Anybody using the R5 Clarity adjustment?
poppyjk
poppyjk Contributing Member • Posts: 892
I have been trying to maximize in camera jpg image quality/sharpness while using the EF 100-400 v2 on the R5 with 1.4X and 2X TC.
Today I added +2 Clarity and like it in addition to Fine Detail Picture Style at default; Peripheral illum corr - ON, Distortion correction - ON, Digital Lens Optimizer - Standard; Auto Lighting Optimizer - Standard.
Interested in hearing other peoples' settings with TC's on the EF 100-400 v2 or with TC's in general.
"Well done is better than well said" - Benjamin Franklin
You have my express consent to edit any of my images that I post on DPR.
 poppyjk's gear list:poppyjk's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 35mm F1.4L II USM +5 more
Canon EOS R5
Amir Menahem Forum Member • Posts: 59
Re: Anybody using the R5 Clarity adjustment?
The clarity effects the raw files?
my Instagram @amir_menahem_
 Amir Menahem's gear list:Amir Menahem's gear list
Canon EOS R Canon EF 50mm f/1.2L USM Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon TS-E 90mm F2.8L Macro +1 more
Chris Jacobs
Chris Jacobs Regular Member • Posts: 400
If you open raw files in DPP you will see the same settings as applied in camera.
I've been having good results with Clarity +1 and Saturation +1 in camera in Standard Profile.
I wish I could add clarity in DPP to my older raw files.
 Chris Jacobs's gear list:Chris Jacobs's gear list
Canon EOS 50D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS 90D Canon EOS R5 +4 more
Zeee Forum Pro • Posts: 21,949
I don't do any in camera settings because it can low it down.
Another one bites the dust. I feel even more confident that soon things will have a wonderful conclusion
 Zeee's gear list:Zeee's gear list
Canon EOS R Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
poppyjk
OP poppyjk Contributing Member • Posts: 892
Actual burst length with my JPG settings
When recording RAW + large fine JPG to the CFExpress card with the settings I listed and H+ 12fps I get 133 shots before the camera slows. The manual lists 160 shots as the theoretical maximum.
With recording separately RAW to CFExpress and large fine JPG to SD UHS II with the settings I listed and drive mode set to H+12fps, I get 92 shots before the camera slows.
Recording large fine JPG's only with my settings to the SD UHS II I got 354 shots at H+ 12fps before the camera slowed. The Manual says to expect 190 shots in the burst of large fine JPG's to a SD card. I suppose the Manual was referring to SD UHS I performance.
I don't see the problem of the processor being slowed down with my JPG settings. So I won't worry about it versus the clear advantage of the comprehensive in camera JPG processing.
Canon has put a magnificent processor in the R5.
Adam2 Veteran Member • Posts: 6,982
What’s the point when shooting RAW?  None that I see as the clarity is added in post and that can be accomplished with any PP software.
Re: Actual burst length with my JPG settings
I can hardly wait to get mine. Should be within 10 days. Good info however I don’t use DPP so it doesn’t really matter. If I did I’d probably still do it all in DPP but that is just me.
I always use DPP to cull before importing to LR. I noticed that even if NR is turned off in camera DPP applies it.
Chris Jacobs
Saves me a step in processing later.
Also, if I transfer from my camera to phone the images are already slightly processed which is nice. I don't think you can process them in camera after it's taken.
stevvi Contributing Member • Posts: 720
You can process RAW in camera to jpeg or heif, clarity included if you so wish. "Play" menu, tab 3.
 stevvi's gear list:stevvi's gear list
Canon EOS R Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 24-105mm F4L IS USM +2 more
Confusing!
Confusing!
What part? I don't use DPP to edit so applying in camera settings like Clarity does not matter as LR won't recognize them.
I do use DPP to pre-edit or cull. Whatever you want to call it. I use Quick Check - Full Screen. The reason is DPP's downsizing algorithm for 'fit to screen' display is very good and contrasty which creates the illusion of sharpness. Here I delete unwanted and unusable files. When done then I import into LR.
I have in Camera NR (high ISO and long exposure) set to off. When I open a file in DPP basic NR is applied because I set up that way in the preferences. I could shut it off in the preferences but it wouldn't matter because basic NR is applied automatically, in the RAW Data and we can't control that. Unless I'm missing something we can't shut NR off completely in the camera.
Confusing!
It was confusing that, in one paragraph, you state you don't use DPP and then in the next you state you do use DPP. Now you've clarified that you use DPP as an image (pre)viewer and not an editor, it makes sense.
Confusing!
I see. Sorry about that.
souvikdgp Regular Member • Posts: 183
I own R6 and I applied clarity +2 in DPP in couple of occasions. But images were too saturated to my linking. So have stopped using it. May be R5 has better results with clarity settings.
 souvikdgp's gear list:souvikdgp's gear list
Canon EOS RP Canon EOS R6 Canon EF 50mm F1.8 II Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM +5 more
