Olympus 100-400 - first shots and impressions
Started Aug 27, 2020 | Photos
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
Re: Olympus 100-400 - first shots and impressions
galenapass wrote:
Hope springs eternal.
I've got these magic beans, I'll let you have them for your cow
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
OP Astrotripper Veteran Member • Posts: 8,676
Aperture vs zoom
For those curious about aperture change while zooming:
  • f/5.0 - 100mm
  • f/5.6 - 140mm
  • f/6.0 - 210mm
  • f/6.3 - 330mm
So this is another big drawback compared to PanaLeica 100-400, which if I remember correctly is still f/5.6 at 300mm. So Panasonic starts 2/3 of a stop faster at the wide end and is still 1/3 of a stop faster near 300mm mark.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Brian Wadie
Re: Aperture vs zoom
forgive me asking in you thread, has anyone spotted a difference in IQ / noise using different software to process raw images?
I'm seeing a lot of noise in OOF areas via LRCC even with ISO 200 yet the same images appear clean in ON-1 RAW 2020
I wonder if they need to update LRCC? (or I may be losing my marbles again)
Isn't it because Lightroom applies excessive sharpening by default? Sharpening noise seems to be the default behavior (I'm assuming Bridge uses similar defaults).
allematic Regular Member • Posts: 475
Olympus Workspace gives the best results for me. Considerably less noise and more detail at the same time.
mikero
mikero Veteran Member • Posts: 3,057
I've turned sharpening off in LR, now that I'm using the Topaz DeNoise AI plugin.
But before I started to use Topaz, I'd reduced the default sharpening in LR from 40 to 25.  I found 40 worked quite well with my Canons, but the Olympus doesn't have an AA filter so needs less input sharpening.
YMMV.
Mike
 mikero's gear list:mikero's gear list
Olympus E-M1 II OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
Brian Wadie
good thoughts all, my mind is a bit addled at the more with my cancer treatment so I must spend a bit more time thinking and looking at this, so I appreciate your help
Brian Wadie
one quick improvement by removing the adobe presets and using camera presets as default start point in preferences
Video IS test
A short demonstration of how the combination of IBIS, Digital IS and OIS works for video: https://vimeo.com/453068326/381972e606
Brian Wadie
Re: Video IS test
looked OK to my old eyes?
stevevp Contributing Member • Posts: 700
Re: Video IS test
What focal length please and is this hand held?
 stevevp's gear list:stevevp's gear list
Olympus E-M5 II Olympus E-M1 II OM-1 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +6 more
Re: Video IS test
Handheld while kneeling, 200 to 400mm. So far my conclusion is that enabling OIS only makes sense if you want to keep the scene static, as it will fight against any panning you attempt, resulting in jerky motion (also seen in one of the clips, despite the panning being slow)
I'll do a more methodical comparison one day, but probably no sooner than next weekend.
User5456214890
User5456214890 Contributing Member • Posts: 557
I haven't yet met a camera or lens that did not require some form of "learning curve". So in that regard I'm optimistic. Looking forward to a little more learning.
Jim
"There are some who can live without wild things and some who cannot." Aldo Leopold.
 User5456214890's gear list:User5456214890's gear list
Olympus PEN-F Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +4 more
Brian Wadie
Jim
sometimes the problem seems to be that we have trouble learning that
