Olympus TG6... The best UW compromise!
Started Sep 2, 2020 | Discussions
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
6
I recently "upgraded" from TG5 to TG6 and my impression from this kit remains the same. Its the best UW camera for its money with the most complete accessories range. IQ is not great with my main gripe being the low resolution (not much you can crop) but its size and features lets you grab some impressive shots:
This and the next one are my favorites
PP was done in LR based on my personal presets
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Trevor Sowers
Trevor Sowers Senior Member • Posts: 1,604
Re: Olympus TG6... The best UW compromise!
Nice!  I enjoyed those.  Which WP Housing do you use?
www.TrevorSowersPhotography.com
 Trevor Sowers's gear list:Trevor Sowers's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L USM +21 more
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,308
No housing at all! But I am using the Olympus wide extender add on lens.
DDoram
DDoram Forum Pro • Posts: 10,361
Nice captures Yannis.
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
(unknown member) Contributing Member • Posts: 602
cool shots bro.
__________________________________________________________
“A little bit of this town goes a very long way.” - Hunter S. Thompson http://www.robertbaker.photography
https://www.flickr.com/people/vegasphotog/
rgs_45
rgs_45 Senior Member • Posts: 1,460
Excellent shots. The wide adapter add on lens you use, is it the FCON-T01 Fisheye Converter?
Thanks.
- Rich -
"A photographer is your worst friend. He will Frame you! He will Shoot you! And if you're one of the lucky ones, he will Hang you too."
 rgs_45's gear list:rgs_45's gear list
Olympus E-M1 Olympus E-M5 II Nikon Z7 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +5 more
rochester21 Senior Member • Posts: 1,212
Wow
These images look much better than expected from a small sensor camera.
Yannis1976
Thanks.
Yes that one! In my opinion, it totally transforms the camera underwater, giving a much different perspective.
rgs_45
Thanks.
Thanks Yannis.
- Rich -
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
Re: Wow
First, even small sensor cameras can produce good images at base ISO. Their major problem is IQ quickly degrades once you start to increase ISO. It's one of the key factors in squeezing best IQ from such cameras. As the OP mentioned, the TG provides a excellent balance of features in a ruggedized compact. Moving up to to a 1" or MFT camera for a underwater use dramatically increases cost and complexity plus really complicates usage.
Next you're neglecting the skills of the OP. He has been doing underwater photography for some time and has definitely more than mastered the basics.
What I like about these pictures is they are actually taken at depth. Far too many people shoot only while snorkeling at the surface. At surface depths there are numerous light problems and have a downward looking perspective. Then they compound this mistake by zooming to frame the subject. One critical aspect of UW photography is to minimize the amount of water between the camera and subject.
Also, the water clarity is excellent. Not the best I've seen, but far better better than many popular travel destinations. They also used the fisheye adapter. Considering the effects of refraction, the normal wide angle field of view is somewhat marginal for UW use. As the adapter is mildly fisheye, the field of view is wider than a rectilinear lens of the same focal length. Considering that water clarity, I'm not sure I would have used the adapter. With less than ideal water conditions, the adapter becomes almost mandatory when working with close subject distances.
Also appears the OP has PP skills. UW shots almost always can stand a little tweaking. If nothing else, white balance often needs some adjustment. The TG series has a fairly good auto UW WB mode. But shooting RAW allows for more dramatic adjustments when shooting in deeper water in less than ideal conditions.
Anyway, thanks to Yannis for posting these excellent pictures. They help demonstrate the underwater capabilities of the TG-6.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
Yannis1976
Re: Wow
Thank you for your nice words! The truth is that I have shot thousands of photos with both the TG5 and now 6 and have now learnt some things about the UW photography I like. If you do like the shots, apart from the camera capabilities, there are also some tricks that may help you get such results:
1) after several years of trying, my model (my wife :-)) and myself are both trained to get certain poses and shoot from certain angles.
2) both me and she are using diving fins so that both of us can go "deep" fast and save some breathing air for the shooting. Fins also make the bodies seem more lengthy giving a nicer result in my opinion. Also using the yellow or red color makes a better contrast vs the blue water of Aegean sea
3) leaving some bubbles while being shot makes the result more interesting
4) if you do deep try to shoot also the water surface. Depending on the sun orientation, the sun rays may give a more dramatic look.
6) try to avoid shooting while snorkeling on the surface and pointing the camera downwards. Results may not be that interesting. Play with the depth, for example, shoot your model while you are even deeper than her/him
7) try and put something interesting apart from the model and the bottom of the sea, such as a rope or nice rock
8) don't pay too much attention to details (neither the camera not the environment help on that). Focus more on the overall image, scenery and colors.
9) The TG5/6 do have a very good UW WB and JPEG also look good. But if you want to make the shots pop, try RAW and play with the LR settings of contrast, blacks, dehaze and clarity. Use a lot the white balance selector!
Again I am really happy you like the shots
recklessrickftw Junior Member • Posts: 32
Re: Wow
I have this camera and I have to say the IQ is quite good actually. If you want to play with raw files, it gets better.
