Moon and Mars with Oly 100-400 + MC-14
Started Sep 6, 2020 | Photos
Captive18 Contributing Member • Posts: 956
Re: Stacked super res at 560mm
Brian Wadie wrote:
Astrotripper wrote:
OK, so I was way wrong about stacking.
Single frame, prepared for stacking
Stacked with x3 drizzle, scaled down to final output resolution
Final result after extra processing. I might have overdone it a bit, but was also curious how far I could push it.
Consider me impressed.
Side note: I would probably not bother trying if not for the fact that AutoStakkert!3 seems to be working perfectly fine under Linux using Wine.
its good to play with new functionality, even better to find it works as described
Great images! Sorry to ask this...when you say “stacking”...are you doing focus stacking?
 Captive18's gear list:Captive18's gear list
Olympus TG-6 Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +6 more
Brandon birder Veteran Member • Posts: 5,314
Really good images. Just not sure of the terms you are using.
What's drizzle stacking x3.?
What extra processing did you do to the last image?
Thanks,
 Brandon birder's gear list:Brandon birder's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-100mm F4.0 +1 more
Bassaidai Contributing Member • Posts: 801
Re: Moon and Mars with Oly 100-400 + MC-14
Great comparison between solo lens and lens + MC ! Especially the last two 100% images really show the resolution benefit of the lens + MC combo, check below
Seems like this really works!
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
Thanks,
Dizzle stacking x3 relates to enhancing the resolution by factor 3 (for both x and y) during the stacking process. This is an option in AutoStakkert 3 (and maybe other stacking softwares as well)
Last moon image was considerably sharpened and boosted in contrast. I find it excellent that way, not "overdone".
Bass
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
2nd image "focus stacking in camera", just set it to focus stacking and let the camera do its thing, including processing the image
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
draleks Regular Member • Posts: 257
Nice, but
5
but you'd have a more balanced composition if you used a longer lens and stood further away.
OP Astrotripper Veteran Member • Posts: 8,676
I mean this . Nothing to do with focus stacking.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Unfortunately, this is not a good set of photos to do a comparison like this. As I mentioned, the seeing was horrible. You can have two images in a series, one after another and one will have one crater blurred a lot while the other will have a different one blurred. That level of air turbulence really messes things up. This is especially visible for smaller, fainter features which can almost completely disappear on some photos in the series.
ARShutterbug
ARShutterbug Veteran Member • Posts: 8,993
Stand further away?
How would I stand further away from this composition of the sky?
User5456214890
User5456214890 Contributing Member • Posts: 557
These are really nice shots. I think I will try tomorrow morning with our newly arrived 100-400 but I thought I was seeing Venus next to the moon this morning around 5am. ?
Jim
"There are some who can live without wild things and some who cannot." Aldo Leopold.
 User5456214890's gear list:User5456214890's gear list
Olympus PEN-F Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +4 more
Re: Stand further away?
It would be difficult. With the recent cuts in the NASA budget, I guess the best option is to arrange an alien abduction or to find a huge selfie stick.
