Dumb question: on the S1, how do i turn off image stabiliser?
doubleclick Forum Member • Posts: 69
I can't figure out how to turn off in body stabilization.
I can find  the setting for auto and panning.
Panasonic S1
LuxShots
LuxShots Regular Member • Posts: 484
Re: Dumb question: on the S1, how do i turn off image stabiliser?
I don't believe it can be truly turned off. Here is a page from my S1H manual, and I'm certain the S1 is similar.
 LuxShots's gear list:LuxShots's gear list
Panasonic Lumix DC-S1H Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix DC-S5 Sigma 12-24mm F4.5-5.6 EX DG Aspherical HSM Canon EF 50mm F1.8 STM +9 more
OP doubleclick Forum Member • Posts: 69
I think the S1 manual gives similar information.
I thought I had to turn it off when on a tripod.
Or does it automatically recognise when the camera is mounted on a tripod and turn itself off?
richgb New Member • Posts: 15
You can turn off the lens IS but you can't turn off the body IS.
AFAIK, there's no way to tell the camera it's mounted on a tripod.
Off The Mark Senior Member • Posts: 3,991
As far as I can tell, if you want to turn off ALL stabilization, and you are using a Panasonic lens with stabilization, then turn the stabilization off on the lens. That should turn off ALL stabilization. (I get the Red Hand icon in the upper right hand corner.)
Same deal if you are using a Canon lens with Stabilization on the MC-21. Turn the stabilization switch on the lens to off. (I have no idea what happens if you are using a canon lens without lens stabilization on the MC-21 adapter though.)
If you are using a manual focus lens on a dumb adapter (like my Minolta MD manual focus lenses on cheap adapters), then in the camera menu under image stabilization, in the mode sub menu you get the option to turn it off.
Also, I don't know whether a panasonic lens without lens stabilization (like the 20-60mm lens) will behave. I don't know whether you will get the option in the stabilization menu to turn off stabilization or not.
Hope this helps.
What Middle School Is Really Like:
https://youtu.be/Q1Xtz5EqMuo
 Off The Mark's gear list:Off The Mark's gear list
Sony a6000 Sony a5100 Sony a6300 Sony a6500 Sony DT 18-55mm F3.5-5.6 SAM +7 more
Thomas Mottl Veteran Member • Posts: 3,626
How to
In Stabilizer Menu go to "Operation Mode"
In the upcoming Menu you have three choices Normal, Panning and Off
Choose OFF and the IBIS is OFF
It will be overide when you are using a L-mount lens with OIS, when you turn it on on the lens the IBIS will be activated.
When you cahnge lens to one without OIS the IBIS will be off again until you activate it again.
 Thomas Mottl's gear list:Thomas Mottl's gear list
Sigma DP1 Sigma SD9 Sigma SD10 Sigma SD14 Sigma SD15 +21 more
Thankyou,
I thought maybe i had missed the setting somewhere.
I kept on looking in the manual and searching online.
I can relax now ūü§£ and enjoy the camera.
With the sigma 24-70 DG DN , which doesnt have lens stabilisation, i have the option to turn it off in the menu.
The panasonic 70-200 f4, doesnt have the OFF option. I switch it off on the lens.
Thanks for the help everyone.
I was looking for the OFF option when i had my panasonic 70-200 attached. I now know to use the lens to switch off the stabilisation.
When using my sigma DG DN 24-70 I can access it in the menus.
At this stage i only have the two lenses for my S1
Barugon Veteran Member • Posts: 8,920
What is "auto".
What is "auto".
The "auto" mode of IBIS "detects panning directions automatically" when you are panning the camera and will NOT add stabilization that contradicts the panning motion.
At least, that is the theory of Auto mode.
LuxShots
Off The Mark wrote:
What is "auto".
I will attest that it works great.
Panning with the S1H and 24-105 f/4
LuxShots wrote:
Off The Mark wrote:
What is "auto".
Thanks for sharing your experience, and good to hear it works well.
I need to play around with it because there are times when using my S1 on my gimbal (Zhiyun Weebill S) and it sometimes seems like the stabilization is fighting me.
BTW: Nice shot. Reminds me of my days back in the early 90's when I used to shoot motorcycle races for a couple of local newspapers / magazines.
frankho New Member • Posts: 14
... Additionally you can put the stabilizer in the Q-quick menu, then the way is not so far.
Regards
Frank
