Anyone in the US buy a RF 70-200 2.8 IS recently?
Started Aug 21, 2020 | Questions
Brand New Regular Member • Posts: 306
Bought a RF 70-200 2.8 IS a few weeks ago, and have had some strange, intermittent AF issues. It's not at MFD and I did update the firmware to the latest, but I still need to test more to confirm if it's the lens, the R5, or the operator.
My question for now is if anyone who has bought the lens in the past few months could share the first two digits of your RF 70-200 serial? I purchased mine from a very large retailer, who I thought would sell through their inventory and re-stock fairly often, but my serial indicates that the lens was produced about 9 months ago. That makes me wonder if it was a faulty return that accidentally slipped back in, or if it really has been just sitting in the warehouse for over half a year.
Canon EOS R5 Canon RF 70-200mm F2.8L IS USM
tifa3 Regular Member • Posts: 167
Re: Anyone in the US buy a RF 70-200 2.8 IS recently?
what do you mean by intermittent AF issues? and how can you tell how old the lens is by the serial?
OP Brand New Regular Member • Posts: 306
It misses the focus in instances when it shouldn't, and it's happened multiple times (i.e. non-challenging scenarios where my 1D4/5D4 and EF 70-200 2.8 IS II always hit). But I haven't used the RF (nor the R5) enough to rule out anything yet, which is why I just want to determine if the lens I got was possibly flawed/a return.  If a few other people recently got RF 70-200s that were produced last year, that would ease my mind a bit
As for lens dating: https://www.the-digital-picture.com/Canon-Lenses/Canon-Lens-Aging.aspx
The lens became available in December 2019 so there shouldn’t be that many old stock though.
Mike Mulaw Forum Member • Posts: 70
The R5 does not have any cross type AF points so there are some scenarios where the R5 will not find focus that the DSLRs would. Could it be that these situations only have contrast in one direction?
Thanks for the suggestion, but there's good contrast in both directions, so I don't think that's it. Like I said, I need to do more testing to rule some things out, but I'm hoping someone will chime in about the serial numbers. But I may be exchanging the lens anyway, since it came with a fairly big piece of dust or some other debris speck inside as soon as I pulled it out of the box (part of the reason it feels like a return...with the other being the old production date).
Mine was purchased in January, and has a date code that looks like October, 2019.  I have had no issues with mine focusing.
My serial number starts with 83. I’m assuming that means November 2019? No issue focusing at all with the R5.
Tony Defriez Regular Member • Posts: 192
To answer your questions:
  • No issues
  • 82
But how do you tell the year it was made from these 2 numbers?
If you believe the first 2 numbers are the year this make mine built in 82 and an RF35mm 1.8 lens, I have, built in 69!
The serial number may have the date buried in it but it will be coded (not as clear date by as encoded date with Canon only knowing the key)
  • No issues
  • 82
Here is the decoder key:
  • No issues
  • 82
Thanks Tony. 82 would be October 2019 and 69 is September 2018. The production can be ascertained via: https://www.the-digital-picture.com/Canon-Lenses/Canon-Lens-Aging.aspx
Do you remember when you got the 70-200?
Thanks Mike!
shawnphoto Senior Member • Posts: 1,307
Define missed focus. Is it just barely missing or is it way off? Can you post an example?
You can probably send it to Canon and they'll fix it. Might be better than playing the lottery with the dealers again.
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
Not way off, but not too close, either. It definitely isn't a motion blur/shutter speed issue. I just sent the lens back, anyway, because I think the speck of debris inside the lens is going to bother me down the line, AF issues or not. It doesn't quite look like dust, since it's a little big and somewhat shiny, and a brand new lens shouldn't have that straight out of the box. Hopefully the replacement is fine, but if I have the same AF issue, I can pretty much rule out it being the lens (or it's confirmation that I have the worst luck). Thanks
CanonshooterRF212 Contributing Member • Posts: 503
Which retailer?
 CanonshooterRF212's gear list:CanonshooterRF212's gear list
Canon EOS R Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
