Do you let lens always mounted on the camera, or not?
Started Sep 19, 2020 | Polls
Kodachromelover Junior Member • Posts: 37
I wonder how many of us keep or do not keep the lens mounted on the camera when we do not use the camera for a long time (but… how long?).
My E-M1 Mk III always rests on the Oly 12-100/4, while the Oly 9-18 rests on the E-P5 which does not have an eyepiece. I do so to distribute the weight evenly all around the mount.
What do you do?
 Kodachromelover's gear list:Kodachromelover's gear list
Olympus PEN E-P5 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +1 more
POLL
Ever mounted
83.8% 98  votes
Sometimes mounted
10.3% 12  votes
Sometimes not mounted
2.6% 3  votes
Never mounted
3.4% 4  votes
  Show results
Olympus E-M1 Olympus PEN E-P5
C Sean Veteran Member • Posts: 3,423
Re: Do you let lens always mounted on the camera, or not?
Usually a prime on the GX80 and the 100-400 on the Gh5.
Royd63uk
Royd63uk Regular Member • Posts: 300
Yes I do
Chuck_G Regular Member • Posts: 184
I nearly always keep a lens mounted in case I see something I want to grab a quick shot of. Which lens depends on which camera. For my G85, I keep the 12-60 kit lens mounted as it has a good range and is reasonably sharp and very lightweight. For my 2 Sony cameras, there are no lenses currently mounted.
 Chuck_G's gear list:Chuck_G's gear list
Sony Alpha DSLR-A300 Sony SLT-A77 Panasonic G85 Sony DT 18-70mm F3.5-5.6 Tamron 18-270mm F3.5-6.3 Di II PZD +3 more
linux99 Senior Member • Posts: 2,151
Always either a lens or a body cap......
You want one or the other.
Don't ever leave the open body cavity exposed - dust is one of the worst enemies of Digital Cameras.
Use either a lens (like I do) or a body cap.
 linux99's gear list:linux99's gear list
Sigma DP2x Canon PowerShot S100 Sigma DP3 Merrill Nikon Coolpix A Fujifilm X100T +19 more
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Looks like I am a minority of one.  I have too many lenses to choose from, so normally I just grab a camera body and a lens and make it work.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
IronWolf New Member • Posts: 4
I typically leave a lens mounted all the time to my cameras. Usually a prime on GX85 that gets swapped out for certain situations (i.e. to a telephoto Zoom for my daughter's volleyball games, etc).
I also have two DSLRs that I keep the lenses attached to - that's more because for paid shoots I tend to have two bodies, one with a 24-70 and the other with a 70-200 so I don't have to swap lenses, I can just grab the other camera.
I do have an older DSLR that currently doesn't have a lens attached. It isn't used much, so I just store it with no lens attached.
 IronWolf's gear list:IronWolf's gear list
Panasonic Lumix DMC-GX85
Re: Always either a lens or a body cap......
Oh yeah - even for my bodies without a lens, they always have the body cap on. Good point.
Shoot - I just get nervous when i see people posting things to Craiglist without a body cap!
dooler233 New Member • Posts: 1
Once the exchange is complete, mount the new lens to the camera, place ... The lens case should always be locked by at least one latch (though I ... The 1st AC should not let go of the lens in your hand until you say “I got it.
The model of your camera is important to knowing what lenses you should ... There are some Canon lenses that simply will not work at all on certain Canon cameras! ... When you mount a lens that is built for a 35mm size and stick it against a ... Let's say you want to use a Nikon 16-35mm lens on a Nikon crop sensor DSLR:. Here
skysurfer5
skysurfer5 Senior Member • Posts: 1,125
I always keep a lens mounted to my camera because (1) it fits my bag better than if the body and lens were separate and (2) that way the camera is ready to go when I pull it out.
With my E-M1iii and the way I have configured the inside of the bag (an older LowePro Flipside 300), it's the 12-40 that is always mounted. When I used the same bag with my E-5, it was configured differently and everything fit better when the 50-200 mounted to the camera.
'Is it the only lesson of history that mankind is unteachable?'
…Winston S. Churchill
 skysurfer5's gear list:skysurfer5's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +20 more
Impulses Forum Pro • Posts: 10,039
I'm not sure whether people read the OP or not, several of the comments are about how they carry lenses in a bag when the OP is asking about what they do when the camera goes unused for a long time, unless I'm misinterpreting...
Anyway, in a bag I almost always keep a lens mounted, the only exception to that might be when I put my E-M5 into a very small bag where it'll only fit with a pancake mounted but I still throw a prime or two in a wrap underneath it... In that case I might stow it at times with just the body cap, the same will likely be true of my A7R IV for which I'm not getting any pancakes.
As far as storing it at home goes tho, I always take lenses off and put them in pouches alongside the camera that's covered by a protective wrap, and I keep it all in plastic bins with Eva-Dry desiccant boxes in them. What I grab for any given day can be pretty dynamic anyway, so it seems more useful to first pick the bag I'm gonna bring (from a separate bags bin) and then grab the lenses & body.
Always use body caps tho, I've actually got a spare in my larger bag just in case. I usually keep rear lens caps attached to that spare body cap in the bag.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
Yes
Yes, even the body cap is a lens.
If the body has a battery with a charge, there is a lens present "at the ready".
Why would anyone leave a camera unable to make a shot ?
I'm not a perfectionist, I'm a precisionist.
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 8-18mm F2.8-4 +17 more
Sergey Borachev Veteran Member • Posts: 5,338
I don't understand the question. Are you worried about some kind of damage?  Not me.  The last lens used is the one left on the camera, although I always have the 12-40mm mounted on one of the cameras.
alcelc
alcelc Forum Pro • Posts: 19,006
No reason not to.
Back to the old days (40+ years) when I did not use auto dry cabinet, for not immediate used cameras and lenses, I used airtight food bags plus silica gel to store them for the wet region I lived. Because whenever if I picked out a piece of lens or body I had to open the airtight bags, that had let the atmospheric humidity came in. Therefore I unmounted lens from the body, put on their lens/body caps, stored them separately each in their own airtight bag surrounded by silica gel. These bags of gear then collectively stored inside large size airtight box with more silica gel. I could keep the unused gear untouch so those less used gear inside their individual bags basically could remain dry for years.
I brought my auto dry cabinet 4 years ago. No more airtight bag and no more silica gel. No reason for me to store lens and camera body separately. It means every camera (not actively uses) has a lens mounted on for at least 4 years already. Likely it would be remained for the many years to come...
Albert
** Please feel free to download the original image I posted here and edit it as you like **
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,218
Re: Yes
I would disagree that a body cap is a lens, because it contradicts your last point - why would anyone leave a camera unable to make a shot?
The lens I leave on a camera may not be the most likely one I'll need for my next opportunity, but it stays on the camera regardless.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
Henry Richardson Forum Pro • Posts: 21,959
Kodachromelover: I suppose you love the Kodachrome look :-)
Most of the time I leave the lens on my camera.
Kodachrome is gone so, as far as I know, it is no longer possible to shoot Kodachrome film. Of course, there must still be unused rolls of Kodachrome in freezers around the world but, I think, there is no labs that still process it. I have about 30 rolls of various 35mm and 120 film that I bought in the 1990s in a freezer back in the States and there may even be a roll or two of Kodachrome too. Just for fun awhile back I started a thread about getting sort of a Kodachrome 25 look with digital camera raw files. I started a thread:
Kodachrome 25 profile for Lightroom (free)
https://www.dpreview.com/forums/post/64071862
Here is the pseudo Kodachrome 25 preset:
https://www.dpreview.com/forums/post/64078519
And some example photos using it:
https://www.dpreview.com/forums/post/64079655
https://www.dpreview.com/forums/post/64081892
https://www.dpreview.com/forums/post/64094312
Henry Richardson
http://www.bakubo.com
OP Kodachromelover Junior Member • Posts: 37
Re: Kodachromelover: I suppose you love the Kodachrome look :-)
Thanks, Henry!
I'll try your suggestions for a Kodachrome look. Your photos are outstanding.
Lelio
Thanks, Henry!
Lelio
Lelio, thank you.  It is something for you to play with.  Let us know if you make any improvements to the preset.
Henry Richardson
n3eg
n3eg Veteran Member • Posts: 3,316
But do you always have a camera mounted on your lens?
I'm not nearsighted. My eyes just have good bokeh.
It ain't easy being me, but someone's gotta do it.
4/3 system user since 1981.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
RedDog Steve
Re: Yes
Mediocre at best, but this body cap does indeed produce an image.
9mm f/8 fisheye "bodycap"
I sometimes do in-camera post processing (as above). During those times I prefer to leave a small lightweight lens such as the 14mm f/2.5 or the bodycap fisheye attached for convenience of handling.
rd
