No, not the GX8, too
Started Sep 20, 2020 | Discussions
eques Veteran Member • Posts: 4,115
My GX7 had problems with the thumb wheel 2 years ago. The whole top of the body was replaced under warranty. Then a year later the problem returned. I personally know a guy who had the same problem, and I read here on this forum, that this is a common weak point of the cheaper Panasonic bodies.
OK, so I got a GX8, which had a rather stiff exposure correction wheel. After about 15 months there is the same trouble. You correct -1/3 and get a random correction like -1 2/3 or +2/3 or non at all.
Great fun.
In my experience it is necessary to correct exposure a lot to avoid burned out highlights.
AFAIK this problem in my cameras started with more than 30k shutter actuations.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Mark Thornton Veteran Member • Posts: 4,570
Re: No, not the GX8, too
My GX1 was repaired under warranty for a problem with the rear thumb wheel (it had stopped working altogether).
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Well, I had the gx7, the gx80 and never had a problem. However, my recent Gx9 is starting to suffer the same issue. It's still under warranty so I'll probably send it in for repair, but I really hope the issue won't reappear after a few months.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
grsnovi Veteran Member • Posts: 3,030
I don't feel that the dual-purpose function of the wheel is good design given the components. If instead of a "push-to-access" the wheel was split into 2 wheels of the same diameter so you accessed top or bottom in the same location, it might be more robust.
Mine hasn't started misbehaving but I suspect it will given enough time.
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
OP eques Veteran Member • Posts: 4,115
Used Panasonic cameras
My conclusion is, that I won't buy any Panasonic bodies used, if I am not certain, I can return them.
In any case, twice sellers have been honest enough to mention problems with the thumb wheel.
Peter
(unknown member) Forum Pro • Posts: 47,805
GX9, GX850 same problem here...
If that wasn't me, then you can add me to the list. GX9, GX850.
Great fun.
Peter
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
