Tilt Shift vs Photoshop
Started Sep 1, 2020 | Discussions
JackM
JackM Veteran Member • Posts: 9,009
Finally bought a 17mm TS-E for my real estate gigs. As a quick test I went back and shot the facade of an apartment building I shot 2 years ago for a realtor using my 16-35/4L IS. The old shot was taken with the camera pointed up to include the whole building and then heavily corrected. I corrected it as far as I felt I could without it getting really squashed and weird. The new shot has minimal corrections because I was not on a tripod. Please pardon the totally different weather and light.
Old:
16-35L corrected
New:
17mm TS-E
The TS-E shot is much more true to life, and was easier to take as there is no guessing during composition, and is easier to work on.  The full 17mm field of view is retained.
The approach, taken with 50/1.8 STM. I took the above shots from the sidewalk on the right:
 JackM's gear list:JackM's gear list
Canon EOS 5D Mark IV Canon TS-E 17mm f/4L Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM Canon EF 24-70mm F2.8L II USM +7 more
Eddie Rizk Senior Member • Posts: 1,224
Re: Tilt Shift vs Photoshop
I love my TSE 17.  I don't like using it hand held, though.  If it had a tripod mount, it would sit permanently on its own tripod.
It's a magnificent piece of glass, too.  I didn't really get the full impact of better color and contrast on a lens until I got the 17,  I could recover more highlights with it than with other lenses, and the colors somehow looked better, in addition to having the magic shift function.
I've never actually tilted it.  I shoot it at F11, so everything is sharp.
Eddie Rizk
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
JackM
OP JackM Veteran Member • Posts: 9,009
Normally I wouldn't hand-hold it, but I was just excited to try it right after purchase.  I've rented it twice before, so I know what you mean.  In this shot in particular, the inherent  vignetting of the lens while shifted up is helping the sky, almost like a polarizer.
I think at 17mm, the tilt function is not a major player.
f8 and be there, no?
J A C S
J A C S Forum Pro • Posts: 20,544
You were farther away with the new lens. Also, your geometric correction would look better in DXO View Point.
Interesting.  That may be part of what I see with it.
Absolutely, especially with architecture.
Eddie Rizk
Formerly "Ed Rizk"
AlbertTheLazy
AlbertTheLazy Veteran Member • Posts: 8,683
Are you sure?
The main drawback for me with using corrections in post is that you have to deform the image rectangle and then crop to accommodate the narrowest side. This means that you have to allow extra space around the edges when framing in camera.
Albert the lazy photographer
Having fun with my cameras in Scotland
 AlbertTheLazy's gear list:AlbertTheLazy's gear list
Canon PowerShot G15 Fujifilm X-T1 Fujifilm X-T3 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R +6 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Canon 5DSR with Canon 17mm f4 TS-E.   Three shifted and stitched images.
Correcting in Photoshop will never match your 17 TS-E. Check your file, I think you shot the original at 16mm, helping to exaggerate the corrections.
I generally shoot the 17 TS-E with an interest in the foreground within inches of the lens, so it is the f22 club for me. Too bad it does not go to f64! At times I will shoot at f8 and then focus stack to achieve the depth of field I want with increased sharpness.
I experimented with tilt years ago, and will do so again soon. However, my understanding and results make me believe that it is not useful for the images that I create. Definitely less effect with the 17 than the longer ones.
I use shift to correct converging lines, but I primarily use it for shifting and stitching to provide a wider view with medium format sized image files. You can experiment to see if you have an interest in ultrawide angle photography, achieving the view of an 11-12mm lens with your 17.
Have fun with it!
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
AlbertTheLazy
John,
I'm not the one to tell! Try replying to the right person.
John Crowe
P.S.  The only reason that I have stuck with Canon and not switched to Nikon, is the 17 TS-E!  I use it for 95% of my architecture/landscape photography.
John Crowe
Just hit "reply".  Sorry if it came up in the wrong place.  I actually wish DPREVIEW would get rid of the staggered reply system...just leave it as replying to the initial post.  Keep it simple.
Steve Balcombe Forum Pro • Posts: 15,582
TS-E lenses have two advantages - staggering image quality and (as you mentioned) the ability to fully compose in the viewfinder. If you had taken the 16-35 shot in similar light to the 17 TS-E, and corrected it 'correctly', the difference could have been very small, such that it would be virtually unnoticeable in a downsampled image.
Another option would to use the EF 11-24, keeping the camera level, and zooming out as far as necessary to fit in the top of the desired frame. Then crop the image to get the final framing. With no Photoshop manipulation other than the crop, this should be identical to the TS-E image except for the lower pixel count - which may or may not be an issue. This is a useful technique if the 11-24 is a better fit to your broader needs, or if you already have one and don't want to further invest in a TS-E lens. Also it can be used to create certain images in a single frame which would necessitate stitching multiple images from the shift lens.
But if you need the tilt function, nothing replaces that.
JackM
I'm not sure, I don't think I would have shot from the street, but perhaps.  Or as has been said, you're seeing the cropping required by the correction.
I should just go out again and shoot it with and without shift.
As I already pay $10/mo for Adobe CC, other software may as well not exist!
Nick5
Nick5 Senior Member • Posts: 1,664
Nicely done hand holding your tilt/Shift. have the 24mm TS-E II tilt/Shift. I always use a Tripod to line up correctly and also bracket -/+ 2. No loss of information.
when I bought the 24 in 2014, I said next year I will buy the 17mm......
I guess it’s next year....
 Nick5's gear list:Nick5's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon TS-E 24mm f/3.5L II +8 more
J A C S
AlbertTheLazy wrote:
Are you sure?
You can follow certain perspective lines and see that.
Sure, I have experienced that as well.
I almost bought the 24TSE after renting it for a while.
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Definitely - if you look at the post in the fence to the right relative to the plant-grill in the wall of the car-port, you can see that you are further back with the TS-E.
Not that that necessarily alters your conclusion, but the further distance sorely make the image look less "squashed and weird". If they has been taken from the exact same vantage point, the perspective and hence "squashed and weird"-effect should also be the same
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
JackM
Not wide enough for real estate.
