Air Show (EM1 II and Panny Leica 100-400MM)
LMcFarrin Regular Member • Posts: 375
21
Lawrence -M-
"Its not the chicken, its the Chef."
"I can show you better than I can tell you."
Tyrbiter Forum Member • Posts: 78
Re: Air Show (EM1 II and Panny Leica 100-400MM)
I would suggest using a slower shutter speed for piston engined and turboprop aircraft, the stationary propeller blades look very different from the way the eye sees them.
Some people like to see a full propeller disc, others are happy with 30 degrees or so of prop blur. Most propellers rotate at between 1,000 and 1,500 rpm so roughly 1/125th shutter speed is a good starting point.
OP LMcFarrin Regular Member • Posts: 375
Understood.  First time shooting them.
Lawrence -M-
Bobby J Veteran Member • Posts: 5,049
That bottom shot is pretty interesting because the top three airplanes have the propellers stopped in the same position!  Wonder what the odds of that would be?
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +10 more
Old Timer63
Old Timer63 Veteran Member • Posts: 5,829
I think they are great shots
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Panasonic Leica Summilux DG 25mm F1.4 Fujifilm XF 14mm F2.8 R Panasonic Lumix DMC-G7 Fujifilm X-T10 +17 more
Dale108
Dale108 Veteran Member • Posts: 8,617
Nice series.
Dale
LMcFarrin wrote:
 Dale108's gear list:Dale108's gear list
Panasonic Lumix DMC-FZ300 Olympus TG-5 Sony RX10 IV Pentax K-1 Panasonic Lumix DC-G9
Indeed, I thought you would benefit from the suggestion, otherwise I can't fault your photos.
When I shoot aircraft I normally use a 100-400 Pana-Leica lens on my G9 mainly because it gives good reach for distant subjects with the x2 crop factor of the MFT sensor.
On the occasions where this lens is too long I switch to the 12-60mm Pana-Leica lens, that's mainly for static aircraft on the ground or large aircraft displaying.
Enjoy your airshow photography, it's a fun thing to do but remember to ensure you don't freeze as airfields are often pretty windy.
Max5150 Contributing Member • Posts: 595
Good observation. The one that's "out" is a different aircraft model.
BJM
evetsf Senior Member • Posts: 1,421
Yes, and looks like it's using a Russian radial engine which turns the opposite direction (clockwise viewed from the front of the aircraft) from the US norm (CCW).
Steve
- The Hierarchy Approves -
All rights reserved for any images in my Gallery or included in a message. Specific exceptions may be granted upon request.
 evetsf's gear list:evetsf's gear list
Fujifilm X-S1 Panasonic FZ2500 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH +3 more
Lawrence -M-
R Liewenberger Contributing Member • Posts: 931
Yes, the good old Yak-52, this one a TW version with the 3-bladed propeller, a Spornrad (the rear wheel, for nostalgia reasons) and completely retractable main wheels.
The normal 52 has a front wheel, a 2-bladed propeller and even when 'retracted' the three wheels are still showing like in this lousy tiny 100% crop of such a max. 1600 x 1200 UZI file:
Two older SOOC jpgs of three normal Yak 52, from the days of the 2.1 MP Oly C-2100 UZ:
I didn't know about the difference propellers turning clockwise or CCW, but this picture shows you're right, both when looking at the Anstellwinkel (angle of attack? pitch?) of the propeller blades as well as the side of the blade on which some 'lawn mowing' / 'pigeon chopping' caused some wear to the paint:
Liewenberger
