Corrupt RAW files from EOS R
Started Sep 2, 2020 | Discussions
PhotoDM New Member • Posts: 12
Every now and again my EOS R produces a corrupt RAW file, shooting direct to a Sony G Series 64GB card, which is only apparent when imported into C1. I copy the images onto my HD using PhotoMechanic.  Is this a sign of a failing camera, or just dumb luck?  I had one of my original 5D's do this regularly, 14 years ago, and Canon swapped it.
Mika Y.
Mika Y. Senior Member • Posts: 2,130
Re: Corrupt RAW files from EOS R
If I understood correctly, you only use a single card? If so, maybe it's worth a try to first eliminate the chance of this being a problem with the card itself. If you have no need for an another large card, just some small-capacity cheap card should be fine. Or maybe you know someone who can borrow a card that is known to work?
 Mika Y.'s gear list:Mika Y.'s gear list
Canon EOS Rebel T4i Canon EOS 5D Mark IV Canon EOS R7 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +13 more
PMUK
PMUK Senior Member • Posts: 2,998
Hi PhotoDM,
Firstly, I have no idea what the problem may be. However, have you checked the file in question is actually kaput and it's not a transient data copying thing? Three things that spring to mind are: does that image look different via the camera playback (albeit the camera produces a *.jpeg for review); try copying the same set of files from the card to a different directory and see if the same file corrupts, and lastly; maybe try a different RAW converter, e.g. Adobe DNG Converter, or DPP and, again, see if the same file is corrupt.
If the camera is producing the occasional corrupt file, it tends to point to an occasional problem - as suggested, maybe it's the SD card beginning to fail? (Hopefully not the R).
I can't think of anything else to try at this point, but good luck...
Phil
OP PhotoDM New Member • Posts: 12
Thanks - I will try this. I have another identical Sony card, and also a Sandisk Extreme, so I will do some testing.
I have 2 identical Sony cards that I use with the R, so I will try with the other one.
Thanks for the tip!
Chris Giles
Chris Giles Regular Member • Posts: 443
It's usually a bad cable. Intermittent issues are hard to pin down. Change the cable if you haven't already and see if it happens again.
koenkooi Contributing Member • Posts: 919
PhotoDM wrote:
Every now and again my EOS R produces a corrupt RAW file, shooting direct to a Sony G Series 64GB card, [..]
Is your card one of these https://petapixel.com/2020/06/15/sony-product-advisory-these-popular-sd-cards-can-corrupt-your-footage/ ?
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Rawpaul
Rawpaul Senior Member • Posts: 2,567
don, t forget to format the card in the camera you use 👍
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
I tend not to shoot weddings tethered
All my bodies each have their own cards, so yep I do that
Fortunately not, but thanks for the heads up!
Southstorm
Southstorm Forum Member • Posts: 52
How are you transferring the pics to your computer?
 Southstorm's gear list:Southstorm's gear list
Canon EOS 7D Mark II Canon EOS 80D Canon EF 85mm F1.8 USM Canon EF 400mm f/5.6L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +11 more
Michael Mul New Member • Posts: 2
Hi all, reaching out to the canon communtiy to see if any one else out there with a EOS R has had corrupt files from the camera. I have had this R for the last 18months, this is the 2nd time it has happened to me.
Last friday i did a shoot, no issues. On sunday doing a product shoot i popped back in the extreme pro 64gb SD card and formatted in camera as i always do. began the shoot no issues, i could zoom in and check out photos as i was shooting.
Loaded up the photos from the shoot to my workstation via lexar card reader, the first thing i noticed was the quantiy of shots to be transeferred.way more than the product shoot i just completed. When i opened the folder on my WS with adobe bridge i could see all of the previous friday shoot had re uploaded but no preview of prioduct shoot. Tried to open the product shots with PS, not a valid format! tried with capture one 20, no joy either.
I noticed the file numbers were skewed. The canon R obviously didnt format the card even though i hit the button, the product shots on sunday were actually numbered before the numbers of the previous friday shoot and ran right up to the first file number of fridays shoot.
I had to re shoot the products, pain in the ass but not the end of the world. But what if this was a job i couldnt re shoot? this is the 2nd time in a few months that this has happend to me. The first time i put it down to something stupid i had done and didnt think too much about it. This time round i have documented it.
The thought of heading out on a shoot where you just dont get time to double check every time you put in a card, formatt it and then take a shot and double check the file numebr is continuous and then you are good to go!
Is it possible that i am the only canon R user with this issue? Have i reached out to canon CPS of which i am a member, yes. do i want to embarress them by publicing their response. Not just yet but i am begining to question my decision to stick with canon when so many of my colleagues have left for other mirrowless brands.
Marco Nero? if you see this post and had time i would appreciate your feedback.
thanks. mike
 Michael Mul's gear list:Michael Mul's gear list
Canon EOS-1Ds Mark III Zeiss Milvus 18mm F2.8 Canon RF 28-70mm F2L USM Sigma 135mm F1.8 (L-mount) +2 more
Thomas A Anderson Senior Member • Posts: 1,360
It is almost certainly a memory card issue.  If you want to be extra careful you could update your R firmware or do a full factory reset.
Quick or Full format?
Then again, maybe a card reader issue.  Did you try another?
You're going to have to conduct some controlled experiments here.  Format it in your computer.  Use your R as a card reader.  Try something different to isolate your issue.  Don't use Adobe Bridge to transfer....just copy/paste from File Manager.
Do you have another card?
Sure, it's possible.  But you've got several links in the chain here and you need to determine which one is broken.
This doesn't sound like an R problem.
Marco doesn't know anything about RAW shooting.  And if you want his feedback why don't you send him a private message with a link and ask him to read?  It seems like maybe you're not terribly technologically savvy?  Is that accurate?
thanks. mike
 Thomas A Anderson's gear list:Thomas A Anderson's gear list
Canon EOS R
Thank you Thomas for the logical breakdown, i appreciate you thaking the time out.
I do always do a full format in camera when begining a new shoot. The card and the camera appear to be functioned correctly again. I cant replicate the issue so i guess its just a glitch.
Canon did over the last few days engage with me on a more professional level. everyone i have spoken to points to a failing SD card. I am sending the card back to SanDisk with the comments from canon tech.
For me though, the card is dumb storage, that is it reads and writes, but it doesnt rename files. the real oddity in this is the file naming confusion which the EOS R suffered.
fridays last file was 9800, on sunday after putting in the same card from fridays shoot and full format in camera, the very first shot from sunday was named 8977.
The file numbers then on sunday ran consecutively right up to the first shot from fridays shoot.
After accepting the files were corrupted and i would have to reshoot sundays work i put back in the card and full format again, the file numbering is back in syn ( added fridays shots and sundays shots ) . everything is as normal.
this from Canon, "Thank you for your update, the camera will set the file numbering depending on the last file saved, if there was a corruption in the index the camera may have misread the last file number and started at a new file number, this is speculation as we cannot confirm this is the case until you test with another card".
maybe i just dont get it. Regardless of the card in camera, The R obviously retains internally the file numering. Did a possibily corrupt card cause the R to confuse iteslf in the file numbering?
thanks again Thomas.
mike
Enlight fotografie
Enlight fotografie New Member • Posts: 6
I recently experienced this same issue and I thought it was the Eos R which is creating the corrupt files because this happened with 2 different sd cards. But later I found that my card reader had the problem.
thanks
Emmanuel Nalli
