C Sean
Re: Questions regarding Birds in Flight and Birds In Shade with my equipment
hockey guy wrote:
I have the Olympus OM-D E-M10 Mark II and the Olympus E-P5 with VF-4 viewfinder.
I wanted to try wildlife photography.
I am testing the Panasonic 100-300mm f/4-5.6 II lens now.
I chose to try this lens over the Olympus 75-300mm f/4.8-6.7 II because it is slightly faster.
I know that it is not the fastest and sharpest but I was not prepared to spend the money on
the Olympus 300mm f/4 IS PRO.
Just be aware people here started with the either the original 75-300 or the 100-300 and later upgraded. Currently there is demand for the new Olympus 100-400 and you need to ask yourself why?
In good light I have been able to get some pretty sharp images of birds that are not
moving or moving slowly on the surface of water.
Just make sure over time you improve the composition or try to make the image stand out.
I have not had as much luck when birds are in the trees, shaded (handheld.)
Unless it is an owl, bird of prey or even a woodpecker. If it something else, usually the photo is amateur at best.
Birds in trees usually have cluttered backgrounds. Anywhere there is two tips for this problem. Use an expensive large flash and a flash extender to add fill light on your subject. The other thing is to meter your subject only and you may get an increase in shutter speed.
Even at 1/320 sec small birds moving in branches are out of focus.
Usually those pictures sucks. I understand if the bird is unique, rare and colourful. However, if you’re not only holiday to Costa Rica then I would understand. However if it is a common bird then why bother trying to take a shot that going to end up being rubbish?
Any suggestions?
I am also trying to photograph birds in flight and that has been hard.
I sucked at that and I need a lot more practice.
I have read that the Olympus OM-D EM-10 Mark II ( and I imagine the Pen E-P5) do not
focus rapidly enough.
Nope, they’re more personal or travel camera. There are other cameras out there that are more expensive and designed more for sport and wildlife.
Has anyone been able to use either of these cameras for birds in flight?
If not, what would be the most economical choice a this time?
