NX20 Samsung error message 00
Started Aug 18, 2020 | Discussions
Burniejim New Member • Posts: 4
Hi, I'm in need of some help and I'm hoping someone has the answer for me.
my Samsung NX20 is about 7 years old and I have never had a problem with it until recently when I accidently dropped it from about 1 mitre height onto a carpet with  concrete underneath. This resulted in the shattering of the UV lens screwed to my 18-55 lens mounted at the time. There appears to be no other physical damage but now when I turn the camera on I get the Error 00 and the camera shuts down. I'm guessing that the problem is with the camera body because I get the same result when I mount my 200 lens.
I would appreciate any suggestions.
Thanks in anticipation.
Samsung NX20
kypfer Contributing Member • Posts: 985
Re: NX20 Samsung error message 00
You may have damaged the contacts in the lens throat. With the lens removed, examine the contacts in the throat of the camera with a magnifier or loupe for any obvious damage.
If you have an adaptor to use other manufacturers' lenses, (M42-NX, PK-NX or similar), fitting this should bypass the contacts and may help indicate the problem.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Burniejim New Member • Posts: 4
You were spot on with your suggestions. Under the magnification of a loupe I found a minute piece of gold metal from one of the posts but it hasn't fixed the problem.
As you suggested I tried a generic attachment which bypassed the connection and that gave me access to camera adjustments. From suggestions I found on line I tried without result to get access to the "system parameters" so I could homely fix my problem via the "no lens release enable" setting but using the suggested guide I can't access it.
Any further suggestions would be much appreciated.
No further suggestions, I'm afraid. I use my NX5 solely for legacy lenses, mostly Russian M39 rangefinder lenses, so these symptoms wouldn't affect me
You could consider offering the body for sale on eBay or similar, with specific reference to the fault symptoms. Someone may be interested for spares or indeed as a legacy-only body. Any cash generated could be put towards a replacement body. If you do decide to sell up completely, list the body and lenses separately, you'll likely make more like that
Good luck
Thanks for that advice. The more I research, the more I find that Samsung seems to have come up with a great series with the NK then made their money and left the buyers high and dry. I 'll keep trying to solve the problem and If I'm successful I'll post my findings.
thanks again for your help. Cheers.
I'm not so sure about the "made their money" aspect. Business practice usually wrings every last penny out of a profitable scheme! Much more likely it was realised early on that there simply wasn't room for another high-end system in the marketplace and withdrew before they lost too much
You're probably right. I'm just cheesed off with them.
GiM_6x Regular Member • Posts: 286
Check also the lens's pin on camera, it might get stucked from drop.
GiM
 GiM_6x's gear list:GiM_6x's gear list
Samsung NX1 Samsung NX 18-200mm F3.5-6.3 ED OIS Samsung 16-50mm F2.0-2.8
