Lumix G7 Too bright
Started Sep 14, 2020 | Discussions
Sparkio83 New Member • Posts: 6
Lumix G7 Too bright
I have a Lumix G7 which is great for what I use it for (I'm a very basic photographer). I tend to always have it on the auto focus Ai mode for photos.
However i have noticed that lots of times I use it (particularly indoors) the photos and video are very white looking. They look almost bleached. Is there a setting somewhere that can help to make the photos and video look a bit more in contrast or is it just a very bright camera?
Panasonic Lumix DMC-G7
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Re: Lumix G7 Too bright
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
JosephScha Veteran Member • Posts: 7,249
I used to have a G7 and did not experience this.  Are you using the auto everything mode, that sets ISO, shutter speed and aperture?  If so, you almost certainly could avoid this in P mode where you set an appropriate ISO to keep your shutter speed where you need it to be.  Do you have exposure compensation (+/-) set above 0?   If so, please set it back to 0.
I can't really think of anything more.  Can you please post a picture showing the issue?  We might be able to recognize something.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
alcelc
alcelc Forum Pro • Posts: 19,006
Use iA+ & EC
You might wish to use iA+ instead of iA as the following:
https://www.dpreview.com/forums/post/64349653
Albert
** Please feel free to download the original image I posted here and edit it as you like **
rashid7
rashid7 Veteran Member • Posts: 7,011
YOU DO KNOW HOW TO ADJUST EXPOSURE? (EVCompensation)
Keep it fun!
pannumon Veteran Member • Posts: 4,130
Check that metering is set to "multi metering" or "center weighed" instead of "spot". I have assigned the fn3 (down button) for changing the metering mode. It may be that the setting does nothing when using full automatic mode, though.
I strongly recommend spending an hour or two of learning what aperture, shutter speed and sensitivity (ISO) means and how they are related, as well as different focusing and metering modes. This will help understanding what are the possible reasons for the camera to fail.
Learning how the camera works is not obligatory, but it is a relatively easy way to take your photography to a next level. It's also a lot of fun testing different exposure parameter combinations when trying to perfect an image.
G7 is a great camera, after using G80, I am amazed how light it is.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Too bright
stay away from IA for a while, you figure some way to get an image try to see what you like on that dial.
IA tries to get things bright, but may blur out a subject.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
