Drove up to Anderson, South Carolina to pick up a tool and on the way back shot some architectural images with the K3ii and the DA* 50-135mm. Drove back through Due West, which is near Level Land, to Abbeville and McCormick to see Greek Revival antebellum mansions.
Now knowing that Ricoh is updating the DA* 16-50mm my mind wandered to what I would want if they also decided to update the 50-135mm. Having the K1 and the FA* 70-200mm, my primary want was that the APS-C lenses should be relatively small and easy to transport. There needs to be a real difference between the two formats. The need to have large, heavy bulbous lenses to ensure edge to edge sharpness and reduced distortion at fast f-stops means I'm willing to compromise on those factors to a degree for the sake of size and weight.
Here are some size (dia.) and weight information.
- DA*50-135 f2.8 67mm 685 g
- DA*60-250 f4 67mm 1040g
- FA*70-200 f2.8 77mm 1755g
What is the sweet spot for APS-C? Should the 50-135mm even be upgraded?
The Old County Court House with the obligatory confederate monument in Anderson, SC
Due West Associate Reformed Presbyterian Church, You can generally tell the denomination by the steeple. I don't believe there is any significance to the vulture sitting on top!
Abbeville Main Street United Methodist Church. Notice the difference?
Abbeville, Burt-Stark Mansion. Noted as the location of the last Council of War of cabinet members of the Confederate government in May 2, 1865. Classic antebellum mansion of a square, two story with a four wood column front porch.
Cedar Springs Historic District, Frazier-Pressley House. Built in 1852, this is not a classic Greek Revival antebellum mansion in that it is three-story, stuccoed brick building, with three octagonal elements joined with a connecting hallway. The columns are brick (not the usual wood) also.
Near McCormick, Eaton Hall, 1854. Classic Greek Revival that features a pedimented, two story front portico. Two image panorama. Take away the front porch and this is a simple two story wooden box house that had no plumbing or gas/electricity. So it wouldn't catch fire the kitchens were in another building nearby.
