Why not a titanium body ?
Started Sep 11, 2020 | Discussions
zakaria
zakaria Veteran Member • Posts: 6,556
5
what I want from Pentax:
a strong yet light "titanium" body like Fujifilm X Pro 3 or an aluminum body like K01 to keep the weight much lighter than stainless steel.
The design:
is by sliding all the upper buttons and keeping a small screen at the top right. Why not go back to a design close to the K5 instead of crowding buttons .
Weight:
close to the weight of K50 or KS1.
I hope to see a  body  matching with the limited lenses. Let's keep K1 line for the Star lenses and the APS-C for the ltds lense .
pentaxian .
 zakaria's gear list:zakaria's gear list
Fujifilm X-H1 Pentax K-1 II Fujifilm X-T3 Nikon D780 Pentax smc FA 31mm F1.8 AL Limited +8 more
Pentax K-01 Pentax K-1 Pentax K-5 Pentax K-50 Pentax K-S1
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
Re: Why not a titanium body ?
It would probably be too expensive to make. Titanium ain't cheap.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
alex_virt Veteran Member • Posts: 3,044
In early 1990s in Russia, when export of titanium as a strategic material was banned, one enterprising company exported lots of spades made of titanium
bob5050 Senior Member • Posts: 2,948
Why confine the *s to FF? I'm really looking forward to the upcoming DA * 16-50mm.
Or the limiteds to FF? Pentax itself is marketing the k-new as "compact and study," and always called the KP the perfect match for the Limiteds.
bob5050
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Sigma 17-50mm F2.8 EX DC OS HSM +6 more
LightBug Senior Member • Posts: 2,818
Magnesium is lighter than Titanium
The design:
Weight:
I'm rather surprised myself when I googled "Magnesium vs Titanium". Magnesium is what most higher end cameras like K1 and K3 use.
https://cdiichinadirect.wordpress.com/2012/04/04/magnesium-is-called-the-metal-of-the-future-for-a-reason-lillian-wong/
Quote: "Magnesium is 33% lighter than aluminum, 60% lighter than titanium, and 75% lighter than steel. Yet for many applications it’s stronger per unit volume than all three of those structural metals."
 LightBug's gear list:LightBug's gear list
Pentax 645Z Pentax Q-S1 Pentax KP Ricoh Theta V Pentax smc DA 15mm F4 ED AL Limited +19 more
Oiche Senior Member • Posts: 2,045
This is why...
7
What advantage is there over a magnesium alloy body? Ah yes bragging rights and enhanced snobbery.
It's not a pure titanium body anyhow that you refer to, it is a titanium alloy where they add a small percentage of titanium to the alloy instead of magnesium.
If you knew about titanium engineering you would know a pure titanium body would be ludicrously expensive as it is very difficult to manufacture.
Such engineering applications usually include a very high melting point beyond aluminium, magnesium and others. Clearly a consumer camera does not need this.
Carbon composites were developed for the likes of fighter planes, one of the reasons was because titanium was too expensive.
I'm happy with polycarbonate myself... Light, strong and shock resistant. Carbon composites are more brittle therefore less suitable than poly composites.
 Oiche's gear list:Oiche's gear list
Pentax K-70 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 40mm F2.8 Limited Samyang 14mm F2.8 ED AS IF UMC HD Pentax DA 15mm F4 ED AL Limited +1 more
Joseph Tainter Forum Pro • Posts: 11,494
I'd prefer depleted uranium.
Joe
Only for sabot rounds ... <g>
Actually, I went to the barber's yesterday and she asked me if I preferred a scissor or electric cut. My answer: I have a thing against telling professionals what tools to use. I'm just interested in the result.
Same applies here.
bob5050
ogl
ogl Senior Member • Posts: 2,004
3-6 USD for 1 kg. aluminium is 1.7 USD for 1 kg.
 ogl's gear list:ogl's gear list
Pentax K-5 IIs Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited
Joe
Very heavy element and the radioactivity introduces noise to the sensor...
The workable manufacturing costs of Ti is exponentially more than Al.
The raw material cost is insignificant in comparison.
Might be cheaper to cast unobtainium with encrusted diamonds with a kryptonite atmosphere!
None of you guys engineers? Used to be a few Boeing engineers on this forum maybe well past pension age 😁
Pentax645 Contributing Member • Posts: 968
Joe
Another industry first for Pentax.......an eye-catching yellow body. Upgrade model with a hint of magical glow.
......................Larry
 Pentax645's gear list:Pentax645's gear list
Pentax K10D Pentax K-1 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA 12-24mm F4.0 ED AL (IF) Pentax smc D-FA 100mm F2.8 macro +6 more
Zvonimir Tosic
Zvonimir Tosic Veteran Member • Posts: 3,234
Magnesium alloys are 2.5x lighter
7
Magnesium alloys are ideal material for shaping of Hi-end camera bodies, best in terms of overall cost, manufacturing complexity and overall performance of the finished product.
Titanium not so; manufacturing processes are more complex and expensive. Titanium was used sometimes back in the past, for simpler camera bodies, when the use of magnesium alloys and casting processes were not quite developed yet.
Magnesium alloys are incredibly light, perfectly suited to reduce camera weight; resulting alloys weigh around 1.8 g per cubic centimetre; they are the lightest of all structural metals. Compare that to approx. 4.5 g weight per cubic centimetre for Titanium: Magnesium alloys are ~ 2.5 times lighter.
zakaria
OP zakaria Veteran Member • Posts: 6,556
I mentioned 3 points:
1.The body material" xpro 3 like"
2.the weight"k50 ks1" like
3.the layout."k5 like "
Most of your comments concentrated in the material point .
what about the weight and the layout?
what about k5 like body  it is simple ,durable and the grip is very comfortable.
pentaxian .
hikerdoc Veteran Member • Posts: 3,513
Re: Uranium
Probably a good choice. So many discussions turn radioactive ☢️ anyway! May as well make it legit.
You're being unrelistic.
Weight: Comparisons from cameradecision
  • K-S1: 558g. 121 x 93 x 70 mm
  • K-70:  688g. 126 x 93 x 74 mm
  • KP: 703g. 132 x 101 x 76 mm
  • K-5: 740g. 131 x 97 x 73 mm
  • K-3: 800g. 131 x 100 x 77 mm
Point: The K-S1, like the K-70, is not a premium camera, it's lighter built than even the KP, which was specifically designed to be light and compact. Weight of the K-S1 simply isn't going to happen in a flagship built to a higher standard of durability.
I don't think the K-S1 will be repeated. We might see an update to the K-70 (K-90?) that could be closer to the 700g mark. But the k-new won't.
Layout: The K-new includes a focus joystick and a new top dial--otherwise the layout looks very close to the K-3/K-5 line.  Obviously, adding additional controls is going to squeeze existing ones a bit. But I don't see the new layout as all that different or hard to get used to.
bob5050
Zvonimir Tosic
Point 1. The material is addressed above; titanium is inferior overall solution. Magnesium alloys are better.
Point 2. K50 KS1 are simplistic cameras, not sturdy enough, not sealed enough, not freeze proof enough, not weather resistant enough, mechanically outdated to be comparable with K-new in any possible way. K-new has more components inside and all new architecture, all new AF assembly, new mirror box, new pentaprism, new IS assembly, more ports, etc.
Point 3. K5 too is a simplistic camera compared to more advanced K-new, which will have features that surpass K1Mk2, especially in the AF area. Since the emphasis is on shooting through the OVF, camera must have more direct tactile controls to be operated intuitively and without screen access.
You're always going on about this but you don't have any premium lenses.
I grace my K-70 with * and Limited lenses and spend money where it counts.
My K-70 with these lenses makes a better imaging machine that your equipment.
bob5050
drummercam Senior Member • Posts: 1,964
Zvonimir's right, especially with regard to "emphasis is on shooting through the OVF, camera must have more direct tactile controls."  A lot of discussion takes place about what Pentax "ought to do," underappreciating that Pentax, in the K-new, has clearly reaffirmed its dedication to the DSLR, ergonomics, operability and durability.  K-new's architecture is indeed all new; no component is off the shelf, especially not the pentaprism, which they have been pulling from bins for years.  As for weight, asking that a compact, robust camera body be lighter by the weight of a packet of chewing gum seems misguided.
"Elegance of operation" -- Pentax
"Heavy for its size" -- DPR
 drummercam's gear list:drummercam's gear list
Ricoh GR Digital III Leica Q Pentax K-01 Pentax Q7 Pentax K-3 +11 more
5
I don't currently own any * or Limiteds, no. How that affects durability escapes me.
My K-70 with these lenses makes a better imaging machine than your equipment.
No doubt. I don't believe I've ever dissed the K-70's IQ. It's much newer than my K-3 and incorporates later technology. Again, however, that's unrelated to durability.
I expect that the k-new will cost somewhere between 1,600-2,000 USD. Knocking a camera off a table that costs that much is a different proposition than dropping a $500 camera. So higher end cameras get sturdier construction. That, in itself, adds weight but does not necessarily impact IQ. Two different issues.
bob5050
