Sensor and lens tilt and how to DIY adjust your equipment
Started Sep 19, 2020 | Discussions
SamuelChia New Member • Posts: 9
It is difficult to determine which forum category is best for posting this thread since it is cross-disciplinary, discussing our discoveries and issues as it relates to astrophotography, though not necessarily limited to astro-work only, mainly using the Sony a7R II as an example, though the problem isn't Sony-specific. Perhaps it is best suited to live in the Sony E-mount forum since many of the examples are for the Sony system, but any enterprising photographer can easily adapt our methods to any other system.
Joseph Holmes and I have found our Sony a7R II (and my Canon 5D Mk II too) sensor to be crooked relative to its bayonet mount. A few years ago, such a claim would be considerably more aberrant. It is less so as sensors have gone way up in resolution and way small in pixel pitch, revealing tiny alignment errors better, and reader comments on Roger Cicala's recent flange distance articles and elsewhere on the web indicate that increasing numbers of photographers are concerned about such issues. No one has yet proposed a simple and relatively cheap method that is also sufficiently precise for determining sensor tilt and my hope in publishing this information is to provide such a means to anyone interested.
It should come as no surprise to most that lenses also have focus field tilt issues too, and on average the tilts seem to be more severe than sensors. Returning 'bad copies' which are decentered is fine, but returning them because they are tilted is a fool's errand since every single lens is tilted (according to Roger Cicala and also in our experience), unless one is so lucky to find one that matches the tilt of their camera. Marianne Oelund shared her method of adjusting field tilt using aluminium foil about three years ago. The ring shims Joseph and I found might be of interest. We think they are a more elegant way to shim the bayonet mount of our cameras and lenses. All the details are in my article.
Fair warning: the discourse is a very long one and covers a multitude of issues and discoveries, but I trust it would make a worthwhile read for anyone who cares.
https://cacaoeditions.com/your-cameras-and-lenses-are-crooked/
View: original size
Samuel Chia
P.S. I posted this topic first on the Sony Full Frame E-mount forum a while back but it didn't seem to get any attention. I thought perhaps since the content is quite astrophotography focussed, it might be useful to anyone who frequents this subforum category more. I hope it might help you.
SigmaChrome Forum Pro • Posts: 13,990
Re: Sensor and lens tilt and how to DIY adjust your equipment
That's a beautiful Milky Way shot with a very appealing landscape, Samuel. I like it very much. I reckon a little tone curve adjustment and a slight saturation boot would improve even more. Just a thought.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma dp0 Quattro +39 more
Tristimulus Veteran Member • Posts: 8,585
Seems more likely that field curvature (a lens issue) and slight deviations in sqaring on is the real issue here.
Image sensors and lens mounts are usually plane parallell to within tight specs.
My Sony A7III is deriver the same image quality over the entre field of view when used with my 106/530-5 astrograph (a high end flat field astrograph).
Not so when using ordinary lenses. Than field curvature and not perfectly squared on lens elements play a role. All within specification, but somewhat looser tolerances. That is real life in a not perfect word.
Flange distance to the image sensor is usually the least problem here.
Only if over intepretating the results.
Need to know the specifications before complaining. After all Cameron and lenses are industrial products made within certaint tolerances (real life is a balance between price and cost). Only a fool would expect absolute perfection...
Squaring on is well known within the astronomical community since the early days of telescopes. Lots of ingenious ideas even in the early litterature.
View: original size
Samuel Chia
Most likely the real world results are good enough for 99.9 % of the users. This seems more like an issue, not to geeks, but to geeky geeks. I might be wrong, but then I am stuck in a real world life where nothing is perfect - most things are just good enough.
OP SamuelChia New Member • Posts: 9
Thanks for your thoughts. It seems you didn't read through the article, and so you have wrongly assumed several things, like whether I'm aware or not of the specifications, and you also assumed I'm complaining, which I'm not. I'm providing solutions. There's not a single complaint in my article, only the sharing of limitations and facts.
I've given away, scot-free, 4 years of combined work with some of the best minds in the industry, to solve this problem and provided the solutions with caveats to any who wishes to straighten out their equipment. A number of people have since reached out to me and were delighted thereafter, finally able to enjoy the full performance of their fine instruments which they have paid so dearly for with hard-earned money.
As I wrote in the introduction, there are those for whom such precision is unnecessary, such as Instagrammers who don't care about making large, finely crafted prints. For those, don't waste your time here.
grateful Junior Member • Posts: 25
The link takes me to a “server is down“ error message on that web page. Is there another way for me to access this article? I would be so grateful for your help. Many thanks, Mark
In my opinion this is a non case. Tilted image sensors can be found but almost all of them are mounted within spec.
What I would worry more about is the lens or telescope. Astigmatism, coma and field curvature are much more real life concerns for astrophotographers (get the right lens).
Telescope optics and adapters happen to be tilted. Aligning and sqaring on the telescope is commonly needed and that can even compensate for a tilted image sensor (which is a very rare incident). Just get an adjustable adapter.
Why chase mice when the elephants are battering the room?
From the response tilted image sensors seems to be a non issue to the crowd here (if measuring fine enough tolerances everything is out of adjustment).
Better worry about what usually cause problems than what might appear once in a blue moon - if out of luck.
