Used the Panasonic Remote do you like it?
Started Sep 5, 2020 | Discussions
HRPOWER Regular Member • Posts: 159
Hello
Hoping to upgrade my G7 to something newer soon as the Remote App does not work so well with the G7. I assume you can't just update your camera and the new firmware will allow better app function?
I think when I last checked one needed to have the newer Panasonics before you get full screen monitoring.
I require the ability to remotely self shoot and make amendments when the camera is not at arms length.
Appreciate any of your experience or input.
Panasonic Lumix DMC-G7
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
Re: Used the Panasonic Remote do you like it?
For me Image App works fine with the G9 but it has also workd fine on all my previous cameras including the G7
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
northlondon43
northlondon43 Senior Member • Posts: 1,941
Hi Trevor. I constantly have problems with the app connecting to the camera and phone, which I suspect is because I'm not doing things in the right sequence (I've read the guidance but it's not helped). Would you mind describing what you do (including initial set up)? Thanks
Adrian
An amateur, atheist, alliterationist
 northlondon43's gear list:northlondon43's gear list
Fujifilm X100V Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +4 more
James Stirling
James Stirling Veteran Member • Posts: 9,282
Adrian this video from Graham Houghton who produces a lot of great videos on Panasonic gear P&S and ILC. Other than distance I have had no problems with the app on the FZ1000 or my various m43 camera over the years
https://www.youtube.com/watch?v=oamIxfdoQRQ
Jim Stirling:
It is undesirable to believe a proposition when there is no ground whatever for supposing it true” Russell
Feel free to tinker with any photos I post
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
Trevor Carpenter
I'll assume James's post below tells you what you want.  If it doesn't come back.  It's a bit complex so I can't recall it all without working through it.
alcelc
alcelc Forum Pro • Posts: 19,006
It is at least true to my older Panny (GX7), that any strong Wi-Fi interference around might cause the remote connection unstable.
A few years ago, I had set up a remote AV transmitter in my living room to transmit broad brand TV signals from the decoder on one side to the TV on the other side of my living room. While I set up the remote connection between GX7 and my smart phone/tablet (aged models in today's standard), I was good outdoor or in other rooms if my apartment, it was very unstable ~ failure connection in my living room. Switched off that AV transmitter all problem gone.
So, if you have an unstable Wi-Fi connection, worth to check any strong interference nearby. Normally I could get a stable connection of around 30~50 feet straight line distance.
Albert
** Please feel free to download the original image I posted here and edit it as you like **
northlondon43
Many thanks Jim. I'll take a look later on today.
Adrian
northlondon43
Thanks Trevor
Adrian
Tacitvs Regular Member • Posts: 163
The app worked flawlessly on my old phone and refuses to connect with my new one.  No idea why, tried everything under the sun to fix it to no avail.
 Tacitvs's gear list:Tacitvs's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Olympus 12-40mm F2.8 Pro Olympus 7-14mm F2.8 Pro Panasonic Lumix G 25mm F1.7 ASPH +1 more
