Can an Ra be used for infra-red landscape photography?
Started Sep 13, 2020 | Discussions
Barry Pearson
Barry Pearson Veteran Member • Posts: 9,625
I'll start by quoting Canon about the Ra:
"Because it is designed for astrophotography, shooting normal subjects is not recommended. Subjects may appear redder than they actually are, and may not be able to obtain appropriate color balance when shooting normal subjects."
I've previously had a Pentax K-7 camera converted for infra-red by having the IR filter removed. Then I've used a filter to block as much visible light as possible. Using a tripod and long exposures.
In other words, I'm not talking about "appropriate color balance when shooting normal subjects". I'm talking about exploring subjects (typically landscapes) in the IR part of the spectrum. Often converted to monochrome.
(This is speculation at the moment. I have an R and I've pre-ordered an R5.
I certainly couldn't afford an Ra at the moment!)
 Barry Pearson's gear list:Barry Pearson's gear list
Ricoh GR III Canon EOS R5 Canon EOS R7 Canon EF 8-15mm f/4L Fisheye USM Canon EF-S 10-18mm F4.5–5.6 IS STM +28 more
Canon EOS R Canon EOS R5 Canon EOS Ra Pentax K-7
klausd Forum Member • Posts: 75
Re: Can an Ra be used for infra-red landscape photography?
No. The Ra is just enhaned until the Ha line. But IR is still cut. It would look similar to the Baader line of the following. (Canon is non modified, Baader modified like the Ra)
https://s12.directupload.net/images/200913/wibcf977.png
 klausd's gear list:klausd's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-70mm F2.8L IS USM
Barry Pearson
OP Barry Pearson Veteran Member • Posts: 9,625
Thanks for that comprehensive answer.
Barry Pearson
I now accept that an Ra wouldn't have a full IR spectrum, for the reasons you identify.
But would it have significantly more of the spectrum than the R?
I've just put a Hoya R72 infra-red filter on my RF 70-200mm f/2.8 lens on my (unmodified!) R. And shot (hand-held!) some trees, in and around my garden.
These are the results after significant (minutes!) work in Photoshop.
(No cropping, though).
There is some IR remaining after the R72.
(I realise the R72 probably isn't a perfect visible-light filter).
Would the Ra have significantly more?
Barry Pearson
The R72 filter does appear to be a near-perfect filter.
See Hoya diagram in red below.
Its cut-off excludes visibility of the H-alpha line.
So my Canon R (not Ra) must be accepting infra-red light well beyond the H-alpha line.
Since my Canon R is doing that, what is the upper-spectrum-limit of the Ra?
Does the Ra simply have a very narrow pass around H-alpha?
Or does its variation from the R extend well beyond the R's own limit?
In other words:
Would the Ra make a good camera for infra-red landscape photography?
