Re: Tack sharp, don't buy it for bokeh
kkkk wrote:
march hare wrote:
The reason why I use a m43 sensor camera for my work is the OOF transition as it is a lot more subtle than on a FF sensor. Most of the work I do is about telling a story about fauna so I shoot from semi macro to wide hence the 12-45 is ideal.
As for the 17mm it is heavy and quite large so it is a lot more practical to use the panaleica 25mm f1.4 as in order to get those other images. There is a lot of hiking and scrambling over rocks, fighting dense undergrowth involved in getting the photos, plus I am no longer a spring chicken and march hares have small pockets.
OOF transition is probably my most used tool in telling a story
I am curious about your comment regarding OOF transition. I was always under the impression, without having proof for it, that a "FF" sensor should have an advantage in this respect in parallel with its inherently better dof control? To take the argument further I always found, when looking at images taken with MF or LF sensor cameras, that what stands out is exactly superior OOF transition.
Can you post one of your images that shows good OOF transition?
It's not about producing a single image but a series of images I don't chase complete isolation
eg a gum nut on relation to a juvenile leaf, a mature leaf, new stem growth etc etc. I will shoot within the same space with about a dozen different focus points using f4 and f8 along with 30mm, 55mm and 70mm focal lengths depending on the distance between each point needed to be emphasized
It is a process that ends up with about 5 to 10 images that are viewed as one it's a system works for what I need to do.
I used to use a Fuji but there was too much DOF in some transitions it never worked with FF. Since I got the Oly 12-45 it is a breeze it seems like it was tailor made just for me;-)
No images to show as they are not mine to show as they are owned various universities I work for my other stuff is very different mainly film
