Some selected by DP Merrill (1-2-3)
Started Sep 14, 2020 | Photos
butfly
butfly Forum Member • Posts: 85
6
Maybe it's the most favorated camera for me.
that all knowledge was but remembrance,
and that all novelty is but oblivion.
 butfly's gear list:butfly's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sony Alpha NEX-7 Nikon 1 V3 +19 more
Comment & critique:
D Cox Forum Pro • Posts: 32,979
Re: Some selected by DP Merrill (1-2-3)
I like these, especially the first one with all the little tiny people.
The DP Merrills are wonderful cameras. I don't think you posted anything from a DP1M ?
Sigma fp
jande9
jande9 Senior Member • Posts: 1,707
Beautiful pictures.
You do a lot of exposure comp, and very successfully too.  How do you keep from blowing highlights?
jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
butfly
OP butfly Forum Member • Posts: 85
I always take the three toys in my bag together on travel, and pick one up based on the scene arbitrarily. In recent years I find myself like to the mid-focus like 60-150 more and more than youth
butfly
Basically I'm used to set the +0.3/0.7 ev as default custom setting for dp series. But for scenery of hard light or strong contrast I will increase/decrease it violently based on live view on the LCD :D.
jande9 wrote:
Beautiful pictures.
jan
butfly
After uploading some photos yesterday by phone (mobile web), I found these photos looks like lossing their crispness. Can anybody tell me how can I upload the photos with original quality, or embedded external photos?
Some of my photos can be found at flickr: https://www.flickr.com/people/butfly/
SigmaChrome Forum Pro • Posts: 15,728
Lovely work butfly.
I often take my DPMs - 2 and 3 - on walks. They keep my mind well focused and give me excellent results.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
The versions in the threads are greatly compressed, but the "original size" versions are not so bad. I just upload the full size DP3M image, saved as a maximum quality JPG.
I downscale the images from the sdQH and the fp, so as not to overload everyone's bandwidth. This does lose some detail.
Sigma fp
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
I also get good results from using 100% quality (least compression) but full chroma sub-sampling (4:2:0) ... (in FastStone Viewer - we can't separate compression and sub-sampling in SPP).
Good man ... at 75Kb/sec, I do appreciate that.
For my pre-Merrill SD15 I leave images at 100% ( i.e. less than or equal to 2640x1760px).
There are more ways than one to skin a cat ...
Seba Smith - The Money Diggers, 1840
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
butfly
So how can I upload photos to the dpreview without compressed by the website?
Shoukd I resize all photo to smaller than 2640x1760 before upload?
Can I embed some external images by url in thread of the dpreview forum?
I'm freshman here with only few posts here, thanks for any suggestion.
I see that you downsized your picture of the sand dunes to 7 Megapixels. It looks sharp and detailed on my monitor. You might try, as a test, posting the same image at full size, to see if any more important detail can be seen.
The others have been reduced more, but as they are mostly fairly simple graphic images, where the composition is more important than very small detail, I think they work OK. But you could try posting a couple of larger versions.
Your logo (or seal) is interesting. What does it represent ?
Sigma fp
xpatUSA
The compression that Don referred to is only in the small post view, not the original size view. You can not control the post view - it is re-sized by DPR.
Should I resize all photo to smaller than 2640x1760 before upload?
No. You can use any size you want to. 2640x1760px is just the biggest image my Sigma camera can capture.
Yes. Click on the 'Insert Image' icon and then select 'Insert image from web'.
Ted
butfly
looks like the below is not correct. in the top post of these thread i insert some Image from website and others from local, but they were compressed all, and i had checked the html code -- the dpreview insert Image from itself, not external.
butfly
let me try again for uploading them onto the dpreview gallery first and insert into thread from gallery.
All looking good here.
Sigma fp
xpatUSA
butfly wrote:
xpatUSA wrote:
looks like the below is not correct. in the top post of this thread i inserted some Images from a website and others from my computer, but they were all compressed, and i had checked the html code -- DPReview inserts Images from it's own Server, not external.
Please do not change the order of quotes by adding text above mine. For example, see that the above is out of sequence.
'insert image from web' places the image in the post view compressed or expanded as required.
From my website:
Click on 'original size' to see it full-size in a new window.
If you don't like that, you can just type the URL into your post:
http://kronometric.org/phot/sensor/fov/F7QEinclFilt.gif
Members will then have to click on it to see it.
Ted
