Question on using a FF lens in crop mode on A7RIV
lovehifi Contributing Member • Posts: 733
When using a FF lens on the an A7RIV in crop mode do you also multiply the aperture by 1.6? Example would a 85mm 1.8 FF lens in crop mode now give me a focal range and aperture of 136mm 2.8?
 lovehifi's gear list:lovehifi's gear list
Sony a7C
jst13 Regular Member • Posts: 257
Re: Question on using a FF lens in crop mode on A7RIV
1.5 is the factor..but yes you are right
 jst13's gear list:jst13's gear list
Sony RX100 VI Leica Q2 Fujifilm X100V Panasonic Lumix DMC-GM5 Sony a7 III +14 more
Brian_Smith
Brian_Smith Veteran Member • Posts: 3,338
8
The aperture of a full frame lens remains the same in crop mode.
 Brian_Smith's gear list:Brian_Smith's gear list
Sony a7R IV Sony a9 Sony FE 24-70mm F2.8 GM Sony FE 16-35mm F2.8 Sony FE 24mm F1.4 GM +4 more
OP lovehifi Contributing Member • Posts: 733
Thanks.
Sony a7C
noel2 Senior Member • Posts: 1,095
Absolutely.
Aperture is focal length divided by diameter of the entrance pupil. It is independant of the sensor size.
 noel2's gear list:noel2's gear list
Pentax K-5 IIs Pentax K-1 Sony a7R III Sigma 18-250mm F3.5-6.3 DC Macro OS HSM Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +24 more
EarthQuake Veteran Member • Posts: 3,074
6
For exposure, ie: light gathered per mm^2, yes it will always be 1.8.
For total-light-gathering, it will effectively act as a 127/2.8. It will produce the same DOF as an 127/2.8, and similar levels of noise if you were to shoot at 2.8 rather than 1.8.
JamminHyaku
JamminHyaku Regular Member • Posts: 379
As others have said, the answer is yes and no. The sensor is still receiving the same amount of light, as the lens hasn't changed, its just that since the sensor itself is limiting itself to a crop frame size, it is not actually using all of that light.
Using crop mode is the same as using an APS-C sensor camera, the big difference is the MP. On an A7R series camera, you are still left with 20 some MP, but on an A7iii for example, it is closer to 10 some MP. Which may be fine for shots, but would restrict you from cropping in basically whatsoever.
 JamminHyaku's gear list:JamminHyaku's gear list
Sony a7R II Sony FE 70-300mm F4.5-5.6 G OSS Samyang AF 14mm F2.8 FE Sony FE 28-70mm F3.5-5.6 OSS Sony FE 50mm F1.8 +7 more
PWPhotography Forum Pro • Posts: 10,750
No, physically but has APS-C 1.5x crop on FF equivalency,
https://www.dpreview.com/articles/2666934640/what-is-equivalence-and-why-should-i-care
https://www.dpreview.com/learn/2799100497/equivalence-in-a-nutshell
Not only you have 1.5x FL equivalency but also 1.5x aperture equivalency in IQ. F1.8 FF lens in APS-C crop mode is eq to F2.7 (roughly f2.8) on FF in these areas - DOF, total light collection that deteriorates entire IQ department to an APS-C sensor level - resolution/sharpness (down to 26mp), DR (similar to A6xxx sensors), SNR (shadow area will have more noise after pushing up), high ISO.
https://www.photonstophotos.net/Charts/PDR.htm#Sony%20ILCE-6600,Sony%20ILCE-7RM4,Sony%20ILCE-7RM4(APS-C)
You gain in effective FL 'reach' but lose in IQ, no free lunch.
 PWPhotography's gear list:PWPhotography's gear list
Canon EOS-1D Mark III Sony a9 Sony a7R III Sony a7R IV Canon TS-E 17mm f/4L +18 more
SQLGuy Veteran Member • Posts: 9,657
A couple of other ways to think about it:
1. A bit over simplistic, but crop mode is very much like using a 1.5X teleconverter. A 1.4X TC adds 40% to the focal length, and drops one stop (1.4 X the lens' rating).
2. F stop is the ratio of the lens' effective diameter to its focal length. Cropping, or a teleconverter, increases the focal length, but doesn't make the front element any bigger, so the calculated F stop obviously increases by the crop factor as well.
For instance, a 100mm F2 lens will have an effective diameter of 50mm. E.g. the Canon 100/2 USM takes 58mm filters and probably has about a 56mm front element... there being some losses along the way in getting to 50mm effective diameter. Putting that lens on a 1.5X TC, or using it in 1.5X crop mode, will make it act like a 150mm lens. 100/50 = F2.0. 150/50 = F3.0.
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Nikon D200 NEX-5T Sony a7R II +24 more
Trollmannx Veteran Member • Posts: 6,808
Do not quite agree as the lens does NOT change and remain unaltered despite whatever is put behind the lens. Any 1.8/85mm lens is still a 1.8/85mm lens.
Putting a 1.4x teleconverter behind the lens will extend the physical focal lenght. The physical aperture will remain, but obviously the f/number will change.
When cropping an FF camera to APS-C format the field of view becomes more narrow, and that is where the added 1.5x tele effect comes in.
The lens does not change. The light density does not change. The plate scale does not change. Only the field of view change when using a larger or smaller image sensor, simply because the area of the image sensor differ.
And obviously the larger FF image sensor can collect light falling outside the APS-C format. That is where the confusing "collects more light" comes into play.
The equivalence part (which can be sound) is often expressed in confusing ways and surrounded by lots of equivalencenonsense...
+1
+1
Thanks everyone. I was figuring it was x 1.6 instead of 1.5 because in crop mode the A7RIV is 26 megapixel. Thanks for all your thoughts and answers. I picked up a 85mm 1.8 and was trying to figure out what the focal range and aperture would be in crop mode. My take away is that the lens and its specs do not change but the amount of the FF sensor being used does.
Sony a7C
It's not confusing but FF sensor does collect more total light. The light density in per square mm is the same. But FF sensor is much bigger therefore collects more total light. If you compare between F1.8 FF and F1.8 APS-C lenses, you will see F1.8 FF lens opens hole (diameter) bigger on the same aperture and shutter. Believe the same FF f1.8 lens open the hole or diameter less under APS-C mode than under FF mode in the same aperture/shutter.
The larger FF sensor collects more total light and then projects to the same output size with less pixel magnification (or enlargement). Really no confusing here in equivalency.
Just imagine an old projector.  The larger film (sensor), the less enlarged after lens (glass) projecting to a big curtain (final image), better quality.   Really the sensor format is directly related to pixel enlargement.  Larger sensor -> less pixel enlargement -> better IQ, not that difficult to understand.
+1
+1
