My lens got some "bubble" inside
John31000 New Member • Posts: 15
Hello everyone
I've bought a lens refurbished like one years ago. I was very new to photography, now I've noticed that there are some bubble inside the lens very very small.
Do you know what is it ? If I can repair it ?
I've never had any problem taking picture with the lens. The quality is good.
Here 2 pictures, maybe if you can tell me if it's normal
Micro bubble inside my panasonic 14-140
Picture taken with this lens at 14mm :
JPG , 800 iso , 14mm f3.5
I wanted to sell this lens. Do you think I should sell at a low price ?
Thanks you
bclaff Forum Pro • Posts: 11,659
Re: My lens got some "bubble" inside
John31000 wrote:
Hello everyone
Do you know what is it ? ...
I don't see anything except dust and reflections
But a tiny defect is unlikely to affect image quality so I wouldn't worry about it.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
FrancoD Forum Pro • Posts: 14,704
I made it a bit more obvious
it is a common problem with a somewhat similar Sony lens.
Most think is fungus, I think that is some type of balsam separation because it happens between cemented elements and it is spread around evenly. Fungus grows at random . The Sony replacement cost for thse two elements is around $250, I have no idea of what Panasonic would charge for it but probably not much less.
BTW, IF it is what I think it is, it can't be cleaned.
This is a photo of the Sony lens , posted in the Sony A forum.
You should be able to see the similar pattern. Some think that it is cause by leaving the lens in the sun . Could be right..
(in the old film day was simply the balsam failing but the separation was a lot more obvious than that)
Aoi Usagi Senior Member • Posts: 2,595
John31000 wrote:
Hello everyone
Separation. The front doublet is starting to separate from each other. This is actually a defect in the optical adhesive, and is quite common with budget lenses. The Sony E 55-210mm comes to mind. There is no way to economically repair it.
It will most likely get worse over time. Once fully separated, there will be an air gap that was not accounted for in the design of the lens. This added air gap might cause low contrast, flare, and overall image degradation. I would keep using it until you see issues in the picture.
Thanks you
Formally Evogt500
Dana F Regular Member • Posts: 163
Go to this link........https://www.mu-43.com/threads/weird-crystals-in-panasonic-14-140mm-f-3-5-5-6-ii.97402/
Several cases of where it's happening. Good Luck.
 Dana F's gear list:Dana F's gear list
Pentax *ist D Olympus PEN E-PL6 Sigma sd Quattro Pentax KP Olympus OM-D E-M10 III +3 more
