R6 observations & test shots (PICS)
Started Aug 30, 2020 | Discussions
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
24
CANON EOS R6 - waiting for the battery to charge
This isn't a "review".
I'll get around to doing one of those later after some other tests. I'm simply passing on my first impressions on the R6 camera. To sum it up:  I like it.  .
Using the EF 100-400mm f/4.5-5.6L IS II USM lens (via the control-ring lens adapter for RF to EF lenses), I literally forgot I wasn't using a full-frame DSLR.  The speed and responsiveness were great and there was no lag in operation while shooting.  Quite a surprising experience.  With the RF 85mm f/1.2L USM lens, the camera caught every single shot of every single subject trained it on.  To speed things up, I'll post my observations in bullet-form below...
Observations from today:
* R6 was used with two lenses initially.
* Battery took over 1.5 hours to charge & was mostly depleted when unboxed.
* After 20 minutes setting preferences, camera was slightly warm.
* Heat was not observed during two days of shooting stills.
* Camera turns on instantly.  There's no delay in startup.
* Camera is very responsive.
* Images were fairly well exposed.
* Joystick will appeal to DSLR users.
* Touch screen is VERY responsive.
* After taking 387 images, there was 76% power left in the battery.
* R6 is thicker than the EOS R but very comfortable to hold.
* Feels solid & well constructed.
* Eye/Face tracking ignored backlit birds.
* Eye/Face tracking ignored my black cat in the dark on black fabric.
* Eye/Face tracking absolutely superb with humans.
* Eye/Face tracking worked well with all three my cats.
* VERY reliable Autofocus.  100% success rate with over 1000 images.
* Control Dial feels firm and solid.  Turns easily (faster than the R imo).
* Nice colors in JPEG.
* Low noise with high ISO.
* EVF is good.
* LCD with Live View was great.
* I suspect that IBIS draws plenty of battery power.
* A second battery is a good idea (I took all my shots with just one).
* 12fps burst rate applied to both lenses I used today.
* IBIS works beautifully.
* No signs of wear on the R6 body paint so far.
* IBIS performed at around 8 stops with the RF 85mm f/1.2L lens.
* LCD playback applies some anti-aliasing that is exaggerated where high contrast occurs on an image.  The images don't exhibit this when downloaded.
* I was aiming at a tree while holding the R6 over my head - my hands shook and I could see this on the LCD screen.  As I half-depressed the shutter, the IBIS kicked in and the scene immediately stabilized.  Impressive to watch (similar to lens stabilization).
Things I didn't like:
* Screen could have been slightly larger but is still excellent.
* Rear viewfinder sticks out almost half an inch from the body.
* Canon didn't ship the BG-R10 Battery Grips with the cameras & lenses.
* Spare LP-E6NH batteries are way too expensive for what they are.
For these sample images that I took today:
* Mechanical Shutter was used.
* I selected "Fine Detail" for my User Defined Setting.
* All images shot in JPEG (I don't shoot RAW).
* All images were handheld (no tripod or monopod needed)
* Images have been lightly edited in Lightroom 4.
* One full sized JPEG is included below.  All others are reduced to 2500p wide.
Afterthoughts:
I really like the R6 camera.  I've opted to replace the R6 branded Canon EOS strap (that comes with the camera) with a slightly wider EOS DSLR strap with no camera model name stitched into it.  A branded strap often causes people to engage you over the model you are using... but several people still approached me to see what I was shooting with and wanted to ask a lot of questions.  Two of them knew of the R6/R5 and were keen to take a closer look.  The camera is small enough to balance perfectly on the EF 100-400mmL II lens, even without the battery grip attached.
Is it worth the additional cost over the R/RP?  Not quite sure of that but it's worth the price if you want a definitive camera that covers most bases.  If you need to upgrade or buy a new imaging instrument like the R6, then this is like a blend between the 5D/6D DSLR cameras.  It handles a lot like a 6D with a vastly improved AF system.  I think it's a significant camera model and the images it produces are excellent.  I imagine it would be hard to go back to a "regular" camera with less features after using the R6.
* (I have more than 10 images to share, but will post a few more in a separate reply below).
EOS R6 + RF 85mm f/1.2L USM lens + Circular Polarizer
EOS R6 + RF 85mm f/1.2L USM lens - Testing eye-detection AF
EOS R6 + RF 85mm f/1.2L USM lens + Circular Polarizer (Full Sized JPEG)
EOS R6 + EF 100-400mmL II lens + Circular Polarizer
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
Canon EF 100-400mm F4.5-5.6L IS II Canon EOS R6 Canon RF 85mm F1.2L USM
Marco Nero
OP Marco Nero Veteran Member • Posts: 7,582
R6 - second set of test shots (PICS #2)
EOS R6 body - waiting for the battery to charge
EOS R6 + RF 85mm f/1.2L USM lens + Circular Polarizing filter
EOS R6 + EF 100-400mmL II lens + Circular Polarizing Filter
Marco Nero.
pkoenig2001 Contributing Member • Posts: 827
Re: R6 observations & test shots (PICS)
Very informative preview and great test shots - really appreciate!  Am anxiously awaiting my R6.  Thanks so much.
 pkoenig2001's gear list:pkoenig2001's gear list
Canon EOS 40D Canon EOS R6 Canon EOS R7 Canon EOS R10 Canon EF 100mm f/2.8 Macro USM +13 more
Sergio17 Forum Member • Posts: 96
Re: R6 - second set of test shots (PICS #2)
Thanks for the review.
Very nice pictures
 Sergio17's gear list:Sergio17's gear list
Canon RF 50mm F1.2L USM Canon RF 70-200mm F2.8L IS USM Canon EOS R5 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +3 more
Marco Nero
Re: R6 - third set of test shots (PICS #3)
EOS R6 - closeup on the Control Dial.
EOS R6 + RF 85mm f/1.2L USM lens + Circular Polarizing Filter - (tiny caterpillar)
EOS R6 + RF 85mm f/1.2L USM lens - (fumbled my exposure manually here @ 60kmph)
EOS R6 + EF 100-400mmL II lens - taken after sunset
Marco Nero.
souvikdgp Regular Member • Posts: 292
Congratulations on R6. Nice shots abd a great quick review. One question, what's your firmware version? I received mine with v1 1.0
See my work @ https://www.flickr.com/photos/souvikchatterjee/
 souvikdgp's gear list:souvikdgp's gear list
Canon EOS R5 Canon EOS R7 Canon EF 85mm F1.2L II USM Canon EF 100mm F2.8L Macro IS USM Canon EF 24-70mm F2.8L II USM +3 more
juanmaasecas Senior Member • Posts: 1,498
Thank you for your writing!
So do you have the R as well? What are your impressions regarding colors compared to that one?
 juanmaasecas's gear list:juanmaasecas's gear list
Canon EOS M50 Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF-M 22mm f/2 STM Sigma 35mm F1.4 DG HSM Art +4 more
Jx9 Regular Member • Posts: 251
Interesting that you only use JPEGs. Is it to maintain Canon colors while still using Lightroom? Do you still fine tune photos in Lightroom?
 Jx9's gear list:Jx9's gear list
Canon EOS Rebel SL1 Canon EOS M50 Canon EOS RP Canon EOS M6 II Canon EOS R6 +18 more
Eddie Rizk Senior Member • Posts: 1,224
Your opinion counts for a lot, in my book.
Does that mean that High Speed Display works with burst shooting with EF lenses on R6?
Interesting.  I have never shot a JPEG since buying my first RAW capable camera.   That said,  I thought about going to JPEGS when I got the R, my first camera with EVF, because of the preview.  Old habits die hard.
How often do you have to adjust white balance?
Do you still edit your pictures much or use them directly as they are?
Thank you for all of your posts.  I look at every one I see.
Your words are always enlightening, and your pictures are a joy to look at.
Eddie Rizk
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
STR54 Regular Member • Posts: 297
The more I see...the more I want. Good to know the body has not suffered the scuffing/smudging/scratching issues as mentioned in another post.  Thanks for the posting and look forward to seeing many more pics from you. Looks like spring in your part of the world.
Mike
Marco Nero
Re: firmware version
Same here.  It arrived with v1.1.0 installed as well.  It seems Canon had enough time to apply this update to most or even all R6s before shipping.  I understand that the people testing the R6 with beta-testing bodies were told there would be an update to be applied.  So most reviewers were using pre-release cameras with v1.0 software.
Marco Nero.
Marco Nero
Re: EOS R6 Colors
I own an EOS Ra - which is almost identical in features to the R but has a sensor that is modified for astrophotography.  I also bought my wife an EOS RP a while ago.  I can't compare the colors with the Ra sensor because it's not suitable for terrestrial photography.  The images can indeed be edited but the process of editing the colors from the EOS Ra is subject to the errors of the person doing the editing.  I found accurate tweaking and editing to be possible for 85% of shots with the Ra... but human skin tones and grey colors from the EOS Ra were problematic.  Which is exactly the reason behind me buying the EOS R6.  If the R6 was not announced I would have bought an EOS R as my terrestrial camera.
Otherwise, the colors from the EOS R6 are excellent.  Typical of 'Canon-look' colors with a high degree of color accuracy and good automatic white-balance applied to JPEG images.  I'm not a RAW shooter but for JPEGS, the color accuracy is so far ideal.   Compared to the EOS RP, the colors are similar although exposure accuracy appears better on the R6.  I also prefer to higher shutter speeds and sensor protection that the EOS R6 offers over the RP.
Marco Nero.
Marco Nero
Re: JPEGs
I've always been a JPEG shooter and this goes back to the times when Canon was only just starting to include RAW on their earlier digital cameras. I've used RAW on rare occasions although I may be tempted to experiment with RAW again on the EOS R6 because I do like what the sensor is capable of resolving.
Canon caught my eye when they said that the R6 was going to appeal to people who enjoy shooting in JPEG because that was something I hadn't expected them to draw attention to.  It's probably to do with the way the DiGiC X chip processes the images internally.  It was a bit hard to rate contrast and Dynamic Range when I was using a CPL filter or shooting with ISO 50.  I do still tweak image in Lightroom before resizing in Photoshop... but I did notice that the images needed very little color correction.  Only images of white ceramic plates under multiple light sources needed a slight nudge to correct them slightly.  I didn't really need to enhance any colors either.  I certainly didn't need to apply any sharpening and only one of the images I took was processed later for Noise Reduction... and even then, I had to think about whether or not I even wanted to apply it to that picture.  Any noise that showed in higher ISO shots was even and easily removed if you felt a need to do so.
With the EOS R6, I felt that my choice of "Fine Detail" in the User Defined Settings produced just the tiniest bit of anti-aliasing with the sharp edges against high contrasting subjects.  It wasn't too bold but I noticed it when viewing a couple of image at 100%. An example is the Moon photographed against a blue sky... which has a subtle amount of artifacts from presumably the "sharpening" levels applied by the camera. Since this is adjustable, I will attempt to tweak this setting slightly later today.  There is also a "CLARITY" slider below the User Setting.  I may drop the "clarity" down one notch to see if this has any notable effect.  I would consider these slight artifacts to be fairly normal with edited images or even images downloaded from the camera that have been subjected to in-camera processing.  Overall, I thought that the sharpening was just fine.  I did note that on the LCD, when zooming into an image during playback, that the anti-aliasing was enhanced and made to look stronger than it was when the image was finally downloaded later.    For example, a shot of a crescent moon against the blue sky a couple of days ago looked over-sharpened on the LCD during playback, but was perfectly normal when downloaded.  Out of the nearly 1000 photographs I took yesterday, I only adjusted the anti-aliasing on one photograph of the moon (see down below) and one of a bird at sunset.   I found this to be more than acceptable.  If someone like a journalist was to travel with the R6 to remote or rugged locations, I believe they'd be more than happy with the image quality and camera performance.
An example of antialiasing on the curved edge of the moon - which is subtle but correctable (both with camera settings for sharpening and with PP software like Photoshop).
Many years ago, JPEGs were quite primitive and a lot of the useful data was baked out of the files. In more recent years (the last decade), more and more professional photographers have been choosing JPEG over RAW simply because the cameras were producing good results with their processing engines. There's still some very useful applications for RAW files although the JPEGs from modern cameras still include enough data for recovering details lost in highlights or lifting details from shadows.  People shooting RAW all the time might not be aware of this.
The EOS R6 also has the ability to capture files in HEIF (High Efficiency Image File Format) instead of JPEG.  This is quite interesting because it will allow for images more suitable for display on HDR monitors and televisions.  HEIF files are said to be more compressed than JPEG but "open faster" and can contain even more useful data. The Canon EOS 1DX III was the first Canon camera to introduce HEIF files in the Canon family and the R6 uses the same sensor (with a different anti-aliasing filter).  Since HEIF contains 16-bit data (instead of 8-bit), there's a lot of room for editing if you're destination is a HDR device.  I'll get around to playing with HEIF files later.  None of the mainstream web-browsers offer native support for HEIF files (at this stage).  They will also convert HEIF to JPEG in many instances when uploading.  But it's very interesting to have this technology on the R6.
A 100% crop of the moon from yesterday.  The high contrast edge was edited very slightly to reduce the anti-aliasing that was visible when enlarged.
Going back over the images I took yesterday, I think that the results were more than pleasing to my eyes.  I still have to spend more time with the camera before writing a "user/owner review" on it. But so far it's demonstrating appealing results.  I was also expecting the camera to heat up during use but that didn't seem to happen at all.
Marco Nero.
Marco Nero
To: Eddie Rizk
Thank you.  I prefer to review cameras from a 'user perspective' and to try to describe the experience rather than get embedded in technical details that might not be of relevance.  Comparisons can help others to decide if they might like or dislike something. Talking about how cameras compare to one another is only useful if someone else is familiar with the comparison model.  I'd prefer to describe how a camera feels and whether the design or menu is economical to the user. Incidentally, when I first took the R6 outside to try, it reminded me of apiece of IKEA furniture that had been tightly assembled.  Everything feels solid to the touch.  The only weak point is probably where the LCD is hinged to the body.  Most other non-DSLR cameras feel like a piece of furniture that was hasn't had all the Allen Screws tightened and they rattle or handle quite differently.  The R6 fits into the hand well and feels balanced. The deeper body dimensions (presumably to house the IBIS mechanism) gives the camera a heftier feel.  I certainly appreciate the Control Dial although the Top-LCD from the R cameras (and the R5) look visually appealing.  The Control Dial on the R6 is decisive when you change settings.  It's firm and less prone to critical damage like the Top-LCD is.
Are you referring to the 'Display Performance' or the 'High Speed Display' (both of which seem to work fine with the EF lens that I was using)?  I thought there was a way to change the refresh rate of the EVF but I can't seem to find that option now.  There's a Power Saving option for the EVF which made little mechanical difference when I used it.  I've left that option set to "Power Saving" instead of "Smooth" (which uses more power).  Either way, I had the EF lens on when using these features and noticed no restrictions.  Let me know if there's something you need to to check.
From the EOS R6 User Manual re: EF/EF-S lenses supporting 12fps continuous shooting.
I was shooting in bright daylight/sunlight and switched repeatedly between the EVF and the LCD screen and at no point do I recall noting any lag whatsoever.  There's an extremely brief blackout but it's not different to the effect of a DSLR mirror flipping up.  It's literally that brief.  And I didn't notice a flicker as the shutter is held down either.  Just that initial first shot seems to trigger a slight flicker/blackout for a fraction of a second.  Since I had the Mechanical Shutter active (it ships with the Electronic 1st Curtain shutter active), I was interested to see what the performance was with H burst mode on.  It was VERY responsive and the shutter was still incredibly quiet in Mechanical Shutter mode.    It's almost a "whisper" as it fires. Sounds "classier" than a lot of other cameras.  I had to check to see if I was using the Electronic Shutter because it's so quiet.
They certainly do.  I'm going to have to convince myself to try to sample from RAW shots from this sensor.  I have no doubt it will perform very well.  The DiGiC X processor does a good job of rendering JPEGS so far.  I might need to update some of my software to run the new Canon RAW file.
In the last two days with the R6 I just left it in AUTO WB mode.  I didn't need to adjust the WB at all with the camera whilst shooting over the last two days.  If the weather was overcast, I might have had a reason to change it.  Overall, it adapted to sunlight, lowlight, incandescent light, candle light and several LED light sources without a need to change the White Balance at all.   That's probably ideal although I rarely bother changing the WB on my other cameras either.  Shooting a lot of greenery or under overcast conditions will sometimes prompt me to change the WB.  I guess I could have selected "Daylight/Sunlight" from the WB options for some of what I was shooting yesterday.  Either way, the R6 did a respectable job with AWB.  I did edit an image of some prawns on a plate by reducing the yellow and increasing the blue (for the white ceramic plate) when editing in Lightroom.
I tend to tweak most image slightly in Lightroom - and as long as I'm not saving "copies of copies" then there should be no image quality loss beyond the original clean JPEG file that was downloaded ... but I noticed that the JPEGs from the R6 didn't require much work (if any) at all.  Normally I'd lift the shadows to reveal a little detail in some shots... but that wasn't necessary with any of the images I took with the R6. The same applies to Noise Reduction as well.  I found one image that I was considering applying Noise Reduction to and when I looked at the ISO settings in the EXIF information I noticed that it was taken at ISO 5000 (which was a surprise).  I hadn't even noticed that I was shooting with too-high a shutter speed, hence the high ISO for that shot.  There were only two shots out of around 1,000 that I considered applying NR to.  No sharpening was needed since the camera's DiGiC X chip handled that.  So overall, there wasn't much for me to do other than resize.  None of the highlights were overly exposed and the contrast from this sensor and both lenses was fine.
I will almost certainly shoot some JPEG+RAW images with the R6 and I expect the results to be good from this sensor.  If I go up to the mountains I'll probably take some RAW shots just to see what details I can extract later.  This is a very likeable sensor and I can see why it was selected for the 1DX III.
I'm just happy to share what I experience.  The good folks here on the forums have been incredibly helpful to me in the past and the individual experiences of others here have influenced some of my own purchasing decisions in the past.  Usually I'll made a decision based on the specs offered by the manufacturer but it's the experiences of others that tells you if you're going to like or dislike something after you buy it.  I do feel that Canon are pushing prices up with their new models (cameras, batteries, lenses, accessories etc).  As sales for camera drop with the improvements offered in Smart Phone camera tech, it's probably necessary for these camera companies to push up prices to cover losses.  At least we're getting "some bang for our bucks" with the latest installments.
Marco Nero.
Marco Nero
To: STR54 - R6 body paint Resilience
STR54 wrote:
The more I see...the more I want. Good to know the body has not suffered the scuffing/smudging/scratching issues as mentioned in another post. .... Looks like spring in your part of the world.
Mike
Hi Mike,
I saw that post about the R5 suffering terrible paint & rubber loss.... and it gave me the chills because I'm concerned that Canon changed their coating methods for the R5/R6 after seeing the damage that author encountered.  Whilst it's too early to be certain that this was a one-off, I can say that my R6 body came in contact with paper, metal, leather, wetsuit rubber, rings, plants, a tree, a stainless steel watch, 7 different wooden tables, my M6 camera and also the Peak Design metal (aluminium) mounting panel on the ProPad belt mount that I was wearing.  None of these impacts were particularly hard.  These impacts were light and I was careful not to abuse the camera.  But I see no sign of wear, marks or damage to the camera's body surfaces.  I even dropped lime-chili sauce onto the rear of the LCD screen ... which was a little harder to remove than I thought it would be due to the slight "powder-coating" texture on the camera surfaces. I'll be watching very closely to see if any damage occurs in future.
Indeed it is spring here.  Those Cherry Blossoms bloomed a week earlier than usual. Tomorrow is the first day of spring in Australia.  I'm located near Sydney.  Normally Canon tend to release and ship new cameras during our pre-winter rainy season so this is a pleasant change.  I sure hope we're not subjected to more horrific fires again this year.
Marco Nero.
Re: To: Eddie Rizk
With the EF 100-400 II, the R is very responsive in single shot mode. When using continuous shooting or burst mode, there is a "slide show" effect that make tracking moving objects difficult. There is a high speed display setting that supposedly eliminates the problem on the R but only works with RF lenses.
From what you wrote, it sounds like the R6 just solves the problem without aggravation.
After three years, I'm still super happy with my 100-400 and would not have considered replacing it except for that one problem. From the charts I've seen, it's optically competitive with the 100-500 and also, with the TC 2X III, optically competitive with the RF 800.
IBIS would certainly help some of my shots. Lower light capability is something I push the limits of at events. The R6 is $200 US cheaper than the RF 100-500, and adds a lot more functionality with its other features, so it's starting to sound like a pretty good value.
Do I really need anything right now?  No.  Should I be spending a bunch of money this year?  No.  I might have to get it anyway.
Thanks again.
Eddie Rizk
Formerly "Ed Rizk"
JackiePan Regular Member • Posts: 136
Thanks for very detail review, which makes me more confidential to switch to R6.
One question, will R6 still provide burst shoot after battery going down 60%.
J.
 JackiePan's gear list:JackiePan's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EOS-1D X Mark II Sony a7R III Canon EOS R5 +5 more
Marco Nero
To JackiePan - Burst Performance w/battery under 60%
J.
It's Day 3 and I only took a few pics today to test the IBIS capability in low light.  But my battery is now at 66%.  I'll do some testing with a flash shortly to drop the charge below 60% to enable me to test the burst difference.  Presumably Canon were accurate in their description of performance changes.
I'll post back here when I have an answer later this evening.  Presumably the camera will slow down.
Marco Nero.
aeronium Regular Member • Posts: 143
I would say this might be a pro rather than a con, if you use touch to drag af often. Lower chance of hitting your nose
 aeronium's gear list:aeronium's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EOS R5 Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM +10 more
Bassman2003 Senior Member • Posts: 1,798
Thanks for your thoughts and nice images.  This shows the R6 in a very favorable light.
