EOS R5: External Battery USB-C Power
Started Aug 28, 2020 | Polls
DemolitionMan14 Forum Member • Posts: 68
The EOS R5 has the capability to charge batteries via the USB-C port.  I keep a fully charged Anker USB-C Power Delivery (PD) battery pack with me to charge batteries in the field.  It would be great to be able to plug the camera in and use power straight from the external battery.  Is this a desired feature?
 DemolitionMan14's gear list:DemolitionMan14's gear list
Canon EOS 6D Canon EOS R5 Canon EF 8-15mm f/4L Fisheye USM Canon EF 11-24mm F4L Canon EF 16-35mm F2.8L III USM +1 more
POLL
Yes
100% 26  votes
No
0% 0  votes
  Show results
Canon EOS R5
Noah M Regular Member • Posts: 128
Re: EOS R5: External Battery USB-C Power
From what I read, is the camera will charge if powered off.   And you want to do that when not in use anyway to keep the camera cool.  But it won't power the camera.   Is all this true?
OP DemolitionMan14 Forum Member • Posts: 68
Correct.  It will charge when powered off, but will not Power the camera.
sobrien
sobrien Senior Member • Posts: 1,756
Canon claims for the R5 and R6:
“Ability to operate and shoot with the camera while charging with Power Adapter PD-E1 is possible.”
As opposed to the R and RP which are “charging only”.
Maybe your PD device isn’t powerful enough?
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
I should have been more clear.  I would like to be able to power the R5 using any USB-C PD charger and battery pack.  Not just using the overpriced Canon PD-E1 Adapter.
gazza73
gazza73 Senior Member • Posts: 1,015
If the R5 can be powered with the PD-E1 adapter I'd assume as long as the specs of the power bank match the requirements it should work. As far as I'm aware, as long at the camera receives (enough) power it probably can't distinguish if it is via battery or wall adapter.
MarshallG
MarshallG Veteran Member • Posts: 8,951
USB-C PD doesn't work that way. There are a huge varieties of voltages and amperages which a charger can provide, so your wish for "any" isn't going to happen, just as you can't power your laptop from "any" USB-C charger. I think it's too early for us to know what features the USB-C PD charger will need to support in order to support live power, but in my opinion, it's better to have a solution which provides charging/power at the same time, even if it means the camera draws from the battery as it charges. This way, if your cord is ever disconnected, the camera keeps working.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
gazza73
Does anyone with a PD-E1 care to share a photo of the back of the adapter or copy down the specs to see what output it has?
sobrien
It works with my Anker power pack (Anker PowerCore+ 26800 PD) without issue.
iazybandit Contributing Member • Posts: 655
The Power Adapter PD-E1 requires a wall outlet. Great if you're in a studio setting but if you're out in public where there is no outlet, its useless.
 iazybandit's gear list:iazybandit's gear list
Canon EOS R5 Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM +1 more
(unknown member) Regular Member • Posts: 328
Specifically:
1) does it charge battery when R5  is powered off ?
2) Does it allow camera to operate without the battery or when battery is depleted ?
3) Does it allow R5 to operate and charge battery at this same time ?
Thanks for answers,
awaiting my R5 delivery... impatiently.
/kleks
I have the Anker PowerCore Slim 10000 PD, USB-C Portable Charger (18W), 10000mAh Power Delivery Power Bank and it will charge the LP-E6N when the camera is off. However, when I turn the camera on it does nothing. It stops charging the LP-E6N and doesn't not deliver power to the camera. Does your Anker power pack (Anker PowerCore+ 26800 PD) continue charging if the camera is on?
gazza73
USB charging on the R5/R6 works by charging the battery when the camera is off and powering the camera ONLY when switched on. There must be a battery in the camera when powering via a power bank according to Canon
sobrien
Specifically:
Yep.
Nope, there must be a battery in the body.
I have not checked this though I’d assume not given the need to have a battery in. It works with a nearly dead battery though so you might be able to turn it off and give the battery enough of a charge to get going.
Nope, when it is powering the camera it is not recharging the battery.
Thanks for answers,
/kleks
sobrien
It powers the camera, but does not charge the battery.
It does not appear to deplete the battery though I guess that that might vary depending on your use case. I just did a test where I recorded video for 20 minutes straight, with the rear screen turned on, and the battery remained at the same percentage.
Nick5ter New Member • Posts: 8
Needs to be 45watts from what I can see, my 45W PD powerbank works fine.
Also appears that H+ is disabled in this mode when in photo mode
 Nick5ter's gear list:Nick5ter's gear list
Canon EOS RP Canon EOS R5 Canon EF 100-400mm F4.5-5.6L IS II Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +3 more
Larawanista
Larawanista Veteran Member • Posts: 4,736
My R, RP and M6II all can charge via USB type C. If only they can charge while being used!
"Photography is therapeutic."
https://500px.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
DBWi New Member • Posts: 1
I just received my R6. I’ve been following this and other similar threads and I’ve been unable to find out exactly what type of charging cable one needs to plug into the round port in the camera. can anyone help?
R2D2 Forum Pro • Posts: 26,531
Don't plug any power source into any ROUND ports on your R6. BIG - FLASH - GO - BOOM!
If you're talking about the elliptical USB-C port (actually a geometric "Stadium" shape), then you need a USB-C cable with PD capability. PD cables are special "chipped" cables, and are widely available.
R2
Rons DP Account New Member • Posts: 5
Hi
The charging capabilities of Canon batteries are years out of date. A fact made worse by Canon mirrorless cameras being particularly heavy users of power.
Phones with large batteries charge in about an hour with USB C high speed charging. Not available for charging Canon batteries. Why not? Canon chargers are still very old micro USB.
You can plug in a USB C power pack to your Canon camera and as long as it is switched off (i.e. not being a camera) it will charge! Who at Canon thought that was a good plan? Surely a power pack should allow us to use the camera for hours? The fastest I have charged a battery is still over 5 hours; unacceptable. It's particularly unacceptable as on a cool UK day with settings set to low power (except I do always use the viewfinder) I get as few as 170 shots from a genuine Canon R5 battery.
Thanks for reading.
Ron
 Rons DP Account's gear list:Rons DP Account's gear list
Canon RF 14-35mm F4L IS USM
