Sigma MC-11 with aps-c lenses?
Merlin5 Contributing Member • Posts: 784
Hi guys. I read a viewer's comment under a youtube video and he he said aps-c lenses don't work with the MC-11. Someone replied "it is compatible, there's a hack where you remove the inner collar (4 screws) and all aps-c lenses fit."
If I wanted to buy a wide angle Tamron aps-c lens with Canon EF fit + Sigma MC-11 EF-E adapter to mount onto a Sony aps-c camera, just wondering if I'd have to do that hack or if it's not true and that they are actually compatible without the hack? I've read that the MC-11 is compatible wth aps-c cameras but not found anything else about aps-c lens compatibility.
Thanks.
 Merlin5's gear list:Merlin5's gear list
Canon EOS 5D Mark II Sony a6600 Tamron SP 70-300mm F4-5.6 Di VC USD Canon EF 50mm F1.8 STM Sigma 16mm F1.4 DC DN (E/EF-M mounts) +2 more
Ceistinne Senior Member • Posts: 2,428
Re: Sigma MC-11 with aps-c lenses?
Thanks.
Merlin5,
The MC-11 will fit on Sony E (APSC) or FE (Full Frame). The mount is the same for both. On the front end either Sigma SA mount or Sigma EF mount Canon lenses, two different MC-11s  either DC (APSC) or DG (Full Frame)Lenses. To ensure perfect focus the lenses should be Contemporary, Art or Sport.
Canon EF lenses can also be used with the EF compatible version, some of them autofocus very well and some not so well. Sigma guarantee only Sigma SA or EF mount to work.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
OP Merlin5 Contributing Member • Posts: 784
Thanks.
Merlin5,
S
Thanks for the reply Ceistinne. I've found out that the aps-c lens issue only applies to EF-S lens.
Is there a Sigma wide angle lens like a 10-20m with a sony e mount or a Sigma wide angle lens like a 10-20mm with an EF mount that can be used with the MC-11? And would either affect functionality of autofocus on a Sony aps-c camera? I'm guessing not as all I can find is Sigma 10-20mm Sony a mount and  Canon EF-S fit.
Scottelly
Scottelly Forum Pro • Posts: 15,218
Merlin5 wrote:
Thanks.
Merlin5,
S
Interesting question. I will try the 8-16 on a Sony E mount camera. My 17-50 worked on my Sony A7, using my Sigma SA mount to E mount adapter (MC-11). I don't know if the Canon mount version of that lens will work with the Canon to Sony mount MC-11 though. I'll be interested to find out. Maybe try asking the same question in one of these forums:
https://www.dpreview.com/forums/1065
https://www.dpreview.com/forums/1043
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Sigma SD1 Merrill Nikon D810 Sigma sd Quattro H Sony DT 18-55mm F3.5-5.6 SAM +23 more
mike earussi Veteran Member • Posts: 8,815
I've successfully used the Sigma 8-16 in SA mount on my Sony A7R2 without any problem (the camera crops to the APS-C size automatically). I've also use the APS-C SA mount 18-50 f2.8 macro and the 50-150 f2.8 OS lenses without any problems.
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma APO Macro 180mm F2.8 EX DG OS HSM Sigma 70mm F2.8 DG Macro Art +1 more
eFilm Senior Member • Posts: 1,976
Those would be two good reasons not to bother with YT comments.
The Sigma MC-11 is compatible with Sigma A, S, and C series lenses. Exactly as said on the tin. (Just as said in the Sigma manual and other documentation).
It is not intended to be used with other brand lenses, even though it might work with some, on varying levels. Therefore doing some "hack" would make very little sense.
Sigma do not guarantee full functionality with other brand lenses, which would be quite a tall order to begin with. I don't know about Tamron lenses, but some other brand EF lenses and even some Canon EF full frame lenses work, some well, some partially.
As for compatibility with APS-C bodies, no problem. I'd stay clear of the Canon EF-S lenses, though, just in case. The adapter has no lens element inside it, so some EF-S lenses might fit just fine, but even if some particular lens won't fit physically, I see would not ruin, as in "hack" the adapter because of that. There's no shortage of different lenses out there.
