EOS R5: Customize the Rate Button
Started Aug 28, 2020 | Polls
DemolitionMan14 Forum Member • Posts: 68
Currently you can customize all the buttons on the camera except the "Rate" button.  In my opinion the least used function.  Do you want canon to give use the ability to customize the "Rate" button?
 DemolitionMan14's gear list:DemolitionMan14's gear list
Canon EOS 6D Canon EOS R5 Canon EF 8-15mm f/4L Fisheye USM Canon EF 11-24mm F4L Canon EF 16-35mm F2.8L III USM +1 more
POLL
Yes
96.1% 49  votes
No
3.9% 2  votes
  Show results
Canon EOS R5
RedYeti Regular Member • Posts: 311
Re: EOS R5: Customize the Rate Button
If you go to the blue menu #4 you have some (very limited) ability to customise it. I suppose this special customisation is why it doesn't appear in the generic button customisation menu.
 RedYeti's gear list:RedYeti's gear list
Canon EF 800mm f/5.6L IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 100-400mm F4.5-5.6L IS II Canon EOS 5D Mark IV Canon EOS R5 +5 more
Christian Leibig New Member • Posts: 22
I'm not opposed to more configuration, but for me I always set the rate button to "protect". When out in the field I can quickly mark individual pictures from a burst as keepers and after that tell the camera to "delete all pictures on card" (which will just keep the protected pictures). But yeah, that button would be prime real estate for some often used function if your workflow is different.
RichW Forum Pro • Posts: 12,933
I set mine to delete images...
Works for me...
 RichW's gear list:RichW's gear list
Canon EOS R5 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM +7 more
French Fry Regular Member • Posts: 196
This is one of the many suggestions people had over at Canon Rumors for this thread:
https://www.canonrumors.com/forum/threads/dear-canon-r5-and-r6-firmware-upgrade-and-feature-requests.38815/page-4
It would be great if you would log your interest in this feature or any others with Canon, so they receive and act on valuable user feedback.
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Christian Leibig wrote:
I'm not opposed to more configuration, but for me I always set the rate button to "protect". When out in the field I can quickly mark individual pictures from a burst as keepers and after that tell the camera to "delete all pictures on card"(which will just keep the protected pictures). But yeah, that button would be prime real estate for some often used function if your workflow is different.
How do you do that?
Joe
tifa3 Regular Member • Posts: 167
The rate button is useless for me. Let us customize that button to whatever we want.
PicPocket Veteran Member • Posts: 5,897
Re: there is always one
This just seems like an endless thing with every camera I have owned - a button that never gets any use
My 400D and 7D had the print button
5D II, 5D IV and now R5 have the rate button
OK, maybe not all. I have a M50 too, and it just have too few buttons to have a useless one
And I'm curious if someone would vote no for this poll
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Its pretty customize-able as is
I actually use it, but in reality... the camera is so customize-able I don't see a need to make that one button anything else.
Have there been any recent Canons that had the ability to customize half as many buttons? (Question more out of curiosity than making a point)
Mike Jackson - Wildlife Photography Enthusiast
https://www.flickr.com/photos/mj_flickr/
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Hoka Hey
How do you do that?
Never mind. I found the "delete images" in the Play menus. I have never used those menus as I typically just dump everything to Bridge and  cull from there.
Your suggestion works well for the field when you have to shoot numerous images to get one keeper.
Joe
OP DemolitionMan14 Forum Member • Posts: 68
We actually have 2 "No" votes
I wonder if that is because there was no "I'm indifferent" option. I'll probably remain curious about why anyone is opposed to this
Tazz93
I'm one
I said no because there is no good reason to waste resources on it. If it could be done without a cost to other more pressing issues, sure... why not... customize your buttons until your heart is content.
Re: I'm one
Fair enough... nothing is zero cost. even this comment was some effort to type in. But in all fairness, I don't know the cost. I guess they did spend resources making so many buttons customisable. Hopefully, they learned enough to make that a trivial thing by now. Or maybe not... I don't even know the reason why that button isn't customisable while many others are. I guess that was the point of the OP... ask canon, and see how they feel about it. They will be in a better position to weigh the effort
For all I know... it may just be that buttons mappings are just stored in a LUT and they just need to include this one - a minor code change. Or it can be more complicated where the LUT has a fixed size they might have exhausted already. Or something as impossible as this button being wired very differently at hardware level
Only canon may know. I can only say whether I would like it if it can be done
