
Nikon Df Nikon Z7 Nikon Z6
Virtual Photon Senior Member • Posts: 1,295
You must mean the 14-24 f/2.8S?  Both the 24-70 f2.8s and 14-30 f4 are available.
 Virtual Photon's gear list:Virtual Photon's gear list
Nikon D500 Nikon Z7 Nikon Z6 Nikon Z50 Nikon AF-S Micro-Nikkor 60mm F2.8G ED +8 more
woops, my bad. Thanks for the correction.
Karl-FR
Karl-FR Forum Member • Posts: 84
Hi Tony !
I have a 14-30 f4 and 82mm filters. I have slim ND filters (8,64,1000) and polariser.
My english is limited so I will do as this :
14-30f4 at 14mm + ND filter = No vignetting
14-30f4 at 14mm + Polariser = No vignetting
14-30f4 at 14mm + ND filter + polariser = Important vignetting. Not usable.
14-30f4 at 14.5mm + ND filter + polariser = A very little of vignetting but you can correct with lightroom.
Here a RAW example of a stack of ND filter and Polariser at 14.5mm
A second example with just ND filter at 14mm so without polariser but rocks are shining.
I don't kept raw example of ND filter + Polariser stack at 14mm.. But it's not usable. Important vigneting. Even if my filters are slim :/
Slim ND filter are : Haida PRO II Digital MC 82mm
Polariser is : Marumi DHG circulaire 82mm
Hope I helped
Picture edited : https://flic.kr/p/2jEFuRu
 Karl-FR's gear list:Karl-FR's gear list
Nikon Z6 Sigma 150-600mm F5-6.3 | C Nikon Z 24-70mm F4 Nikon Z 50mm F1.8 Sigma 70-200 F2.8 DG OS HSM +2 more
OP Tony_J Forum Member • Posts: 74
Thanks! It looks like I don't need to be too worried about the 14-30 then. I don't intend to use a CPL on it on a sunny day due to the weird things it does to the sky on a wide-angle lens. So at most I'll be stacking a CPL with a 6-stop ND to shoot waterfalls, which generally will not require as wide as 14mm.
Now just waiting on someone to shed light on the 24-70 f/2.8...
Lance B Forum Pro • Posts: 32,794
My results concur with Karl-FR on the 14-30 with ND and polarizers.
If you are going to shoot waterfalls, I strongly recommend using a polarizer as it reduces reflections on both the water and the foliage for deep rich foliage colour and also brings out the colour of the water. You can get a dark polarizer from Breakthrough and can select standard, 3 stop or 6 stop varieties.
 Lance B's gear list:Lance B's gear list
Nikon D500 Nikon D850 Nikon Z7 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Teleconverter TC-17E II +19 more
cosmicnode Veteran Member • Posts: 5,399
Why not try a NISI filter holder with landscape polarizer, I have recently bought one but had little time to test it fully I am still waiting for graduated slide in filters to arrive, there is no vignetting from the frame with the 14-30 using the polarizer so there will not be a problem when the slide in filters arrive. I know about the sometime affects on a blue sky with polarizers but that is not their only use , removing reflections of water and glass is also useful. but you also have the 24-70 which will benefit from a polarizer. It takes 3 slide in filters but I removed one of the 3 slide fittings when I could see vignetting  at 14mm but ok with 2 slots, I bought the version 5 but the version 6 has a lock for the polarizer rotation. at a extra cost.
I had the 75mm version but have had to sell it since it does not go up to the 82mm of the 14-30
NISI
Ricci Talks discusses filters for the 14-30 f4 at around 18mins in his review of the 14-30mm
https://www.youtube.com/watch?v=yE0mSDIw0xs&t=44s
Mike.
"I say we take off and nuke the entire site from orbit, it's the only way to be sure."
 cosmicnode's gear list:cosmicnode's gear list
Nikon D1 Nikon D1X Nikon D1H Nikon D2H Nikon D2X +16 more
I'm just not interested in a filter kit, too much hassle to carry around and set up in the field. (In fact, I'm often lazy enough that I will put an ND filter over my UV protection filter if vignetting is not a problem and I'm only taking a few shots with the ND; it's better to accept a tiny amount of degradation in image quality than to potentially miss the shot.)
