Closeup Photography Using the Panasonic 3D1
Started Sep 16, 2020 | Discussions
threed123
threed123 Senior Member • Posts: 1,490
Not quite Macro, but close. I was reading about how others are using close-up lenses with the Panasonic Lumix 3D1 (note--added after posting original-not the 3D1aparently after reading some more--apparently, they are using linked Lumix mirrorless--oh well) and decided to just tinker with it using the camera the way it is. It has very good focus close up--even within a couple of inches. So off I went into the backyard. It was a windy day, but the camera did very well. I post-process all the shots in Stereomaker, using some techniques to adjust the separation and crop the image to a more macro level. Also did a little sharpening and some alignment and color level adjustments.
These are crosseyed to the left and straight on to the right. I've taken hundreds of 3D pics with this camera and it always amazes me how good they are with very reasonable depth.
Lumix 3D1 - Bumblebee 1
Lumix 3D1 - Bumblebee 2
Lumix 3D1 - Bumblebee 3 - flying
Lumix 3D1 - Butterfly - A lot of eye confusion with the fence-railing. The detail is great, though.
Lumix 3D1 - Spider - about 3/8" long. Shot about 2" away, and cropped.
Lumix 3D1 - Tree Frog - about 1.5" long. In 3D, it really comes alive.
Lumix 3D1 - Flower
Panasonic Lumix DMC-3D1
Tourlou Senior Member • Posts: 1,046
Re: Closeup Photography Using the Panasonic 3D1
Thanks for sharing.  Having two lenses on the same camera opens possibilities I don't have.  I always shoot 2 separate pictures, so, subject has to be pretty static.  Shooting 2 pictures allows you to change the distance between the 2 shots though, which is a huge advantage whan shooting distant things.
Regards.
Ron
tony brown Veteran Member • Posts: 4,387
Very impressive, clean and precise images for such close-ups.
Would like to try this camera as I am currently using Cha-Cha for everything but, looking on E-Bay, the used ones are still VERY expensive, e.g. 1,000 US$.
Cheers, Tony.
threed123
OP threed123 Senior Member • Posts: 1,490
I know they are ridiculously expensive used. I bought a second one for $500 and thought I was getting a bargain. That camera was given to my son he took pics all over Europe and everyone turned out great.
