What creates the high contrast in these images?
Started 5 months ago | Questions
whosthatwhatsthat Forum Member • Posts: 84
Hello everyone,
I've been loving the work of Steve Hiett here are a few of the images I found of him behind the scenes and the resulting images.
What are the lights he's using on that rig? Looks like two strobes with norman beauty dish reflectors? also what on earth is that rig called?
These low res BTS images it looks as if he is using a ring flash? if so what ring flash? and why on a campaign of the same shoot has he swapped lighting setup???
I've also attached two other images of his work - the one in the phone box appears to have the reflection of the same lighting setup.
Do you think the image of the lady with the handbag is the same lighting setup?
Would these come out the camera looking close to this and then he's just upped the saturation and contrast?
robgendreau Veteran Member • Posts: 7,792
Re: What creates the high contrast in these images?
You need the added light. Try high speed sync flash if you have a flash that can do it.
Gerry Winterbourne Forum Pro • Posts: 18,204
whosthatwhatsthat wrote:
Hello everyone,
Possibly but very unlikely. Having spent so much effort on lighting, composition ant taking the shots it's far more likely that as much attention has been paid to processing.
Gerry
________________________________________________________________________
I'm happy for anyone to edit any of my photos and display the results
_________________________________________________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
gerry.winterbourne@ntlworld.com
