Connect Canon 90D to PC via USB
adonetok Regular Member • Posts: 145
I downloaded Canon utility 3.0 but it only work with WIFI.
How to connect Canon 90D to PC via USB?
Steven Blackwood Senior Member • Posts: 2,039
Re: Connect Canon 90D to PC via USB
Be sure you. have the latest update and plug your USB cable in, making sure your PC end is plugged directly into the PC, not into a hub. Sometimes hubs work but not always. Also, make sure your Camera firmware is the latest.
You don't say which OS you are using.
Steve
stevenblackwood1950@gmail.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS R Canon EOS R6 Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II Canon RF 35mm F1.8 IS STM Macro +1 more
OP adonetok Regular Member • Posts: 145
Windows 7
Fastfreddy74 New Member • Posts: 14
Also make sure the cable is an actual usb data cable, some cheap ones only works for charging.
Yes, once changed cable it works.
Thank you.
