Using your MC-20 Teleconverter with your OLY 60mm Macro lens
Started Sep 10, 2020 | Discussions
wollumeg Forum Member • Posts: 66
Re: Using your MC-20 Teleconverter with your OLY 60mm Macro lens
I received my order of 2 sets of 10mm and 16mm pixco extension tubes.  I wanted to attached 10mm together to not need to worry about scarping away any material on the 16mm.  Unfortunately, one of my 10mm tubes is not allowing the electronic connections to work.  I tested by attaching one 10mm tube directly to the lens and one works (allowing autofocus, focus bracketing, etc.) and the other does not.  I have emailed roxsen support to get their thoughts...
oneofone25
OP oneofone25 Senior Member • Posts: 1,586
brand??
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
Peter 1745 Senior Member • Posts: 2,022
Try making the hole on the tube that the small mount pin goes into slightly bigger as a slightly misaligned hole is a known cause of this issue.
Peter
'Keep taking the photos'
Are you talking about this hole?
Thanks!
Thanks!
Yes
Peter
LA22 New Member • Posts: 3
Re: The proof is in the pudding...
  1. Hi, what lighting set up do you use for your photos?
MovingH2O Junior Member • Posts: 47
That's answered in the thread.
