Low GX7 Video Playback Volume
Started Aug 29, 2020 | Discussions
SC489 Senior Member • Posts: 1,577
I haven't used my GX7 for video recording for a while. The video playback volume on the camera is low despite the volume control being at maximum. Playback volume is fine when I copy the file to a PC. Is this low playback volume typical of the GX7?
 SC489's gear list:SC489's gear list
Sony Cyber-shot DSC-HX80 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
JakeJY Veteran Member • Posts: 5,442
Re: Low GX7 Video Playback Volume
I presume volume is all the way up using the rear dial when playing back.
You can also check your speaker volume in case that is independent.
[MENU/SET] > [Setup] > [Speaker Volume]
As for general playback volume levels, others with GX7 would have to answer (I only have GX85).
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
OP SC489 Senior Member • Posts: 1,577
Yes, the camera volume settings are at max.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Just a thought. The gx7 is a very old camera now, check the little microphone holes are not blocked with dust. Our home starred to go very quiet and dust blocking the speaker holes was the culprit.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Six years is not 'very old' for a camera by my standards. My 1968 Pentax Spotmatic still works.
Adrian Harris
Ah but 6 years of dirt is definitely old dirt
.. . except for new shoes every couple of years when mine have worn through, cameras - and occasional a lens to complete a range - are probably the only new things I ever buy. My 'new' car is 2007, only bought digital TV because they switched the analogue signal off. And horror of horrors my smartphone is 7 years old ...and I only bought that to trigger the GX7 remotely
