Godox AD200 flash
Started Aug 20, 2020 | Discussions
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Godox AD200 flash
Is there anything that I need to know about connecting, by cable, a Godox AD200 flash Please ?
Using a flash is all new to me, so I don't want to damage anything.
I have the Godox AD200 & the cable. I want to use it with a Sigma SD15 & SDQ.
Sigma SD15
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Godox AD200 flash
Colin,
As far as damage is concerned, it is said that "older" flashes with high trigger voltages can damage modern cameras. I looked for your flash model here but Godox is not listed. There may be other lists where it is.
I suggest that you plug the cable into the flash but not the camera, turn the flash on, wait for the ready light and then measure the voltage at the camera end of the cable. Maybe teaching Granny to suck eggs but a steel paper-clip is often handy to access those little round connectors' center terminal.
If the voltage is less than 15VDC I would be tempted to try it on my least favorite Sigma BUT it's your call.
HTH.
There are more ways than one to skin a cat ...
Seba Smith - The Money Diggers, 1840
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
SigmaTog,
The Godox AD200 is a modern flash and should be ok with your cameras or any current cameras.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Jim Roelofs Regular Member • Posts: 162
Another way would be to use a wireless flash trigger setup.
Sincerest regards, Jim Roelofs
You're invited to visit my humble portfolio @ pbase.com/jrdigitalart
Tame birds sing of freedom, wild birds fly. (John Lennon)
"whatever the system wants – we oppose – whatever the system opposes – we want" Mao
SigmaTog
OP SigmaTog Senior Member • Posts: 1,114
Thanks Gentlemen....seems I am imagining that things were more complicated then this ?
I'll just give it a try....
atom14
atom14 Veteran Member • Posts: 3,301
Ta, I'd be interested to know, ∑Tog. I've got a Metz 45 that I HAVE NOT yet used on the SD1M, so I'll be:
Waiting for Godox!
atom14.
Notomb
Notomb Regular Member • Posts: 182
Godox AD200 is a off-camera Flash, use with cable? Why?
 Notomb's gear list:Notomb's gear list
Sigma sd Quattro Panasonic S1 Sigma 35mm F1.4 DG HSM Art Sigma 30mm F1.4 DC HSM Art Sigma 18-35mm F1.8 DC HSM Art +5 more
xpatUSA
Because it is off of the camera.
Ted
SigmaTog
That is exactly right thanks Ted......
I want to use a cable for simplicity & so I don't need the XPro trigger, $$$.
See this is what I am trying to understand & learn, these triggers seem to only fit specific brands of cameras & none say Sigma.....??
Notomb
Hahaha. very nice-
And AD200 in a Hand, Diy Staff on body?  Or Five meter of cable in a stand?
xpatUSA
Hahaha. very nice-
xpatUSA
withdrawn as unhelpful n/t
Lynxo Contributing Member • Posts: 522
Hi,
I just bought the Flashpoint R2 Single Pin Transceiver, works with any camera. I will be using it with my DP3Q. I have the FP AD200 and FP Round Head Flash for Fuji.
All manual on the sigma’s but nice thing with the Godox/FP, when you set flash level on the R2 Transceiver, it will set it in the flash heads so you don’t have to be physically near the flash. Just did some quick tests few days ago and it works great.
xpatUSA
Lynxo wrote:
Hi,
Hi, glad to hear it but I don't own a Godox or a Quattro.
Ted
