EF-S lens in EOS R
Started Sep 9, 2020 | Discussions
thanda Regular Member • Posts: 338
EF-S lens in EOS R
Hello all,
I am eyeing EOS RP and I believe mirror-less could be the future. Otherwise my immediate choice would be 6D mark II
Yes there is a nice adapter that takes EF and EF-S lenses and currently I own EF-S 15-85mm lens which I like for casual photos and an EF 50mm lens for portraits (not pro)
My question is how is EF-S 15-85mm on EOS RP. I am aware there is no crop-factor and dof is as it as.
So I am looking mainly the performance and other factors if any?
Tmjc Regular Member • Posts: 312
Re: EF-S lens in EOS R
I'm not sure if you misstyped or if you just have wrong information, but the 15-85 lens is designed for crop sensor cameras only and it's image circle won't cover the full sensor of the RP. You can still use the lens but you'll have to crop the image to get rid of the vignetting.
The cropped imagine will have 10mp thereby giving you worse results than any modern apsc camera.
I would only recommend to use the lens as a stop gap solution and upgrade to a 24-105 or similar lens later on
 Tmjc's gear list:Tmjc's gear list
Canon 6D Mark II Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon EF 50mm F1.8 STM Canon 70-300 F4-5.6 IS II +1 more
davev8
davev8 Veteran Member • Posts: 4,833
i believe the RP has a crop mode so the user won't have to crop in post ..it will just become a 10MP APS-c camera
it depends on how the OP displays his photos ...a 50 inch 4k monitor only needs 8MP..it won't look any better with more MP unless you want to crop in
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will  tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
OP thanda Regular Member • Posts: 338
Oops I did not thought about that. Even with crop-sensor EF-S 15-85mm tend to vignette a bit.
Now, I am thinking either I sell EF-S 15-85mm and go into full-frame or switch to EOS-M cameras for their compactness or EOS xd, xxd or xxxd cameras.
1) I need to upgrade my ageing EOS 450D
2) At max I upload in flickr or print them on 13x18 cm if they are family portraits.
One hand side I like looking through the view finder and still owns many OM-1n cameras (please to look through the VF) and some medium formats. And on other hand modern tech and compactness are desired at many occasions.
quiquae Senior Member • Posts: 2,265
As mentioned earlier, the crop is automatic: the moment you attach an EF-S camera to an EOS R, the body starts shooting at the APS-C crop size of 11.7MP ( 30MP / 1.6^2 ). If you are going ahead with purchasing an EOS R, I would recommend getting full frame lenses for general photography--you'd be wasting much of the potential of the camera if you shoot with crop lenses.
The one exception is if you have plans to shoot video: 4K video on EOS R comes with a mandatory 1.6x+ crop, which means your 15-85 suddenly becomes more convenient for shooting video than any RF standard zoom.
tl;dr: get the EOS R, get the full frame lenses, but hang onto your 15-85.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
davev8
i would sell the 15-85 and look at the rp
as a M system owner  i am unable to say how long canon will support theM..we have only been getting 1 new lens a year and non so far this year..you can adapt EF/EF-s lenses but many are big and defeat the point of the M ...they won't drop the M for a very long time but just make the R look more enticing ...they dropped the flagship M5 with no M5mkii so if you want a camera with a built in EVF you have to get the lowly m50 ..which is a good litle camera for the price.. there is a rumored all singing all dancing M7 supposed to be on the cards but i won't hold my breath ..maybe it will arrive but the truth is we are in a shrinking market and canon has 3 lens mounts and i am pretty sure there goal is to end up with just one ....and it won't be the M
but on the bright side the M has a lot to offer and some of the lenses you cannot replace with as compact and with the  IQ they can produce at the price...or any price in other systems   ...the 11-22mm UWA is the best example
Sittatunga Veteran Member • Posts: 5,406
thanda wrote:
Hello all,
If you go for FF, you will not find the 15-85mm much use. It won't fit onto any FF canon DSLR, and it will automatically crop to just under 10 megapixels on the EOS RP or just over 11 on the R.
For the price of the RP I would recommend the EOS M6ii, a much more advanced 32 megapixel camera than the RP, which will take all your lenses (including the OM ones) and it's smaller than your EOS 450D. Your EF and EF-S lenses will give their best results on the M6ii. It does have a detachable electronic viewfinder; if you want one built in, consider the simpler and much cheaper 24 megapixel EOS M50. If money is tight and you're not bothered about an EVF, there's the M200 or the end-of-line M100, also 24 megapixels.
Going full-frame mirrorless isn't going to be worth it unless you also buy the 24-240mm RF zoom or one of the several 24-105mm RF or EF zooms.
davev8
your 15-85 will work much better on the R than on a 450D you will have better dynamic range and better ISO evan in crop mode on the R  and waaaay better AF..also if you get into video the 15-85 will be a good lens at the R shoots 4K video in crop anyway
looking at what you do you won't be MP deficient anyway ..but thier will be a lot of unrealised potential
your manual focus lenses from your OM cameras will work splendidly  adapted on an R..  focus is easy with focus peaking  or the 10X loupe that you can have anyplace on the tuch LCD in a couple of dabs and a swipe  adaptors are cheap on ebay ...be warned  MF glass it can become ....addictive
I have Zuikos from 24mm - 135mm except 100mm and macros. I rather sell 15-85mm, if Zuikos goes well with R/RP.
If I get it right then I may also need OM-EF adapter + EF-EOS R?
You can get adapters straight from OM to RF (or OM to EF-M too).  The minor advantage of going the OM to EF to RF route is that the OM adapters are very slim, so buying a lens for each adapter would not increase the size of the adapted lenses very much.   The big advantage of going the OM to EF to RF route is that the match-triangles focus aid of the EOS R needs to know that there's a lens mounted. Canon does that by the body checking for an electrical response from the lens, and a chipped OM to EF adapter will give that. Some older chips, however, will confuse the camera. The RP doesn't have that focussing aid anyway. Otherwise you can use focus peaking or focus magnification, but not both at the same time. I don't think anybody makes chipped lens mount converters to RF mount yet, even though they would only need to tell the camera an adapted EF lens was mounted and that can't be too difficult.
Now I am strongly biased to R/Rp and perhaps some Zuiko f/2 lenses. I turned 40 this year and still shoot film and have a nice darkroom in the basement.
I let go 15-85mm and start saving for R/Rp
Sounds sensible. Hang onto your 450D if you go for individual chipped EF mount adapters as that body will definitely let you program each chip to tell the camera the focal length and maximum aperture of its lens. That's useful for the EXIF data (it won't tell you the actual aperture used, but it will identify the lens) and could be useful if you subsequently buy a body with IBIS.
You would also be able to use your OM lenses to give manual focus confirmation with your 450D.  That 135mm Zuiko would give you a very compact 200mm FF equivalent lens.
If I can say honestly then one thing that I really don't like to have is the video feature in a DSLR (may be I am not so mainstream)
A kind of modern 450D, that have a full-frame, good auto-focus and AF-points, minus optical view finder, a better connectivity and grip. But...
User5469540350 Regular Member • Posts: 175
Two pics. EF-S 18-55 at 50 ( 4.5MB) and rf 24-240 at 50 (9.5MB). The ef-s lenses can only be used in the 1.6 crop mode. EF and RF lenses in both and 1:1 , 4:3 , 16:9 mode.
I think camera did a great job despite throwing a kit lens (EF-S 18-55).  Nice comparison and thanks for the effort.
Mark B.
Mark B. Forum Pro • Posts: 29,743
It's slightly worse than that.  The OP is looking at the RP, which has a resolution of 26mp so with the crop will be left with 10.1mp.
The video is really a by-product of the hardware you need for the EVF and the computing power you need for the good AF and AF points.  The slight extra cost of the firmware for video is more than cancelled out by the economies of scale from selling to all those who do want video.  If you're serious about not wanting video, look what it does to the price of the price of a Leica.
I am dropping the idea of using EF-S lens altogether and use EF and OM Zuiko lenses instead.
But I did not read or know anything about using of manual focus lenses either with R or Rp. If Rp does not support then I will pick R (a bit pricey for what I do nevertheless)
I bought the R for the magic focus aid, extra 4 megapixels, improved dynamic range, dust cover over the sensor while changing lenses, better construction, EVF  and bigger battery.
Both cameras do manual focus peaking or magnification of the focus spot (5x or 10x but not in conjunction with focus peaking).  I use the much maligned M-Fn bar to control the magnification and toggle the electronic level and histogram, so I don't need to lock it or worry about accidentally altering the exposure with it.  The match triangles focus aid is wonderful manually focussing RF and EF lenses and adapted lenses with chipped adapters.  The RP doesn't have that feature, but it does have automated focus bracketing, which is missing from the R.
