Re: ED 100-400 f5.0-6.3 loose on mount?
12
For your interest please compare the locking detent on the 100-400mm to other lenses you may have for MFT. I made the comparison on my lenses and this is what I found.
Refer to the attached pictures.
Measured with digital caliper: 2.1mm width
Measured with digital caliper: 2.04mm width
I also measured the diameter of the rotation locking pin on 2 camera bodies and MC-14 and MC-20. The pin diameter was 1.95mm.
Now it is a matter of simple math.
For 100-400mm: 2.1mm - 1.95mm = 0.15mm clearance
For other lenses: 2.04mm - 1.95mm = 0.09mm clearance
We can see that there is a difference in the clearance. With the 100-400mm, there is a total rotation play of 0.15mm, whereas other lenses the total rotation play is 0.09mm.
These are calculations based on my lenses. You will have to measure your own lenses to compare. Your 100-400mm locking detent width may be larger which would result in more rotation play.
You may also ask why on a 'good' lens it feels rock solid, no rotational play even though there is a designed in mechanical clearance. Well there is rotation play as well, but you might have to force the rotation to feel it. One other thing to consider is the gap of the 3 lens lugs to the base of the lens mount. You would have to measure both the 100-400mm and other lenses to see if the gap is slightly bigger in the 100-400mm. If the gap is bigger, then the lugs are not holding the lens as tight against the camera body lens mount which will add to the felt slippage that occurs. All these little mechanical tolerances add up.
Other users have noted that the lens is rock solid or just slightly slipping on their camera bodies (previous discussion), so this does indicate slight differences in either the lens locking detent width, lug gap or even the camera body lens mount.
My situation is that I have very minor rotational play on my 100-400mm but it does not bother me. I didn't even notice it until this was brought up as a problem and I tested my lens for rotational play.
Hope this is helpful to understand what may be causing your problem.
