CFexpress card runs HOT...like REALLY REALLY hot that you can't even hold it hot
Started Sep 10, 2020 | Discussions
traderjay
traderjay Regular Member • Posts: 466
I finally got a CFExpress card (256GB + 512GB LEXAR) and they run HOT! I don't know what temp they run while in the camera but when copying files from the drive to the PC using the lexar CFExpress reader, they get so hot that even the reader is uncomfortable to touch. Ejecting the drive right after a transfer is even worse, I can barely hold it for a few seconds before putting it down on the table...
Workstations - EPYC 7702 + 3950X || NVIDIA RTX 2080ti || Canon imagePROGRAF Pro-1000
 traderjay's gear list:traderjay's gear list
Canon EOS R5 Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM DxO Optics Pro Elite +1 more
starfly Senior Member • Posts: 1,137
Re: CFexpress card runs HOT...like REALLY REALLY hot that you can't even hold it hot
It's known that CFe cards run hot. I do wonder how much this varies from brand to brand, or if they will all run equally hot. And I wonder how much the CFe cards contribute to the R5 heating issues.
 starfly's gear list:starfly's gear list
Canon EOS R5 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM +1 more
David Carlyon Contributing Member • Posts: 712
I'm still waiting on my R5 that I ordered the first day, but my CFE card and reader came in right away. I ran a speed test and noticed the same thing. This was on a Hoodman reader, which is designed with fins to function as heatsink - not sure if that really helps! The speed-test would be running the card flat-out, though - I imagine shooting stills, even in big, fast bursts, it hopefully won't get that hot. 8k video at the highest settings probably will, though.
traderjay
OP traderjay Regular Member • Posts: 466
Hopefully the card doesn't get that hot in the camera when recording 8K which is about 320 MB/s write speed. When I was pulling footage off card using the adapter, it was clocking at around 750MB/s plus.
L_Speed87 New Member • Posts: 8
Not a huge issue in and of itself.  Nand memory actually prefers to run hot, it works better when it does.  Operating Temps of 70C are normal, which is pretty darn hot to the touch.
RDM5546
RDM5546 Senior Member • Posts: 3,654
Even though a water temperature of 110° F (43C) is 'relatively-safe', exposure can be painful; the human pain threshold is around 106-108° F (42C) ... A child can suffer a third-degree burn in 124°F (51C) water in less than three minutes. Children and adults can be burned this badly in two seconds or sooner in 149°F water .. A safer temperature for domestic hot water is below 50°C. This is because water at a lower temperature takes longer to cause injury. For example: At 60°C, it takes one second for hot water to cause third-degree burns.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Exactly. Which is why i pointed out it's hot to the touch, but it's not really an issue from an operational standpoint.  Many people assume that because it's that hot to the touch, something may be wrong or that it's going to die a quick death.  I was pointing out that this isn't an issue as operationally, NAND memory has no issue running at that temp, it's part and parcel with the fast speeds you're going to get.
Whether your fingers enjoy touching it after a long transfer is a totally different issue entirely. One might want to wait a bit under such scenarios
RDM5546
The memory in the CFE and all flash cars is non volatile and by design relies on providing the semiconductor charge high enough energy to cross a charge high barrier to get into an isolated trap state in a controlling part of the storage bit cell. Going over this potential means it has to be supplied a significant power and the barrier has to high to prevent the charge dissapating from normal thermal energencies experienced.
So yes I agree the temperatures experienced in the hot CFE cards is normal and well within design tolerances. The card are within their thermal design envelopment for data retention but hot enough to potential cause burns during extended exposure particularly by children if held above 51 C for three minutes which is not likely because is quite unpleasant. It is also not likely because Canon this and it is part of their thermal management system to prevent burns that would result from a 60 C card. It is easy to see some difficulty the management system has keep humans, data collection, and camera components safe and in regimes of reliable operation for a 20 year product lifetime with zero regular maintenance.
So there is a distributed set of key locations the Canon software attempt to manage the temperatures of and I know of at least four and likely five serious hot spots that must occurs in some modes of camera operation. They do this with a temperature estimation thermal model and apparently three thermeter measure points. Not every danger has a direct thermal sensor and some of the areas are too small varied to put a temperature in. Particularly modeling the cool down operations is highly tricky as it requires data from all of the external case heatflow location of which there may be many and varied in locations. Knowing your sensors are cool is far from know all the sensitive components in the system are cool. Time is a factor there and fewer points are required if more time for reaching cooled equilibrium is allowed for.
We do not know know if all flash cards from different suppliers are exactly the same in their thermal ramp streaming write heating cycles. It is possible there are differences that may be only small from a perspective of camera writing time but this depends on the specifics of the cards and management firmware operation in the camera as well.
I own Sony and Lexar CF cards. Also Sony, Lexar and Prograde V90 SD cards. I do not have my R5 yet but I am now curious how long each will run under controled environmental experiments writing the highest speed video rates shown in the manual  within card specification for each card to observe the recording times vs manufacturer.
gavin
gavin Veteran Member • Posts: 8,241
Read the Lens Rental R5 thermal imaging article. The hottest part is the CFe.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
RDM5546
There are many "hottest part" at issue here in the article if it is read carefully as have and will explain. The lens rental story does state "The hottest spot in the camera, though, was clearly the CFx slot. After the card was ejected it was about 48°C."
You are partially corrent in that elsewhere later in the article we learn "The CFx card slot was at 57°C and the internal temperature sensor at 61° C when things shut down."
However it is reasonable the temperature sensor source the EXIF data is presumably referring to the hottest spot mentioned in the article and it is at the temperature sensor which is at a location not known outside of Canon precisely but there has been plenty unconfirmed speculation as to it's location.
I suspect the temperature sensor may be close to the hottest spot which actually on the circuit board not too far from the temperature sensor.
The article mentions three different "hottest part".
The first was the statement: "The hottest part of the camera was the back behind the LCD door (43°C / 109°F), followed by the rear body around the command/set dials and the area of the grip where you rest your thumb (40°C / 104°F)."
The second was the statement "The hottest spot in the camera, though, was clearly the CFx slot. After the card was ejected it was about 48°C."
The third was the statement " The camera is hotter deep inside (the temperature sensor) than at the hottest exit points."
For the purpose of evaluating mitigating strategies to accelerate the heat exit transfer rate I chose the first stat the hotter part of the camera which is the only one of the three hot locations above that is fully on the exterior of the camera and the back behind the LCD has a large surface area attractive for facilitating large amounts of heat transfer. The CFE card is 5°C warmer which would be better for hear transfer but it's surface area is small and not easily assemble from it's mounted location inside the camera and behind a latched door.
LesT
LesT Regular Member • Posts: 484
Having had that very card in hand.... temperatures were the same between that and the SanDisk. You have the Delkin as well. Are they similar in heat? I found that reader very warm as well. The SanDisk reader is much cooler but it is a different build.
Pulled my SanDisk CFexpress out of the camera yesterday and noticed it was hot within the camera as well...not as... But noticeable.
So.... Unlike SD cards, CFExpress cards are built to dissipate the heat created through higher transfer rates to the outside of the card. It is actually a new challenge in the storage industry because we could put heatsinks on SSDs when transfer rates increased as they were not meant to be a removable platform like CFExpress. The difficulty with CF Express is that air pocket between the card and camera and card readers. The heat has nowhere to go.
 LesT's gear list:LesT's gear list
Canon EOS R5 Canon EF 28-300mm f/3.5-5.6L IS USM Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM Canon RF 24-240mm F4-6.3 +2 more
Tracey Pettis New Member • Posts: 4
Am I seeing burn marks on my express disk? Wow! Should I even use? Has anyone experienced similar?
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
I've been using my CF-e cards for over two years.  They have not burned up yet.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
Abbott Schindler Veteran Member • Posts: 3,099
What reader were you using?
Looking at the card's label, I'd suggest that you a) scrap the card (possible heat damage), and b) buy a different brand. Consider Delkin, SanDisk, Sony Tough and other mainstream cards.
AFAIK, Ritz "brands" gear; they don't manufacture it themselves. There's no guarantee that they consistently source from the same suppliers, or even the same quality parts from those suppliers.
Your card's Write spec is pretty low; I wouldn't consider it for video or heavy duty burst use. Also, keep in mind that "Maximum" claims don't mean much. For example (made up!) I can claim "2000 MB/s Maximum Write Speed", and deliver 100 MB/s and I've met the "spec". I've got similarly spec'd cards from several manufacturers, and none hit their Write spec, but 2 of them come reasonably close to their Read spec, and outperform another brand's Write spec by quite a bit.
At the very least, though, don't use that card again—or risk problems. B&H had some really good sales on Delkin and SanDisk CFexpress cards in the last several months; watch their site.
FWIW, I'm shooting with EOS R5's. The only times either locked up was when I used a specific brand of card. Without saying which brand, I'll reiterate my recommended brands above, which have performed flawlessly for over a year, including when shooting 8K video.
Rudy Pohl Veteran Member • Posts: 6,141
I bought a new R5 four months ago and I do a lot of video recording almost all shot at 4K 120fps ALL-I at 1880 Mbps. I have used 2 SanDisk 128GB 1220 cards and a SanDisk CFExpress card reader since day one. My cards have never been anywhere near hot. Rather only mildly warm so you can barely feel them. This is true when coming directly out of the camera from indoors recording and when downloading a full card to my PC.
Also, this brand of card never stops recording because of too much data transfer regardless of the video format, i.e. 4K120p, 8K30p, etc.
Rudy
But see the discoloration on the disk? Seems like that would be a bad sign that I might not want to use it.
BobKnDP Senior Member • Posts: 3,140
Apparently CFExpress cards vary in running temperatures. Some throttle.
Delkin Black CF Express Type B 512GB Memory Card Review - Incomparable Sustained Write Speeds and Low Temps | The SSD Review
If the Lexar model in the review is what you have, then you have one of the hottest cards in the test.
I was inspired to buy a couple of 128GB Delkin Power cards. (Less costly than Delkin Black.)
Deak Regular Member • Posts: 229
Where did you buy the card? There are a lot of fakes on online sites... a genuine card should not do that.
Deak
 Deak's gear list:Deak's gear list
Canon PowerShot S100 Fujifilm X-H1 Fujifilm X-T3 Sony a6600 Canon EOS R5 +40 more
Wraith New Member • Posts: 10
Switched from Hoodman to ProGrade
When I bought my R5 I also got a Hoodman CFexpress card (128gb) and a Hoodman CFexpress card reader. They ran very hot and appeared to be running continuously while attached to the computer even if the reader was not being accessed by an application.
I stopped using the Hoodman card and card reader. I switched to ProGrade card readers and ProGrade CFexpress cards (128gb). All of my excessive heat issues went away once I switched to ProGrade.
expro Senior Member • Posts: 2,273
Re: Switched from Hoodman to ProGrade
I’m assuming you don’t shoot 6k/8k video as your card does not write fast enough. This means it also will not heat up anywhere near as much.
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
