R6 - for Astrophotography? Yup. (PICS)
Sep 7, 2020
The EOS R6 + EF 24mm f/1.4L II USM lens - (the red reflection is from my car door).
I drove out to the mountains tonight because the sky was clear today. Arrived at 8pm. Returned home by 10pm. Skipped dinner. Downloaded images from both my EOS R6 camera and my EOS M6 camera and edited them over a couple of hours. Mostly noise-reduction from the M6 and color tweaks from the R6 (to suit my taste).
No Vignetting with the EF 24mm f/1.4L II USM lens !!!
So, you bought an EOS R6 and wondered if the R6 would be any good for astrophotography. So did I. And knowing that the light-wells on the R6 were allegedly larger than its rivals, it stands to reason that the R6 ought to be capable of capturing something useful with that full frame sensor. It surprised me in being able to render some admirable detail at fairly high ISO. What really surprised me is that the same EF 24mm f/1.2L II USM lens that vignetted so horribly with a non-correctable hard vignette (not light-falloff) when used on the EOS Ra did NOT vignette in the slightest with the EOS R6. In addition, the lens was tonight sporting both a UV Filter for protection PLUS the lens hood. I had planned to strip them off one-at-a-time to determine if the lens or the camera was problematic but the first images to appear on the LCD of the R6 showed me the problem no longer existed with the R6. No vignette!? I guess there's a minor mechanical difference with the EOS Ra and the EOS R6. I can't help but wonder what it could possibly be since both the R and the Ra use the same body design. The same RF-to-EF adapter was used. I was pretty happy to see that this lens is very useful on the EOS R6 because I didn't want to retire it altogether. I'm going to post a thread with that lens later when I get to shoot another location with it. I just spent a weekend on the central coast with this 24mmL lens and it works quite nicely on the R6.
GEAR USED:
* Manfrotto Tripods (x2). One for each camera.
* Baseball cap with LED lights fitted (very handy)
* Reading glasses to magnify the LCD to check focus
* Flashlight, just in case.
SETTINGS USED:
* All images shot in JPEG
* No images have been cropped.
* No Stacking.
* No Tracking.
* Images were edited quickly in Lightroom & resized in Photoshop.
* White Balance for R6 = Daylight
* White Balance for M6 = Tungsten
* IBIS was turned OFF
* Manual Focus used with both cameras
* R6 ISO settings = ISO 2000 - ISO 5000
* Aperture = f/1.4 - f/2.0 (24mm) / f/1.2 - f/1.4 (85mm)
* Shutter Speed = 20 seconds (24mm) / 5 seconds (85mm)
* 2-Second Timer Delay used.
* EXIF details should be embedded in all images (phone users may not see this).
Problems encountered:
* EOS R6 - None
* EOS M6 - self timer became slightly unresponsive in the cold.
* Ash from woodfires was falling on the cameras and lenses.
* Sky was fairly bright tonight - despite the moon not having risen.
R6 + 24mmL - I was standing in the dark when taking this. BONUS: No hard vignette!!
Large Magellanic Cloud in the top left corner. Carina Nebula is in the lower middle of frame.
R6 + 24mmL lens - The milky Way's galactic core was visible on the LCD.
R6 + 24mmL lens - The Galactic Core - after editing lightly for color/contrast preference.
The EF 24mm f/1.4L II USM lens is known for producing coma towards the corners. I didn't bother to correct this during editing. It's easy enough to stop the lens down slightly and this reduces the effect of star-blooming. Some slight light falloff was present towards the edges but it was very subtle and easy to correct. Lens corrections were switched ON for both lenses when fitted to the EOS R6. The bright area of the Milky Way (the Core/the Bulge) was visible on the LCD of the R6 when I was trying to see what the camera was aimed at. You can see this quite clearly on the LCD in the photograph above.
The sky was oddly bright tonight. There was a washed out yellow hue to the images which I tend to only see when there's a moon in the sky. I'd timed my arrival to be at least 3 hours after sunset and around 2 hours before moonrise. Shifting the yellow hue toward blue in Lightroom gave me a pleasant result so that's what you're seeing here from the EOS Ra. I imagine any lens from Canon or even other manufacturers will be just fine on the EOS R6 for this type of photography.
EOS R6 + RF 85mm f/1.2L USM lens
This is a rather special lens which I chose to buy instead of a telescope. The lens has some unusual features (eg Blue Refractive Optics) which suppresses chromatic aberration ...and the resolution from this lens is excellent. It's abnormally sharp at f/1.2 although it's slightly sharper at f/1.4 whilst retaining a large aperture. It was relatively easy to pick out some bright stars, zoom in to 10x magnification on the LCD and manually focus the lens. The EOS Ra has a slightly better LCD screen magnification tool that is far easier to use for manually focusing a lens on a star.
Astro with the EOS R6 - compared to other Cameras:
I found the R6 easy to use. The settings were easily engaged. The camera was highly responsive and the image quality was better than I thought it would be. The LCD screen was reactive even in cold weather. The R6 is less noisy at higher ISO settings compared to the EOS 6D DSLR... which is a favorite camera for many astrophotographers. The signal to noise ratio was quite reasonable and the larger light wells/cells on the EOS R6 enabled good light collection when facing the night sky. I'd have spent more time with different settings to try and lower the noise further if I had the time to spare ... but the results I was getting with the settings used were enough to convince me that the R6 is versatile enough to be used as an astro camera. The Full Frame sensor on the R6 is gathering more light than an ASP-C sensor could hope to do with similar exposure times and ISO settings. As long as your lens has a relatively wide aperture (ie preferably wider than f/2.8) you should have no problem getting good exposures.
Now I'll personally be using the EOS Ra for my astro-landscapes etc. and that's exactly why I bought it ... so this will be one of my only sets of Astro images from the EOS R6. But if I am traveling and might have need to take some astro-landscape images, I know the R6 can do the job. All I need is a tripod.
R6 compared to the EOS Ra astrophotography model.
The EOS R6 produces slightly more noise than the EOS Ra and slightly less detail with the same exposure times. The EOS Ra was also designed to capture more of the red emission nebulae in the 656.3nm (Ha) frequency... something that other cameras can barely achieve without modifying the sensor. But the results from tonight's experiences with the EOS R6 showed me that I could expect to use this camera for astro should it be the one on hand when traveling. Again, the light-gathering ability was very good. Noise was close to the 6D (DSLR) whilst being better than the 6D at higher ISO settings. The EOS R6 didn't quite come close to the rich colors captured by the EOS Ra but the results were just fine. Better than I expected. I think that the R6 is perhaps just as capable as most Full Frame cameras for this type of subject. Very little editing was required for these images. No doubt further tweaking of settings and images will produce more spectacular results. And RAW users will likely be able to pull a little more flex from the files captured. Left to my own devices, I'd probably edit these images a lot more than I have here. Another thing the EOS Ra features is a magnificent 30x magnification but you can still nail the focus on a star with the R6 and you don't even need to seek out a very bright star to do this.
The camera did not heat up when shooting 6-second and 5-second exposures for an hour. To repeat, I have not introduced any colors to these images. In order to extract the blue hue in the Rho Ophiuchus region, I simply increased the color saturation to enhance it. The same process revealed the pink/red colors in the star-forming nebula regions. This image directly below is an unedited image straight from the camera... straight from the memory card. No crops, no color alterations and no edits or adjustments... I just wanted users to know what I was getting tonight. Usually my skies are a bit darker than this. The region in the image below (with the Lagoon Nebula) was directly overhead at the time. The ash falling on my camera and lens was from nearby homes with wood burning fires... plus there have been precautionary burn-offs in the area.... and these may have been contributing to the light pollution in the air.
Hopefully these samples will be of use to others contemplating what the R6 can do under fairly clear skies with moderate to bright lenses.
EOS R6 + RF 85mmL - A full sized unedited JPEG straight from the camera
The Lagoon Nebula is dead center.
R6 + RF 85mmL - Looking towards the Carina Nebula with the R6. It was washed out near the horizon. I have no idea why the sky was so bright over there tonight. (not cropped)
I've only been home for three hours since taking these images, Just enough time for a color/contrast tweak. This is made from 6x JPEGs merged into a vertical panorama. Contrast, Hue, Color, Levels & Curves were edited for the image on the right. Existing colors embedded in the JPEGs were bumped up and enhanced. No additional color was added.
EOS R6 + RF 85mm f/1.2L USM lens - as seen by my EOS M6.
The Canon EOS Ra with the same RF 85mm f/1.2L USM lens (hood removed)
Marco Nero.
